| MINI in Motorsport For everything to do with MINI in motorsport |
| A 215 is going to be wide on a 6.5" wheel, but I've raced with a 225/45R15 on a 6" wheel before so I know the width WILL fit. It's just a matter of clearance and such. But, me testing a 215/40R16 is NOT the same at testing a 215/40R17. The 16 will be a significantly lower diameter than stock (1.5"), allowing for much more clearance. I'm not worried about the speedo error, it's a race tire for me. On the other hand, a 215/40R17 is only .5" lower diameter, so the extra width may not fit based on that. - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| Brian, There was an HS MINI running the 215 Hoosiers at our Divisional this weekend, they seemed to clear OK. He had R84's. You could tell that it was a tight fit. I'm still planning on trying the 205/45 Kumho's if I ever get my "S". I plan to get R85's for the street and a set of R84's for competition. Tom |
| 215-40-16 tight fit There was an HS MINI running the 215 Hoosiers at our Divisional this weekend, they seemed to clear OK. He had R84's. You could tell that it was a tight fit. Tight, indeed. That's why there were only three Hoosiers on ther car, and one wrinkled Hoosier in the pits. This size clears the fenders fine, the challenge is mounting the tire on the rim on a cold day. Also, TireRack doesn't stock this size, (it's a special order) so a replacement tire is backordered, and this car will likely run another two events on the whacky three Hoosiers plus one street tire combo. |
| So, being that I have a guy that mounts Hoosiers all day long and has plenty of experience with small AND stiff sidewalls, I shouldn't have any other issue. Correct? Thanks, Brian - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| So, being that I have a guy that mounts Hoosiers all day long and has plenty of experience with small AND stiff sidewalls, I shouldn't have any other issue. Correct? The clearance between the front tire and shock is close. If you're making custom wheels, don't move the offset in the wrong direction. |
| Being that the stock offset is 50mm, I had planned (when I eventually get a custom wheel) to do about 45mm. I don't see why anyone would NARROW the track, so nothing should get closer to the shocks. About how much room do you think we have to move toward the fender lip? 2mm? 5mm? 10mm?!? - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| When parked, the fender clearance is fine, you could add 10mm to the track with no problems. When driving and moving through the travel range of the suspension, I'm not kneeling by the front wheel, so I don't know how close it gets. Here's what the stock r90 looks like parked; obviously the 215-40-16 will have more vertical clearance. |
| I meant the width, I know the height has PLENTY of room. It can't stick out past the fender well or it's not legal. - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| I meant the width, I know the height has PLENTY of room. It can't stick out past the fender well or it's not legal. Width should be OK, too. Does the plastic lip on the wheel opening define fender well edge ? If so, you should have plenty of extra clearance. |
| Yeah, the plastic fender IS the fender lip, so you shouldn't be able to see the tire past that when looking from above. Sounds like you're pretty sure it clears to me. Thanks, Brian - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| 215/45/17 any one running them? | Blacky | Wheels, Tyres & Brakes | 3 | Aug 5th, 2006 04:25 AM |
| What 215/40-17 performance tires are you running? | MINIAC | Wheels, Tyres & Brakes | 2 | Dec 12th, 2003 10:32 PM |
| What 215/45-17 performance tires are you running? | MINIAC | Wheels, Tyres & Brakes | 1 | Oct 26th, 2003 08:45 PM |
| What 215/35-18 performance tires are you running? | MINIAC | Wheels, Tyres & Brakes | 0 | Oct 17th, 2003 10:32 PM |
| What 215/45-16 performance tires are you running? | MINIAC | Wheels, Tyres & Brakes | 0 | Oct 17th, 2003 09:38 PM |
