Visit Out Motoring!
Old May 19th, 2002, 11:28 PM   #1
Garfield
Garfield's Avatar
Local Time: 11:14 PM
Thumbs up Cooper S G-Tech numbers...
Ok folks, take this with a grain of salt, but here's what my G-Tech came up with.
It took me several runs to get the launch right. But, when I finally did, I was quite impressed.
Ambient Temp: 45 deg F
Tires: 215/45R16 Falken Azenis (sticky)
Unsprung Weight: approx 14lbs less per corner than 17's
GEAR RATIO IS LOWERED SLIGHTLY BECAUSE OF LOWER DIAMETER TIRE - 3.4% lower
Pressures: 37psi (sticky for autox, too much for drag)
Best two 0-60 times were 6.57 and 6.54.
I wasn't paying attention to 1/4 mile times, but the last 0-60 I took, I followed through with a 1/4 mile of 15.14 at 94mph.
Now, I understand that this isn't perfectly accurate, but from past experience with other cars, the numbers were close to the magazines times (if not right on).
My Audi allroad times were much faster than Audi's numbers, but that wasn't a shock either.
- 2005 G Stock '05 MINI or it's back to a Miata in C Stock
- 2004 G Stock 2nd place Pro Solo, 9th Place Solo II
- 2003 STX 5th place Pro Solo, 6th Place Solo II
- 2002 H Stock Pro Solo National Champion
Old May 20th, 2002, 03:30 AM   #2 (permalink)
rich
rich's Avatar
Local Time: 02:14 PM
Ooh la la!!!
Any chance of running a standard tyre-spec S too? Pretty please
Cooper S, Jet Black w/ white roof, silver 16" X-Lite wheels, DSC, MFSW, dark tinted windows
...It's here & I love it!
Australia   Reply With Quote
Old May 20th, 2002, 07:15 AM   #3 (permalink)
Garfield
Garfield's Avatar
Not a chance from me, since I don't own them anymore. But, I would venture to guess you wouldn't do any better than 6.75 or worse than 7.0.
I'm trying to recall which run it was, but I'm about 90% sure I ran a 6.99 with ASC turned ON! If that's the case, the stickiness of the tires wouldn't matter, but the unsprung weight would.
If I eventually get the chance to throw the G-Tech on someone elses with stock wheels, I'll do it.
Old May 20th, 2002, 07:19 AM   #4 (permalink)
districtofc
districtofc's Avatar
i want lateral acceleration numbers!!!! please!
"The best change to your car you can make is adjusting the nut behind the wheel"
Old May 20th, 2002, 07:26 AM   #5 (permalink)
Garfield
Garfield's Avatar
I don't feel they're as real as the others, plus, it's more of a pain to set it up and find a place to do it. The Falkens will affect that even more as well.
If I get a chance, I'll post them though.
Old May 20th, 2002, 07:34 AM   #6 (permalink)
districtofc
hopefully i'll be able to run these tests on my stock tires...i want to get the new g-tech thats been released. anyway, your results are pretty impressive.
Old May 20th, 2002, 07:34 AM   #7 (permalink)
Dom
Test thread infiltrator
Dom's Avatar
Local Time: 05:14 AM
Send a message via MSN to Dom
Hmm... that's kinda quick! Stop posting these details or I'll be forced to buy an S!!
What modifications? Just the wheels?
Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old May 20th, 2002, 07:44 AM   #8 (permalink)
Garfield
Garfield's Avatar
Just the wheels and tires. On one hand, they have an advantage because of much less weight and VERY sticky, and lower gearing. On the other hand, the were pumped way to high giving a smaller contact patch.
Old May 21st, 2002, 04:48 AM   #9 (permalink)
olddad
Local Time: 09:14 PM
Why do I feel Like I need a cigarette?
Guess there is something to that reduction of rotating mass.
Cooper S Red/White/White, Air, Computer, Cloth, DSC, Cold Weather. August build.
United States Male View olddad's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 21st, 2002, 08:40 AM   #10 (permalink)
rich
rich's Avatar
Garfield
Sorry to ask an obvious question, but were the times recorded on a flat track & was there any noticeable breeze?
Rich
Old May 21st, 2002, 09:13 AM   #11 (permalink)
scottgib
Talking Garfield
I appreciate your posts very much. Thanks.
On the launch--specifically what did you have to do to get the best results?
Also, were those tires on 6.5" rims and have you detected any rubbing? Have you autoX'd this setup? Who made your rims and what did they cost? I am planning to get an extra set of 16" stock rims and either put Kumho's or Falkens on them for autoX.(Don't have my S yet.) What would you expect the difference to be between V700's and the Azenis. (I currently have Azenis on a 914-4 and am rather impressed but am not competing well with the guys that have the Hoosiers or V700's.) Thoughts?
Again your info is great. Keep it coming.
Old May 21st, 2002, 11:42 AM   #12 (permalink)
Garfield
Garfield's Avatar
Breeze? Don't recall much of one. "Track" consisted of the shoulder of a flat two-lane highway. VERY Slight hill, but I erred on the uphill side. Waited for all cars to pass, hit the button, dropped the clutch and gradually pulled out onto the road. So hell, there may have even been less traction because of shoulder debrit, but not much less by what my eyes could tell.
Am I giving my own competitors my research?? Should I be paid for this?
Quickly released the clutch at 3k, never took my foot off the floor, and at about 4k it hooked completely up and took off.
16x6.5 rims with 45mm offset.
Enkei RPO-1 wheels, retail for $150/each.
The Falkens are NOT autox tires unless you're in STS or STX. They're close, but not enough to beat a Kumho car. I like them, but will still run my Hoosiers at local events (on identical rims, bought two sets).
Old May 21st, 2002, 02:45 PM   #13 (permalink)
scottgib
Garfield
Personally I am no competition in that I will not get out of the SE region for a number of reasons.
I have searched for over an hour on the internet and have not found Enkei RPO-1's in 16x6.5. Where did you buy them?
Thanks.
Old May 21st, 2002, 03:00 PM   #14 (permalink)
Garfield
Garfield's Avatar
As brief as possible, I got them straight from Enkei, but the sold the rest of them to a distributor with stores in the West. They're being discontinued except for special orders from Japan. Call Enkei and ask them where they went.
Old May 21st, 2002, 05:02 PM   #15 (permalink)
districtofc
scottgib, in my humble opinion your best bet is to wait for the wheels specifically designed for the new cooper coming from panasport. thats just my opinion though call panasport for more details...
Old May 21st, 2002, 10:03 PM   #16 (permalink)
Garfield
Garfield's Avatar
I wouldn't count on lightweights from Panasport though, only the style. They aren't heavy, but they're certainly not light for the price.
Old May 21st, 2002, 10:54 PM   #17 (permalink)
ezrally
ezrally's Avatar
Local Time: 10:14 PM
Panasports are close to the orignal Minilites in a appearance if not size. Thats what I'm getting for a second set of wheels.
Jet Black MCS
Lapis leather
17s or 15s (winter)
no DSC
United States View ezrally's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 22nd, 2002, 07:49 AM   #18 (permalink)
districtofc
from what ive heard they should be light...probably not as light as the rp01s but not much more. btw, if anyone wants the enkeis let me know, i can get them for you.
Old May 22nd, 2002, 09:18 AM   #19 (permalink)
bigbaddaboom
bigbaddaboom's Avatar
Send a message via MSN to bigbaddaboom
Sounds like good numbers, the launch sounds right too.
Thanks for the times, any chance of 0-100??
French Polynesia View bigbaddaboom's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 22nd, 2002, 09:40 AM   #20 (permalink)
Garfield
Garfield's Avatar
It stops timing at the 1/4 mile, so unless I can hit 100 before then, I doubt it.
It was still pulling strong to the 94mph at the 1/4, so maybe in the 18's? I don't know. I shouldn't really try to guess any better than the next person.
It can do braking from 60mph at well, I've just never done it, I'll have to give it a try.
Wheel Arch Marker Lights & Reflectors - One/Cooper Parts Numbers JerseyMini Exterior 4 Jul 1st, 2005 01:42 AM
Cooper S parts...part numbers blackflamer Exterior 0 Jul 22nd, 2003 10:01 PM
Digi-Tech Tuning for Cooper S - 220HP! benggolf Engine & Drivetrain Tuning 29 May 24th, 2003 01:24 AM
Tech manual CD KenL General Discussion 0 Oct 11th, 2002 03:20 AM
