Condensation on Inside of Windscreen - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 14th, 2007, 04:19 PM
rec's Avatar
rec
Local Time: 11:02 PM
England Male View rec's Classified Ads
DIY Condensation on Inside of Windscreen
I keep getting condensation on the inside of my windscreen if the car's parked up for a long time (ie over night, or as an example today at Autosport).
any ideas ?
Old Jan 14th, 2007, 04:26 PM
Restyle's Avatar
Damned
Local Time: 12:02 AM
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
More details rqd ..
Does it ever do if parked up inside Garage ?
Does it do it both on wet & dry days / nights ?
Does it happen after AC has been used ?
Has it only just started doing it, or since new ?
Have you got the sunroof ?
Any other glass involved ?
Old Jan 14th, 2007, 04:56 PM
rec's Avatar
rec
Does it ever do if parked up inside Garage ? what's one of those then ?!
Does it do it both on wet & dry days / nights ? well, it was beautiful all day today, still did it parked up. does it when cold.
Does it happen after AC has been used ? i have AC on all the time, but I dont leave the AC on when I'm asleep ;]
Has it only just started doing it, or since new ? only started doing it. seems it happened since BMW replaced one of the metal sills.
Have you got the sunroof ? no
Any other glass involved ? only the windscreen it seems.
it might be attributed to the fact that i've been running the aircon on very hot recently ?
Old Jan 14th, 2007, 05:20 PM
Restyle's Avatar
Damned
I think the AC removes a certain amount of moisture from the circulated air so its unlikely to be that ..
But .. Might be an idea to see if it still does it when you dont use the aircon.
{Personally cant see the point of using AC in the winter, & only used it a couple of times last summer, although people say its best to switch it on at least once a month to prevent things like airlocks in the system}
...seems it happened since BMW replaced one of the metal sills.
The Door step sills? ... If so then I`d be closely looking at the door seal in that area, & might be an idea to get someone to spray a waterhose around that area whilst your in the car. If even a drop enters, then thats the problem.
Old Jan 14th, 2007, 08:28 PM
rec's Avatar
rec
dunno why they'd have to remove a door seal to replace a little metal thing with Cooper on it, but i did notice there were 3 things on the warranty sheet, rather than just 1... :/
will call them tomorrow i think.
Old Jan 15th, 2007, 12:14 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
They may have replaced the whole sill and that would explain the need to remove the rubber.
It was acceptable in the 80's
Old Jan 15th, 2007, 08:38 AM
rec's Avatar
rec
hmmm, that is quite interesting actually. i will have to have a chat :]
Old Jan 15th, 2007, 03:34 PM
United Kingdom Male View Pentagon's Astro Black & Body Color 2nd Gen MINI Cooper S Profile View Pentagon's Classified Ads
Water ingress
my R56 MCS is booked in on wednesday as the condensation/ water inside doesnt go away, I've tried running the AC on max heat with recirc and also went on a two hour drive, neither worked. I think its the windscreen
Old Jan 15th, 2007, 05:23 PM
rec's Avatar
rec
i spoke to someone today and he said that it happens when the aircon is used in cold weather. apparently the pipes cool or something, frost up, and then defrost into a drain pipe. he said this might be blocked and to put hands on carpets to see if there is any dampness.
mine didn't do it this morning, and hasn't done it all day, tho I will check if it's done it tomorrow and update. i'll go for a week and then see if the problem persists, if it does i'll run it into BMW for a day's diagnostics.
Old Jan 15th, 2007, 05:55 PM
Making it add up
United Kingdom Male View Martin F's Laser Blue & Black 2nd Gen MINI Cooper S Profile
The trouble with using Recirculate is that the damp air stays in the car rather than being replaced by drier air from outside. Full heat without recirculate might be better.
Old Jan 15th, 2007, 07:29 PM
rec's Avatar
rec
i dont use recirculate... ever.
Old Jan 16th, 2007, 08:33 PM
Restyle's Avatar
Damned
Rec, Have you seen this post from Paul Mullet concerning, amongst other things, a Water Ingress problem in his R56.
http://www.mini2.com/forum/2nd-gen-f...-my-s-due.html#
Could be related ?
Old Jan 17th, 2007, 09:04 AM
rec's Avatar
rec
ooh, thanks :]
Old Jan 23rd, 2007, 09:42 AM
United Kingdom Male View jasonc's Astro Black & White 2nd Gen MINI Cooper Profile
no problems, as stated below its if you use the A/C during the winter and keep it on, its quite normal so i've been told!
  #15 (permalink)
Old Jan 23rd, 2007, 04:28 PM
Restyle's Avatar
Damned
Quote: Originally Posted by jasonc
....its if you use the A/C during the winter and keep it on, its quite normal so i've been told!
I`m no expert on this, but I cant see how having the AC on in whatever season would lead to excessive condensation on the inside of the car, especially as it one of its functions is to reduce humidity from the air & deposit it to an exterior drain.
See :- How Automotive Air Conditioning Systems Work
Interestingly, that article mentions that one of the symptoms of a faulty AC is excessive water build up inside the car.
I also found a similar fault on the RAC forums >> Ford Focus moisture inside and gauge not working - RAC Motoring Forum
So it seems that far from this condition being "Normal", it is far more likely to be the result of a faulty component or leak
Condensation inside Xenon headlights? BRG/Blk Cooper S First Generation MINI Exterior 13 Nov 18th, 2010 10:08 AM
Condensation inside windows? Crashandburn First Generation Faults & Fixes 35 Jan 27th, 2007 08:21 PM
Condensation inside sunroof fergusor First Generation Faults & Fixes 2 Dec 21st, 2006 08:43 AM
Condensation inside driving lights...a fault? bimini First Generation Faults & Fixes 4 Aug 3rd, 2005 10:29 AM
Condensation on inside of Headlights Fault- Yes or No Gavin1 First Generation Faults & Fixes 12 Oct 4th, 2004 07:26 PM
