Impact Wrench for changing tires... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > All Models & Variants > MINI in Motorsport
MINI in Motorsport For everything to do with MINI in motorsport
Old Dec 9th, 2002, 08:30 PM
Local Time: 03:02 PM
Have any of you guys bought an impact wrench yet for changing into your autox tires? Now that I have my mini, and my dad has his boxster S, I will be changing 8 tires every Sunday morning, and unscrewing the lugs is a time consuming, pain in the butt process. Can anyone recommend a cheap impact wrench that I could buy for changing the tires?
Scott
Old Dec 9th, 2002, 08:47 PM
dukesantos's Avatar
Local Time: 01:02 PM
United States Male View dukesantos's Pure Silver & Body Color 1st Gen MINI Cooper S Profile
I had the same need. I bought the Sears Craftsman Pro 7.5 amp electric impact wrench. It works very well and is easy to use. You will also need two of the black, long impact sockets- 17mm for the MINI and 19 mm for the Porsche.
Old Dec 9th, 2002, 09:07 PM
Awesome, thanks a bunch
Old Dec 9th, 2002, 09:12 PM
Wow, that actually costs quite a bit, do you know of any wrenches that costs under 100 bucks that are satisfactory for the job?
Old Dec 9th, 2002, 09:20 PM
United States View RSAmerica's Chili Red & White 1st Gen MINI Cooper S Profile
You will need 14.4v, for a Porsche which requires 94 FT-Lbs:
Milwaukee 14.4v Impact Wrench 1/2" Drive
Old Dec 9th, 2002, 09:45 PM
dukesantos's Avatar
I've never seen one for under $100. You should torque to the proper setting with a manual torque wrench (again Craftsman $69 and up) so the impact power isn't critical. I've always been able to break loose factory/tire shop installed lugs on various vehicles with the Craftsman. If cost weren't a factor that Milwaukee unit looks very nice.
Old Dec 10th, 2002, 01:47 AM
Racer's Avatar
Blast from the past !
Send a message via ICQ to Racer
Local Time: 08:02 PM
View Racer's Kawasaki Green & White 1st Gen MINI Cooper Profile
You guys are sooo lucky sometimes - try buying a decent one of these in the UK for under 400 bucks!
Old Dec 10th, 2002, 07:58 AM
Mugami's Avatar
Local Time: 04:02 PM
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile
I bought one of the Cheap Electric Impact wrenches at walmart.(34.95) I was able to remove and replace the factory wheels on mine many time without fail. I cant say it was faster but i can say it was less back breaking. Its not a high quality piece like the others but it does work. Name brand is Rally
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
Old Dec 10th, 2002, 07:59 AM
Mugami's Avatar
another image
Old Dec 10th, 2002, 01:30 PM
Local Time: 02:02 PM
United States View elmadi's Liquid Yellow & Black 1st Gen MINI Cooper Profile
Mine does not work on my Civic so I return it.
Old Dec 10th, 2002, 06:03 PM
jlm
it is not recommended to install with an impact wrench, only remove. They are not reliable as torque wrenches.
john
Small Report after changing tires on my GP Lorien First Generation Works 34 Nov 4th, 2006 11:59 AM
Changing tires Lorien Wheels, Tyres & Brakes 10 Sep 27th, 2006 07:33 PM
Using a torque wrench... Pinball Wheels, Tyres & Brakes 3 Mar 7th, 2006 09:39 AM
2 Big questions reguarding changing tires/Rims kyriian Wheels, Tyres & Brakes 0 Mar 23rd, 2004 04:40 PM
