04 Mini Cooper hesitation on pull away when cold?
2K views 1 reply 2 participants last post by  keefsez
#1 ·
Hi All
My wife's 04 Cooper (manual 5 speed) seems to hesitate or splutter a bit when pulling away when cold. It does seem to clear once warmed up. I've searched through the archives and see this is a common problem but couldn't actually find any threads with a solution what causes it on ones with manual transmission? ANy ideas?
Many thanks
#2 ·
hesitation/splutter when moving off
Hi, I know its awhile since you posted your thread but...my wifes 53 ONE does the same thing, wondering if you have found a solution ? Weve had the car for 2 years with full service history and its only recently started doing it. So far ive replaced, with brand new parts; air filter, oil n filter, spark pkugs, HT leads and ignition coil. There are no fault codes showing or pending and the Eml is not lit. In the meantime if I find a solution i'll post it..
Keith
