| MINI2 Newbie Join Date: Jul 2006 Local Time: 05:16 AM
Offline | More Performance... Hi! I am trying to get the most of my mini One without doing ECU remap(at least for now). I've only got a KN panel filter, and now i've got two new ideas but i have a few questions... New Spark Plugs... Which are the better ones? Denso?NGK?Bosch? I'm really thinking in removing the cat(maintaing the stock exaust system) but i'm affraid the car would be very loud... Anyone tested it? And hp gain? does it worth it!!! Sorry for my bad english!!! |
| MINI2 Regular Join Date: Aug 2003 Local Time: 11:16 PM
Offline | Don't want to be negative, but I doubt the panel filter and spark plugs are going to make any noticable improvement in power. Removing the cat would make for less exhaust restriction, and perhaps a very small power increase. I don't see why it would be loud with the stock exhaust still in place. Of course, it's most likely illlegal to remove the catalytic converter. Let us know if there is a noticable power increase from the things you do. Robert Stancliff Sr. |
| JUST STEP ON IT...!!!!! Join Date: Jun 2006 Location: MIAMI Local Time: 12:16 AM
Offline | Honestly, I've tried a lot of the products out there. For startes and this will not give you horse power, but it will keep your MC from stalling when steping on it. 1. Change the Factory Cables (Spark Plug Wires) 2. Change the Coil as the Factory does not shoot out as much sparks as after market. 3.Exhaust from the Cat Back. Invidia or MyMini are less expensive easy to install and better performance than a Magna Flow or Borla. 4. Defenetly a 15% Pulley, You will see the difference once you have this change. Why from the Cat Back. Well the Factory Header to Cat is quite good and quiet. If you change to hearder, you will spend some $ and you car would sound louder, plus be carefull with exhaust welding and modifying. So will spend a lot of $ to gain 3hp not woth it. So, stock MCS with Exhaust, Pulley, Instake, you should be around 195 to 205hp. Plus you will see the difference. Enjoy...? ![]() ..Step On It...!!!!!.. |
Offline | Thank you for your answers...!!! But remember i have a MINI One!!! By the way with the panel filter and with fuel that i use(BP 100 octane) i can notice the difference.. The car revs up more easly and i have just a little more top speed (about 195km/h) in straight. And the eml light ? how am i going to turn it off? am i going to see some flames without the cat? ![]() |
| MINI2 Senior Join Date: Mar 2006 Location: Madeira Island Local Time: 04:16 AM
Offline | INNuendo.... if youre getting 195 km/h (121MPH) then I certainly wouldnt complain as MINI state that the top speed of MINI ONE is 112MPH! ![]() you car is 9 MPH faster than it should be!Check this. http://www.mini.co.uk/UK/html/model_range/mini_one/techSpec.html |
| | #6 (permalink) |
Offline | Thats not a bad thing i think but... i want more!!! I remind you that i have 175/65/r15 tyres so in a straight i can be almost side by side with a stock cooper! i'm going to remove the cat and put new spark plugs and then i tell you how it feels... by the way as anyone got a mp3 or wav file of a mini without cat but with the stock exhaust??? |
| | #9 (permalink) |
| MINI2 Newbie Join Date: Jun 2006 Local Time: 12:16 PM
Offline | Try the Bluefin ECU up-grade ?. Was told it will push up the power to 120Hp Its only abt 95 seconds and can be done at your home carpark !. Just plug it into the OBD, follow the simple display instruction and bingo ! I did it on my MCS. |
| | #10 (permalink) |
Offline | I tend to agree, not much u can do to increase on the Mini 1. Spark plugs, exhaust does not give u the ooommp if thats wat u looking for. Its also illegal to remove the cat in the exhaust. Might be wrong but the mini1's engine is very much the same as the MC except the ECU setup . So good luck with your up-grades. |
| performance of new vs old S | PaddyF | 2nd Gen MINI Cooper S | 33 | Aug 21st, 2006 09:15 PM |
| Performance Help | paulworthing | MINI One | 3 | Feb 5th, 2005 09:28 PM |
| Hi Performance | DJM | Engine & Drivetrain Tuning | 6 | Dec 3rd, 2004 06:47 AM |
| Performance | Teladi | MINI Cooper S | 8 | Oct 31st, 2004 06:56 AM |
| Performance?? | RYN | MINI Cooper | 15 | Aug 5th, 2002 02:31 PM |
