The engine RPM is about 1300 when the cooling fan is on( air conditioner is off), and drops immediately to 800 RPM when I turn the air conditioner on.Is this normal for cooper S??Thanks!!
HELP!!
What is the engine's idle RPM of cooper S??Mine is 1000-1300 with A/C off and drops to 800 when A/C is turned on. Why is it lower when A/C on??Quite strange....
I think this thread belongs in faults and fixes. Mr/Ms moderator?
My S idles at around 800 all the time. Turning on the AC or the interior fan ( I assume this is what you mean) don't seem to affect it at all. If yours is idling at 1300 it doesn't sound right.
True it doesnt sound right that the idle is at 1300 with no load. The fact that any fan is on doesnt matter cause the fan is electric and not attached to the motor. Question is does it rev at the 1300 with the fan off or does it rev at 800 then goes to 1300 with the fan on. If the idle doesnt change with or with out the fan then you may be running a bit lean on the bottom. Once the compressor kicks in it puts a load on the engine causing the revs to drop which is normal. In most cars once the AC kicks in it will bump up the revs 100-200 rmps to cover the load of the AC or it will keep the engine at a set rpm such as the 800rpm.
I have noticed recently in the morning when the temperaure is about 55 degrees F my MCS will idle at between 1200 to 1300 rpm for a bit. It then returns to a normal idle of 700 to 800 rpm as it warms up.
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
