| MINI2 Regular Join Date: Apr 2002 Location: Long Island, NY Local Time: 12:08 AM
Offline | exactly what is sport suspension plus ? miniusa says sport suspension plus (SSP) includes stiff anti-roll bars, for $500. (sway bars, anti-roll bars, stabilizer bars are synonyms). In SCCA stock you can use any front anti-roll bar, and any shocks, but you must have a stock rear bar. Also, you must run a set of other suspension parts as shipped from the factory: no homebrew mixing and matching (eg.,some parts from the sport suspension, others from the sport plus) of springs and rear sway bar is allowed. What exactly is the SSP ? Anti roll bars and only anti roll bars ? Are the mount the same points, with the same bushigs ? Does anybody have a fiche/CD w part numbers to confirm ? ![]() |
| MINI2 Master Join Date: Aug 2001 Location: Mt. Airy, MD USA Local Time: 11:08 PM
Offline | SCCA Solo II Stock allows any change in the suspension FROM THE FACTORY. The SSP is perfectly legal, even as an afterthought, since it's a stand-alone option. So if you got a pre-spec Cooper without SSP and wanted to add it later, it would still be legal because it's offered as a separate option. This situation is run into all the time with wheels as well. If it's not part of a package, you can upgrade it alone. According to some literature somewhere else I read, and the MINI mechanic I now race with, the SSP is bars AND springs, but not shocks. There is still some question of whether the rear bar is any bigger, I'll have to research that some more by checking the part numbers. In the meantime, if you're running Solo II Stock, definitely get the SSP. The funny part is that you may end up going with the standard suspension front bar to eliminate some understeer. But so far, I've been able to balance the car based on tire pressures alone. - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| MINI2 Senior Join Date: Mar 2002 Location: Washington, DC Local Time: 11:08 PM
Offline | to add to more useless information...spring rates are 160 lb/inch. i run aftermarket 170 front/ 160 rear. not bad for factory springs "The best change to your car you can make is adjusting the nut behind the wheel" |
| MINI2 Regular Join Date: Apr 2002 Local Time: 10:08 PM
Offline | stock suspension settings for my 2002 Mini Cooper, Premium package, with the stock 15" wheels, gas tank near empty. NO SSP option Used the computerized/laser measurement suspension rack across the street at my tuner's shop: read out says: Left Front Caster: +3.92 Camber: -0.24 Toe: + 1/32 Right Front Caster: +3.76 Camber: -0.68 Toe: -1/8 Left Rear Camber: -0.80 Toe: -1/32 Right Rear Camber: -0.76 Toe: 0.0 Total Toe Front: -3/32 Rear: -1/16 Anyone have the recommended stock settings from the factory? FYIAugs |
Offline | shock absorbers My understanding is you CAN'T "use any shock" in H stock or D stock. You can only use the available standard or available option shock (if any), or an aftermarket, non-coilover, with no more than two settings. Did I get something wrong? I'd really like to upgrade the shocks to an adjustable, but can't as yet, find one. DamperAugs |
| | #6 (permalink) |
Offline | the way i read it, it sounds like you can use any damper so long as the mounting points are the same as stock. i was reading about some miata where they had a multiadjustable damper but they had to lock (weld) the camber ajustment to the stock setting in order for it to be legal. "The best change to your car you can make is adjusting the nut behind the wheel" |
| | #7 (permalink) |
Offline | Here you go Russ for ALL stock classes: shock absorber adjustable spring perches must be welded at stock height the bump stops can be removed to facilitate aftermarket shocks aftermarket shocks allowable with no more than 2 external adjustments any bushing can be used external reservoir's allowable coil overs not permitted from my home club's website, NEOKLA SCCA http://www.neokla-scca.org/SoloII/Al...ications.shtml OkieAugs |
| | #8 (permalink) |
Offline | thanks! 2 external adjustments? does that mean 2 settings or does that mean an adjustment at the strut tower and one on the shock body? hahah so confusing. "The best change to your car you can make is adjusting the nut behind the wheel" |
| | #9 (permalink) |
| Sponsor,Moderator & Racer | TBD Augs Std Settings are Toe Front Left and Right 0 deg +/- 7.5' Toe Rear left and tight 0 deg 12' +/- 4' Camber front left and right -odeg 54' +/- 30' Camber rear left and right -1 deg 32' +/- 30' Castor left and right +4 deg 58' +/- 30' Any others let me know Racer |
| | #10 (permalink) |
Offline | adjusting shocks thanks! 2 external adjustments? does that mean 2 settings or does that mean an adjustment at the strut tower and one on the shock body? hahah so confusing. Generally '2 adjustments' means one adjustment for compression only and a separate adjustment for rebound only. |
| | #11 (permalink) |
| MINI2 Regular Join Date: Mar 2002 Location: Fairfield CA USA Local Time: 09:08 PM
Offline | I’m ordering a Cooper and will be running Solo II with it and would like to know how much advantage there is in ordering the SSP as compared to just the Sports Pak. Garfield, is there any rear wheel lift in tight turns (ala Neon) or do the tires stay planted with the SSP and how much under steer are we talking about? ![]() FlaggerStan |
| | #12 (permalink) |
Offline | i watched the mini cooper run yesterday...not sure if it had ssp+ on it, but it did not lift the rear wheel. i also watch the S run, albeit in rain, it didnt lift its wheel either. another cooper with spax coilovers reportedly did lift its wheel under hard cornering. "The best change to your car you can make is adjusting the nut behind the wheel" |
| | #13 (permalink) |
Offline | Hmmm. 205/50R15 Kumho Victoracers on standard suspension, I did this in March: - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| | #14 (permalink) |
Offline | ahh but you drive like a mad man. what tires did they have on the car yesterday? they were kumhos right? "The best change to your car you can make is adjusting the nut behind the wheel" |
| | #15 (permalink) |
Offline | Did you stay to see me drive the MINI yesterday? Yes, the Cooper was running 205/45R16 Kumho Ecsta V700's. Pretty much the same compound tire, just newer design. The MINI is a VERY well balanced car considering how front heavy the numbers are. It does understeer but it can be easily counteracted by the tire pressures and responds excellent to lift throttle oversteer. If the pressures are too high in the rear, it comes around too easily, but can always be corrected by giving it throttle. What you want to do is dial in just enough oversteer for you to purposely cause it, that way you can drift it around sweepers very easily. The car is great, no doubt about it. Yesterday, I drove a Type R for the first time. It cornered flat but the steering response was week and certainly needed much more input to get what you needed. I ran it for 3 runs, the first two I shifted into second and tried to run it in the lower revs through the tight course. The third run, I finally decided to see how far 1st gear would take me through the course and shaved off 1.2 seconds to a 57.8. That car HAS to be run at 7-8k all the time, THEN it's a rocket. (I jumped in the Cooper for one run and turned a 59.9, as a reference. I may have been able to pull into the high 58's with a couple of runs, but no better than that) The Cooper and Cooper S have a lot more pull down low than any of these Hondas, etc. so it can be driven as such. I still have not had a Cooper S on a dry course to compare back to back. To me, from how I've driven it so far, the two suspensions are not that much different. I noticed the S's being a tad stiffer, but nothing to say "oh my god" about. By the way, on the autocross, the Coopers have a definite advantage in that I've never been able to throw a car into first gear so easily. It's very friendly to that. - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion Last edited by Garfield : May 6th, 2002 at 10:00 PM. |
| | #16 (permalink) |
Offline | no i didnt see you drive the mini and it sorta disappoints me that i missed it. oh well, i have a sunburn like no other and wouldve melted if i stayed any longer. i was hoping to see you drive the cooper S on dry pavement this time but no luck...the demo S is being delivered. i had hyped up the S so much to my friend who drives a Mk II N/A Mr2 but you not driving the S and and that incredible driver driving that black Mk II n/a mr2 did not help matters. he still believes the mr2 is superior and i still think the cooper s is. i know i shouldnt bench race but sometimes i just have to! hahah next time hopefully you'll have your S. as far as the type R having to be driven in 1st gear...its all about the vtec engaging i guess. when i drove it i didnt notice the slow steering you mentioned though. i sent you a pm about helping out at the next event so i'll send you an email closer to the next event. do you by any chance know if the cooper had the ssp or ssp+ on yesterday? and when you go from understeer to oversteer are you left foot braking or just gently tapping the brakes?"The best change to your car you can make is adjusting the nut behind the wheel" |
| | #17 (permalink) |
Offline | None of the pre-spec Coopers have a Sport Suspension Plus (which is why Marshall HAD to order his), so I can safely assume this one didn't either. The Cooper S "MIGHT" be faster than a NA 2nd Gen MR2, but that will still be a toss up on certain courses. And I can guarantee the MR2 will be faster with Lee Piccione or Doug Newhard driving (just look for their National results). To go from understeer to oversteer it's neither that you suggested, it's simple throttle application and lift, no brakes necessary. That's what makes this car great for a smooth driver. - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| | #18 (permalink) |
Offline | then why is the mkII n/a mr2 in e stock and the cooper s in d stock? doesn't sound fair. i just looked at the results and im just more confused. in theory...e stock cars should be slower than d stock right? i guess the mid engine, rwd layout is just superior in the hands of a capable driver (as in Lee)? im not really worried about it too much but given equal drivers (experienced), what would turn a better time? so if yourself, or lee, were to drive the mr2 and cooper s back to back which would come out on top? "The best change to your car you can make is adjusting the nut behind the wheel" Last edited by districtofc : May 7th, 2002 at 10:34 AM. |
| | #20 (permalink) |
Offline | i doubt any competitive autoxer is gonna give it away but i think its somewhere around the low 40s up front and upper 30s out back. good luck. ![]() "The best change to your car you can make is adjusting the nut behind the wheel" |
| Sport suspension Vs Sports Plus suspension | Zub | MINI Cooper | 37 | Jun 21st, 2007 02:24 PM |
| Difference in ride height between Sport Suspension and Sport Suspension Plus ? | GUSS | Suspension | 0 | Jun 20th, 2005 07:28 PM |
| No Sport Suspension Plus | colorblind | MINI Convertible | 0 | Mar 18th, 2004 03:18 PM |
| sport suspension | districtofc | General Discussion | 2 | Apr 29th, 2002 09:23 AM |
| Suspension - Sport / Sport Plus? | MrM | Faults & Fixes | 4 | Apr 12th, 2002 05:46 AM |
