Visit Mini Mania UK
Old Dec 29th, 2003, 06:47 PM   #1
Minione1.616v
Minione1.616v's Avatar
Local Time: 02:00 PM
Dark Silver Lights
I have a Mini One that is 4 months old and one of the inside reading lights and one of the rear lights have stopped working. Do you think it's just the bulbs if so is this normal and is it covered by warranty.
Thanks for replys in advance.
Sam
Old Dec 29th, 2003, 06:51 PM   #2 (permalink)
Rakey
knowing me, knowing you
Rakey's Avatar
Local Time: 03:00 PM
have you tried to do a reset?
if not then do try it, it should be in the manual, but it basically involves you holding the button on the light in for about 6 seconds till the light flashes then all should be ok
If that doesn't work then might be worth contacting MINI assist to advise you or your dealer.
Its only a forum you know!
Old Dec 29th, 2003, 11:30 PM   #3 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
I don't think bulbs would be under warranty
Japan Male   Reply With Quote
Old Dec 30th, 2003, 01:19 AM   #4 (permalink)
Rakey
Rakey's Avatar
since when have you posted in threads that are not in OT&B?? are you just bored and following everything I have posted in today??
it is not confirmed that the bulb has gone
that is why reset was suggested by me as it is a problem I had on my car, at the time it was MINI assist that helped resolve it with a simple call to them. They are always happy to advise and will soon say if it needs to go in to be checked out, and after only 4 months I would expect more life from a bulb if it had failed, but it could also be other things, so would be expecting this to be sorted under warranty wouldn't you?
Old Dec 30th, 2003, 12:41 PM   #5 (permalink)
Minione1.616v
thanks
Old Dec 30th, 2003, 12:45 PM   #6 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Just in case u didn't notice this is the One forum
Old Dec 30th, 2003, 01:11 PM   #7 (permalink)
Rakey
Rakey's Avatar
Quote: Originally Posted by Minione1.616v
thanks
did the reset work then?
Old Dec 30th, 2003, 01:12 PM   #8 (permalink)
Rakey
Rakey's Avatar
so, still raises the question what you doing out of OT&B!!
Old Dec 30th, 2003, 01:23 PM   #9 (permalink)
Martin L
MINI defector
Martin L's Avatar
Something seems afoot there. Take it to the dealers and they should replace/fix it under warranty. Two lights to fail in 4 months is not to be expected.
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Dec 30th, 2003, 09:14 PM   #10 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
K K I admit I got lost
fittin xenon lights to a mini one, previous lights were. halogen h7 stefan one s Exterior 16 Jun 27th, 2007 07:53 PM
Changed my 2003 MINI Cooper S' rear lights to 2005 lights. Paul Exterior 3 Dec 1st, 2004 01:37 PM
Front Driving Lights inplace of Fog lights brett Exterior 29 May 8th, 2004 10:07 PM
convert rear fog lights to run/break lights bobw Exterior 2 Jan 1st, 2004 01:31 PM
Did you know the 7-Series has Rear Fog Lights that double as emergency brake lights? BruceK General Discussion 7 May 7th, 2003 03:30 AM
