Visit Derek Woodman MINI
Old Aug 4th, 2003, 07:39 PM   #1
jasonfields007
jasonfields007's Avatar
Local Time: 01:04 PM
Send a message via MSN to jasonfields007
gear shift
hi all,
I've driven the S and the gear shift is pretty stiff and presise. Does the same go for the D's gearbox? Also is it any easier to put in reverse?
Jason
'06' Cooper S Convertible - Astro Black, '04' Mazda RX8 231 - Black
Old Aug 4th, 2003, 07:54 PM   #2 (permalink)
MarkW19
Grinning
MarkW19's Avatar
Yes, the Getrag 6-speed is the exact same one they put in the D. And I assume it will be a tad difficult to put in reverse too as it's the same!
Why don't you take a D for a test drive seeing as you've already ordered one?
United Kingdom Male View MarkW19's Astro Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 4th, 2003, 08:15 PM   #3 (permalink)
jasonfields007
i'm 16 so my dealer wont let me drive it. my dads driven it and says it's great and he's got the S.
j
Old Aug 4th, 2003, 09:49 PM   #4 (permalink)
Liam"S"
I must admit the gear shift is very good in the one I have got a lock slicker than in my S, so much so that I rang up, whilst my car was in having work done on it, and asked them to check the system out. I'm pretty sure its not that same box as one the S the ratios are tottaly diff it could well be built by getrag though I wonder if they use the same bell housing and the holes pitchins are the same on the yaris block. hmmmm thoughts. sorry I am going on.
Liam
its all about the GG (or in this case the uhhh SCREW)
Old Aug 5th, 2003, 04:21 PM   #5 (permalink)
ONED
SUCKIN DIESEL!!!!
ONED's Avatar
We aint had any problems with the gearshift, although anyone who we let drive the car failed to get reverse first time. I can't see any problem!!!
United Nations Male View ONED's Nightfire Red & Black 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Aug 6th, 2003, 06:18 PM   #6 (permalink)
ayde_bury
* Lab Rat *
ayde_bury's Avatar
I had a problem getting the reverse gear on the test drive of a OneD. It was more a case of not being forceful enough and not wanting to damage the car.
The dealer suggested pushing from neutral to the left, then push firmly again to get it through the gate. After that it was no problem at all.
Cant comment on my own, as delivery isn't due until Mid September / October
United Kingdom Male View ayde_bury's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Aug 7th, 2003, 09:32 AM   #7 (permalink)
mmartin
Local Time: 12:04 PM
It is a poor reflection on the design of the 6 speed box when people are commenting that they think they might damage the thing trying to select reverse. I am sure that they could modify the design so that it requires slightly less herculean efforts to get to reverse. I have commented previously that in the users guide it says 'push the lever to the left (UK) till the detent is overcome then select reverse', there is no mention of slaps or whacking from the right etc. etc. Perhaps time for a redesign or maybe rewrite of the manual!
L.E.D. Gear shift indicator Dazmac13 2nd Gen MINI Cooper S 11 Apr 21st, 2007 02:32 PM
gear shift stuck!!!! magnusonf1 Faults & Fixes 2 Mar 6th, 2007 12:21 PM
Gear Shift Indicator miniman23 2nd Gen Interior & Ice 6 Sep 30th, 2006 10:28 PM
Gear shift popped off ! timmy Faults & Fixes 4 Jul 31st, 2004 12:38 AM
Buzzing gear shift bookem Faults & Fixes 4 Mar 22nd, 2004 03:58 PM
