Question for P-Torque - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Sponsors > Performance Torque
Performance Torque
 Visit Performance Torque! Find Products, Group Buys, Special Offers
ECU Remap Specialists
Old May 1st, 2009, 01:37 AM
Local Time: 12:29 PM
Will,
Have you found a way to control A/F when running over 16.5lbs boost on the R56 S?
Not asking how you did it if you have, just if it's possible (and been done).
Thanks!
Old May 4th, 2009, 09:28 AM
Local Time: 11:29 PM
With mods and the p-torque remap your looking at 19 psi overboost with 17/18 held til redline so im assuming yes. I think p-torque are on holiday just now.
Old May 4th, 2009, 04:58 PM
While I know 19-20 psi is possible I'm wondering what the A/F is at those levels.
The tuners over here are seeing the A/F get dangerously lean at those levels.
Old May 13th, 2009, 10:33 AM
MINI2 Sponsor
Local Time: 10:29 PM
Hi
Sorry, I have been away for a while...
I think you may be referring to a certain piggy back ECU? They are running dangerous lean levels as they do control injector open times correctly.
The P-Torque software sees approx 17psi overboost, or 18/19 with intercooler.
A/F is perfect, and actually a little rich at top end to keep things safe when driving hard
Old May 13th, 2009, 06:33 PM
Quote: Originally Posted by Performance_Torque (original)
Hi
Thanks Will!
I wasn't actually talking about the piggyback in this case - I know it runs lean.
Our tuners over the pond using DIMSport have found the AF going lean above 16.5 lbs of boost and just haven't figured out how to get around it yet. Something about the closed loop going bonky at high boost levels. They do know how to change the AF - it just doesn't work correctly above 16.5
unless you want to give up some trade secrets and let them know how to keep the AF good at 19lbs boost I guess they'll have to keep searching.
Thanks again for letting me know it is possible. Hopefully the MAF we have isn't the problem.
Old May 15th, 2009, 11:34 AM
MINI2 Sponsor
Hi
We don't get this problem. We have actually made software for Dimsport, for a customer they had with Hybrid turbo
Old May 16th, 2009, 09:07 PM
allrighty, must have something to do with the mass airflow sensor we have that you don't =(
Thanks for the info!
Performance Torque (P-torque) Stage 1 remap Review Cooper S futureal33 Second Generation MINI Tuning 124 Jun 1st, 2011 01:50 PM
a question about torque Morty First Generation MINI Tuning 4 Mar 29th, 2007 07:09 AM
torque, torque and more torque!! BLUEMINI-S First Generation MINI Tuning 11 Oct 13th, 2005 12:40 PM
Torque #'s Arioch General Discussion 4 Jun 5th, 2001 12:19 AM
