| Tags: news |
| | #161 |
| Mini2 Sponsor & Tuner Join Date: Jun 2005 Local Time: 12:38 AM
Offline | sorry! didn't realise you had to be a member to see them ![]() I will post up some pics here in a minute Manufacturer and Custom Mini Tuning |
| | #162 (permalink) |
Offline | let's try this again ![]() http://www.mini2.com/forum/attachmen...d=1211721 660 http://www.mini2.com/forum/attachmen...d=1211721 956 Manufacturer and Custom Mini Tuning |
| | #163 (permalink) |
| Where's my navigator?! Join Date: Feb 2007 Location: Behind the wheel Local Time: 08:38 AM
Offline | Thanks - much appreciated! NeuroBeaker - Proud owner of "Zeus" (a 'slightly modified' 2004 MINI ONE). *WARNING!* Thesis writing in progress. Experiments continue. Multi-tasking? Explosion imminent! |
| | #164 (permalink) |
Offline | there is some video up of the car now there is a thread about this here http://www.mini2.com/forum/revolutio...ml#post3458109 Manufacturer and Custom Mini Tuning |
| | #165 (permalink) |
| MINI2 Newbie Join Date: Jul 2008 Local Time: 08:38 AM
Offline | Quite an interesting read! I'm very impressed with this level of tuning with the MINI. I can completely understand why you strip your engine down even if it isn't broken, there's just no other way of checking that the physical materials of the internals are sound otherwise. Coming from an Aerospace background there's quite a few methods to go through, but I'll simplify quickly. Phase 1, destructive testing, see what you can do to destroy what you are testing. In the case of current engine development, run an engine beyond 100% thrust for extended periods until it fails. This is very costly and I can't imagine you want to be doing this when you only have 5 or so blocks to be playing with. If the engine gets destroyed to a level you can't ascertain the cause of total failure then you have wasted an engine and gained no results. Phase 2, once you have an idea of what the engine can take before it breaks, you start development up to but not beyond previous development. Once running tests you then disassemble the engine and perform NDT on it to check structural integrity of the material. You're looking for fatigue on a mollecular level here and it's something that NEEDS to be done when you're pushing the envelope. Phase 3, in production testing. Testing the engine once you're happy with your developments in the scenario that it would be used. RMW seems to have done phase 2 and 3, maybe not phase 2 to the level required by Aerospace but it's very commendable that someone is willing to do that. Testing and Development without full knowledge of the continual stresses, not just the initial stresses being applied to the machinery is not the best way to ensure reliability. Theoretical knowledge of how much an engine should take, and phase 3 testing is not enough to ensure a bomb-proof product. |
| | #166 (permalink) |
Offline | it's nice to see someone who appreciates the hard work it takes to make a product that can take the abuse that we subject them to. We have some more interesting things coming for this engine in a supercharged version as I think this is the best for road racing applications. I already have a turbo car with this engine and it is easily the most powerful Mini Cooper ever built. Manufacturer and Custom Mini Tuning |
| | #170 (permalink) |
| MINI2 Senior Join Date: Jul 2007 Location: 7600rpm Local Time: 08:38 AM
Offline | How much would I need to spend to get the stroker taking into account I have your head,440cc injectors etc? ![]() Stock Cooper S @270+BHP 13.7@103.9www.minitorque.com ULTIMATE BMW SHOW 21st Sept 2008- Santa Pod Raceway |
| | #174 (permalink) |
Offline | Head will fit as its only the stroke length that is altered to give the bigger cc ![]() Stock Cooper S @270+BHP 13.7@103.9www.minitorque.com ULTIMATE BMW SHOW 21st Sept 2008- Santa Pod Raceway |
| | #177 (permalink) |
Offline | I thought the head was a direct bolt on. Stock Cooper S @270+BHP 13.7@103.9www.minitorque.com ULTIMATE BMW SHOW 21st Sept 2008- Santa Pod Raceway |
| | #178 (permalink) |
| JCW 210 "apparently" Join Date: Feb 2007 Local Time: 08:38 AM
Offline | After much planning I have decided that I want to have my mini taken to 2.0 though I am bothered by numbers... currently I have a JCW with a JCW head number string, also if I was to change my engine then I have to change my DVLA book to the new number (is this record anywhere) Would it be possible to buy the parts required and hand to a quality UK based mechanic / engine reconditioners so the engine numbers stay the same also, would it be possible to send the current head over for machining and new parts? or would it be more beneficial to strip the engine and ship it to you with the head and end up with an engine externally the same? I just would like to keep the numbers the same as should the car ever in its life go concourse then the head number will be off an S and not JCW. I see this being a good method of tuning without anything visually being changed. I am just running this through so I could make plans of how to go about the conversion. I supppose I would prefure to send the engine over and let you work on it. With the pistons have you used the same material? if not have you looked at the possibility of making them lighter? ie higher grade material but less of it? same with the valves. it would be nice to provide some more torque to the engine. Thanks for your time |
| Anyone have Revolution wheels? | Jazzop | Wheels, Tyres & Brakes | 3 | Apr 23rd, 2007 01:18 AM |
| Stroker / bore kit? | Black_mini_one | MINI Cooper | 5 | Feb 23rd, 2006 08:28 PM |
