Adam's Polishes
Old Oct 14th, 2003, 02:13 PM   #1
jegaboo
Local Time: 08:50 AM
cooper s wheels and springs on a one
New to the site, so apologies if this question has come up and been answered before.
I have a mini one with std alloys, can I put stock Cooper S wheels and Cooper S springs on? What effect would this have on the car Good or Bad?
Old Oct 14th, 2003, 04:33 PM   #2 (permalink)
ChrisBuer
ChrisBuer's Avatar
Send a message via MSN to ChrisBuer Send a message via Skype™ to ChrisBuer
There shouldn't be any problem at all fitting the Cooper S wheels, but I'd go for the 16" X lites opposed to the 17" wheels (as the 16"s handle better).
Regarding the springs, why not purchase some A C Schnitzer springs for your One? They are BMW approved, will drop the car 45mm, and would be better than the S springs imho!
The A C Schnitzer springs are available through all BMW dealers.
Lotus Elise SC - Collecting 1st April
United Kingdom Male View ChrisBuer's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 14th, 2003, 04:57 PM   #3 (permalink)
jegaboo
Thanks for that. The reason I was looking at the Cooper S springs, is that a friend has had his Cooper S to birds for the hartge conversion and the wheels and springs are available. I find the Mini One ride a bit bouncey, would the wheels and springs cure this?
Old Oct 14th, 2003, 05:10 PM   #4 (permalink)
ChrisBuer
ChrisBuer's Avatar
I'd say they probably would, but I'm quite sure that the Sports Suspension Plus you get on a Cooper S is not just different springs, the whole system is different (I might be wrong though).
The S springs should be stiffer and the wheels will be firmer (if they are bigger than your current wheels).
Old Oct 14th, 2003, 05:54 PM   #5 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Local Time: 09:50 AM
If you put the S springs on yours apart from lowering it it will make the car a lot firmer and more crashey over bumps tho it will handle better.
The wheels, what size are they?? most likely 17's if so this will alter the handling of your car and make the ride even more crashey tho it will look smart.
It wouldn't bother me but it may be a bit of a shock for you going from std to S setup so it may be best if u go take a ride in an S with 17's on.
Hope that helped and good luck!!
Japan Male   Reply With Quote
Old Oct 14th, 2003, 08:06 PM   #6 (permalink)
jegaboo
So to compromise, do you reckon that I should just change the springs?
Install sports springs to compensate for using Koni FSD? Or are standard springs ok? NeuroBeaker Suspension 9 May 15th, 2007 05:09 PM
The GP wheels is on, and it so needs lowering, wich springs? Freddo 2nd Gen Suspension 1 Apr 25th, 2007 06:07 AM
Which tire for 17" R90 wheels with Eibach lowering springs MCWim Wheels, Tyres & Brakes 3 Nov 2nd, 2005 08:38 AM
JCW 18" Wheels with Eibachs Lowering Springs? Maaij Exterior 5 Aug 28th, 2005 02:40 PM
lowering springs and wheels = calibration required? KJ_daGreenMini Suspension 5 Feb 26th, 2004 11:42 AM
