Track Day Wheel setup 15 vs 16 or 17's - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > All Models & Variants > MINI in Motorsport
MINI in Motorsport For everything to do with MINI in motorsport
Old Apr 12th, 2005, 02:31 PM
Local Time: 08:05 PM
United States View anthrazit's Solid Black & Body Color 1st Gen MINI Cooper S Profile
I am hoping some people can offer their opinion. I have search a bit, but have not found an answer.
What are the benefits/negatives to running a 15 in wheel for primarily track duty?
Here's my thoughts so far:
1. Lighter wheels/tires package.
2. Less expensive tires
3. Better tire selection (?)
Negatives:
1. Faster tire wear
2. Could it gear the car too low with the new gearing change in the 05 cooper S?
Thoughts? Need to make a decision soon! Thanks!!!
Old Apr 12th, 2005, 02:36 PM
luke o'callaghan's Avatar
Wales View luke o'callaghan's Astro Black & White 1st Gen MINI Cooper Profile
running 15s you'll get better fuel consumption ,if you're using for primarily track you should stick with either 15s or lightwieght 16s
Old Apr 12th, 2005, 05:30 PM
KATENKEITH's Avatar
Challenge addict ...still
Local Time: 09:05 PM
England
Negatives:
1. Faster tire wear
If you are not doing a big brake upgrade there doesnt seem much point going larger than 15 or 16".
15`s will give a slightly lower gearing (depending on tyres) and less weight so be slightly more accelarative. I doubt you`d affect top speed unless you are on a mega long flat out section.
Old Apr 12th, 2005, 11:20 PM
:: Jon ::'s Avatar
Scotland Male View :: Jon ::'s Classified Ads
15s
Negatives:
1. Faster tire wear
i used to race my old austin mini 1380cc every other weekend before i blew the stage 4 head and sent the oil all over the engine bay and on to my tyres causing me to spin a few times into the run off also i did the odd hill climb in it too.. i use to run with 10x6 inch wheels for racing then convert back to 13x7 for every day use..
so as far as wheel selection goes the smaller the better.. go with the 15s this will use the power from the engine and displace it directly onto the track for max grip.. if poss use semi slick tyres too.. yokos are good
Old Apr 15th, 2005, 11:22 AM
Best Personal Regards
Local Time: 10:05 PM
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
Someday I'm gonna try a set of 13's on my MINI for track duty. Anyways, you can't go wrong with 15's.....better cost and better acceleration are key. No way you can get it into 6th at any race track that I know anyways.....
Old Apr 15th, 2005, 11:52 AM
KATENKEITH's Avatar
England
Thruxton-Hampshire-UK?
Old Apr 16th, 2005, 07:04 AM
You might just nip it into sixth for like a tenth of a second around the back, but I would rather doubt it. Matter of fact, I would find it hard to think you could red line it in 5th there. Having said that, have not been there with ole PKT RKT...... In the UK, maybe Silverstone GP, maybe down Hangar Straight. The British isles are just not known for their long tracks.
Old May 8th, 2005, 03:11 PM
s_and_m's Avatar
220 of your finest horses
Send a message via MSN to s_and_m
England Male View s_and_m's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
I concur
If it weren't for the fact that I am so heavy footed that I need the extra braking capacity of an AP Brake upgrade, I'd be running a cheap set of 16 inch X-lites for track work.
S
Old Jul 3rd, 2005, 06:28 PM
BRGNICK's Avatar
Send a message via MSN to BRGNICK Send a message via Yahoo to BRGNICK
15" is my recomendation
I picked up a set of 15" on ebay cheap the other day and did my 2nd track day with them on 01/07/05. They only were 175/15/60 so I was a little concerned about grip.
When I got to the track I was pi**ing down and I thought that I would not be having any fun and would be spinning and sliding every where. Not at all. I didn't really think about this as thinner tyres are better in the wet as thicker ones make u aqua plan more.
The day was amazing and I've saved by 17" runflats another 1000 miles or so in wear. So all in all .
Definatly faster acceleration and significantly improved economy. Plus the drive down on the motor and A roads was nice and smooth and I arrived quite comfortable. Definatly an improvment on the Runflats.
BRGNICK
Thunderhill Track day 7-6-2006, lots of track time, low cost! ThePerfectLine Northern California Region 0 Jun 26th, 2006 09:59 PM
Track Day @ Autobahn Country Club South Track 7/7/05 Joliet, IL LugnutM3 MINI in Motorsport 0 Jun 9th, 2005 10:49 PM
Best whl/tire setup for track use?? hotdogmini Wheels, Tyres & Brakes 10 Apr 24th, 2003 04:30 PM
