| Revolution Mini Works Performance Parts - Custom Tuning |
| How do you lose 4psi of boost and still make big power? Ever wonder how to use less boost and make more hp? We at RMW believe in giving Mini owners a choice in how they go about their power sources. This kit was designed from the ground up to give you the lowest possible IAT's ( inlet air temps) that you can have and still make world record supercharger type power. We designed a kit to work together for this application. We really designed this for the track people who have to run their cars at high rpm and high temps for long periods of time. The dyno sheets below will show you the lower boost on one sheet, logged live the other is horsepower graph comparison from the "normal" way Mini owners make power Heat is the enemy of your engine, big boost isn't necessarily good Notice how much smoother the graphs are with the lower heat ![]() The IAT's were 92degrees F at the end of the dyno pull subsequent testing from 0-90 back to 0-90 and the inlet temps were 107deg F ![]() if you want to scare yourself with your setup.... try this little test and get back to us ![]() Here is what is in the kit: RMW cylinder head RMW Cam RMW Race header/exhaust RMW 440cc inj RMW Pistons RMW Custom ECU tune RMW Water to air Laminova intercooler don't forget the JCW pulley.... ![]() |
| the inlet temps are incredible compared to what we have seen with the other setups sure they work but in the end at the expense of the charger and engine if you notice the smoothness of the graph compared to the higher boosted car Also if you do the repeated low speed to high speed runs the normal setup will just back the intercooler and eventually the car will get hot enough to pull timing and dump fuel |
| Would be interesting to see this set up on a stroker to see some really nice numbers Stock Cooper S @270+BHP 13.7@103.9www.minitorque.com ULTIMATE BMW SHOW 21st Sept 2008- Santa Pod Raceway |
New Here Just asking for advice Hello All, I have an 03 supercharged mini with a few upgrades. I am considering making some final adjustments to reach my goals set ohhh 5 years ago. My question is for the RMW Vendor primarily but if anyone else has some advice I'd be happy to hear. I keep hearing alot of talk about the custom tuning done by JAN. Well unfortunately, I had know idea this man exsisted and went ahead and got a GIAC tune flash for the Cooper. My question is should I upgrade the intercooler, or keep the stock intercooler and have it custom tuned by Jan. Im not out to break any land speed record, but I like most of us would like to get the most bang for the buck. I just really got into the aftermarket world recently and I would appreciate any advice. Thanks again in advance. |
| there is a thread on Northamericanmotoring that address intercoolers. We had tested this quite some time ago and knew that it really wasn't that big of a gain changing the intercoolers in the air to air category. That's why we went water to air to get the most cooling. Better to spend your money on parts that give bigger bang for the buck. Our cam/header combo with the tune will give excellent results. If you want to get to the 240+whp range you will need our big valve cylinder head and big injectors. Feel free to contact me for further info. |
| And so it begins.....Thank you for the reply RMW. 240whp, thats incredible!!! and My wife is gonna kill me . I am gonna have to get back with you after I consider the price for everything cause I feel like a kid in a candy store (cant decide where to begin). |
| Tags: news |
| what make is mini boost | Maui | First Generation Interior & Ice | 7 | Mar 16th, 2007 07:49 PM |
| Does anyone make a boost gauge for the MCS?.nt | toomanycarz | MINI in Motorsport | 2 | May 25th, 2002 09:19 AM |
