Wing mirror electrics + Lighter connected?
2K views 7 replies 3 participants last post by  countryhubby
#1 ·
Hi
This is my first mini and its a 2003 Mini cooper John Works. The wing mirror electrics are not working and either is the lighter. Any ideas? Not sure if they are connected.
I have checked the fuses inside the car and they seem to be OK for both. Is there a master fuse for power for both of these things or a common problem?
Have to admit I am a bit lost!
Any help appreciated!:smile:
#2 ·
Hi ya
If you are shore the fuses are ok F35 5amp for your mirrors and F32 15amp for your power/lighter socket.
I would think if everything else is working in the car maybe someone has had the centre console apart. May be to change the stereo. I would Pop out the mirror control panel and see if it's connected properly there should be two connectors in there if it's a standard panel
I would think that could be the same for the power socket to.
This link might help if you have to start to pull things apart
http://www.mini2.com/forum/faq.php?faq=faq_interior
Hope this helps
#5 ·
Ok I took up the center console and found firstly that the cig lighter had no wires to it ? There are 4 wires there loose 1 pink,1 red, and 2 green one lighter than the other - should they be connected and which one?
There is also a black part connected to the lighter which looks like it should have a bulb or fuse attached ?
The wing mirrors are still not working - fuses are ok checked the washer jet fuse thanks runflat it was ok.
Checked the mirror control panel the 2 connectors seemed ok there.
Ideas?
There was a wire connection beside the engine fuse box not connected to anything but not sure if that is relevant?
#6 ·
Hi ya
From what I can remember you should have a three wires for the socket one is for the light ring there should be one power and one earth from what I can remember.
The two wires for the cig lighter socket should be in a black connector
What the other is for I don't know. I don't have a wiring diagram I front of me at the moment sorry.
Will try to find something over the next few days when I am home
#8 ·
As the wires for the lighter were disconnected anyway I presume I am right in saying that the mirror problem would be unconnected ?
The wires are connected to that and the fuses seem OK - Is there anyway to test the mirror control unit before replacing it , are these a common fault?
