MCS Engine noise when cold - Page 156 - MINI Cooper Forum
post #2326 of 2350 (permalink) Old Jan 24th, 2013, 07:55 PM
mooosk
mooosk's Avatar
Local Time: 06:42 PM
... And so the mini misadventure continues .....
MINI bandy about words and phrases such as "cherished" and "TLC" but are quick to disown responsibility for vehicles which, despite being solely Mini-maintained, having the full Mini TLC / XL servicing package and having carefully covered low mileage, FAIL due to a widely acknowledged and experienced manufacturing fault. MINI (UK) vacuously quote "age / mileage" as a reason for declining a goodwill gesture towards compensating a customer fallen victim to this fault; a previously proud owner of a 2007 MCS with 27k on the clock and now facing a £1133.64 bill for the rectification of this manufacturing defect. Mini (UK) don't consider this vehicle as "cherished" in such circumstances ! .... "don't give a toss" might seem a more realistic mini tag line.
Full marks to CooperMiniNorwich however for the professional and courteous attention received (and the loan car goodwill gesture) despite the hindrance of a BMW affiliation that penalises loyal, non-fleet customers with hugely inflated BMW labour charges which used to reflect an inherent superiority of BMW vehicles ...... and so why is it that BMW can not match the generous warranties offered by emerging Far-Eastern rivals? ..... experiences such as mine and countless others hint that MINI(UK) should back up its boasts with ownership of its mistakes.
mooosk is offline
post #2327 of 2350 (permalink) Old Jan 24th, 2013, 10:31 PM
Paul@1320's Avatar
Originally Posted by Zanhar 25 View Post
I haven't got time to read all the 100's of posts on this subject so forgive me if there are any suggestions in this thread.
My wifes car also sounds awful sometimes from cold. Its done this since we've owned it about 18 months. the cars an 07 plate now with 60K miles. Oil level OK and checked every week, which is another issue! On immediate start up you hear a noise as the tensioner takes up play, only lasts for a few seconds but now and again on start up it sounds like a bag of nails for about 5 minuites, now I'm positive this isn't the timing chain, as you still hear the timing chain tensioner take up play initially . The way I would describe the noise is as if there is a lack of oil to the top of the engine, as if the hydraulic lifters aren't adjusting. It sounds similar to back in the day when a cylinder head had been replaced on a Ford XR3 CVH engine and on the first start up theres no oil at the top of the engine. I had an interesting conversation with PMW at Chelmsford have sugeested that the engine probabbly needs a Decoke, which makes sense as the valves could be stuck open with carbon giving valve clearance issues similar to no oil in the lifters, the only downside is they want about £70 to diagnose and if it needs a decoke approx £1400 ouch! I was also quoted this week timing chain replacement at BMW MINI£960
Once warm the engine sounds sweet as a nut, this only appears to happen on colder mornings.
When the better weather arrives, I'm considering carrying out a decoke myself to save on the cost and also change the timing chain, sprockets, tensioner, guides at the same time. Has any one carried this out themselves? Is there any guides on here? I've ordered a TIS disc from Fleabay.
Years ago when I was younger we thought nothing of taking off cylinder heads so can't be a lot different nowadays. The only job I would do is actually decoke the head, this is a shi*t job especially regrinding 16 valves! so I would take it to our local engineering shop who quoted me £125 for this, £10ea for any replacement valves and £15ea for valve guides, still possible of cost of over £500. Is there any tunung companies that supply upgraded / stage cylinder heads for these engines? Also back in the day when Ripspeeds was Ripspeeds (and not Halfords) you could go there and buy any car upgraded cylinder head off the shelf. Looking on line yesterday couldn't find out a lot, does that mean that a standard head is pretty good anyway, I thought I read once that even the R56 JCW upgrade still uses the standard head, unlike the R53 upgrade.
your biggest problem is with the cams. in theory you need special tools to time the cams.......we have the MINI special tools to do this, though I thought there were some copies of these on ebay but I'm not sure on the quality / accuracy.
We did have a local garage who did manage to get there car running when they took the head off and then we just reset the timing on the cams for them.
You could upgrade the cams, we saw a 10hp increase on our R56
1320 R56 MINI Cooper S engine tuning parts for extra bhp, power and torque
Paul@1320 is offline
post #2328 of 2350 (permalink) Old Jan 26th, 2013, 09:15 PM
had the cold rattle issue, with me engine sounding more like a diesel at cold start and low revs.
tried the updated tensioner and still wasntany better. had me mechanic measure the slack on the chain while he was at it and the slack measures at 72mm and bmw max tolerance lvl is 70mm.
posted in another thread the other week but mechanic said the engines are same as peugeot 207 gti and ordwring parts from peugeot would save me 250 pounds. went that route and can rerport back all is good now
he switched everything out, not just chain and rails among a couple of other things he saw wrong while striping it down.
grand total 470 pounds all in if i went bmw parts route over 700 pounds.
let me tell you that if you are getting cold start rattle issue it is most likely chain that has stretched.
if you have the cold start rattle issue and look to save some cash, side step the bmw steelers and go with a mechanic you know or a peugeot specialist as the parts are loadddsssss cheaper to source.
will list parts required if anyone interested.
Hodge007 is offline
post #2329 of 2350 (permalink) Old Feb 17th, 2013, 02:27 PM
Local Time: 07:42 PM
United Kingdom View STU56's Classified Ads
Don't bother, not being funny but I had 3 sets of modified chains and it always came back. A good test is to start up for a short period (taking out of garage) leave an hour and restart. I cured it like a lot of people on this forum I sold it.
STU56 is offline
post #2330 of 2350 (permalink) Old Feb 25th, 2013, 05:08 PM
Making it add up
United Kingdom Male View Martin F's Laser Blue & Black 2nd Gen MINI Cooper S Profile
I thought I should report my recent experience having previously posted much earlier in this thread.
I bought my R56 MCS in November 2006, so one of the first ones. In 2009 it developed the dreaded cold start noise at around 25,000 miles and the dealer replaced the timing chain and guides etc under warranty.
All seemed to be well until recently I had noticed that the noise seemed to be returning.
Last week it went back to the same dealer who had serviced it from new for some new brake pads, an alternator belt etc. The mileage is now 49,000. The dealer kept the car over night and heard the noise on start up in the morning. Initially they thought it was a timing issue but discovered it could not be adjusted as the timing chain had stretched. I agreed to a replacement under protest and ended the week with a very large bill.
However, full credit to Vines, my helpful dealer, they addressed my concerns and agreed with BMW that I would not have to pay for any parts and would only contribute 50% to the labour which they had already discounted by 10%.
Given that my car is over 6 years old I think the result is a very fair one and reflects very well on Vines who took my complaint very seriously.
I know from this thread that others have had very negative experiences so thought that I should report this to redress the balance. I should add that I have no connection with Vines other than as a customer.
Martin F is offline
post #2331 of 2350 (permalink) Old May 22nd, 2013, 11:31 AM
United Kingdom Female
Broken MINI :(
Hi all.
It seems I have the same problem as listed in this very long thread...
I bought my '09 plate Cooper S in 2010 at 7k miles, from Benham MINI in Wolverhampton.
I noticed very early that on cold mornings there was an engine rattle - but it would be gone within a minute. I called my MINI dealer, but because the rattle was so infrequent and gone so quickly, I could never get her in for them to hear it. It became much less frequent and then went away completely for about 2 years.
She has always been serviced and MOT'd at BMW, and has a full service history.
In January this year (now 40k miles) she started 'kicking' when she was cold, so if I put my foot down it would kangaroo rather alarmingly. Again, this would go once the engine was warm. She was due for an MOT, so I asked BMW to look into the issue at the same time, but the lady I spoke with was not very helpful at all, only saying (rather shortly) that 'it's not under warranty - it will be £95/hour to diagnose.' As I was still at University (unfunded) I didn't have that kind of money just to diagnose, so I had to leave it.
I took it to my local garage, who had it for a few days and couldn't diagnose the issue - and said to take it to BMW.
Finally got her back into BMW (with my fingers crossed that it wouldn't be too expensive) and they say the timing chain needs completely replacing at a cost of £850. My local garage were very confused when I told them this - they said that the chain should last the lifetime of the engine/100k miles?
After some research I spoke with a very helpful mechanic at BMW explaining that this seems to be a common issue, and that she was bought from a MINI dealer and has always been serviced at BMW, and asked whether it would be possible for BMW to offer a 'goodwill gesture' - I'm not sure I can afford to get her fixed otherwise.
I'm currently waiting to hear back from BMW.
I was just wondering whether anyone else has managed to get anything from BMW for this issue, and if they have any advice at all?
I decided to buy a MINI as they were BMW made, and should be reliable. I wasn't expecting a potentially dangerous (if it goes completely) fault at 4 years old...
Thanks,
One very sad MINI owner.
Dragonz5745 is offline
post #2332 of 2350 (permalink) Old Jul 26th, 2013, 06:21 PM
I'm Back!
Tracie's Avatar
United Kingdom Female View Tracie's Pepper White & Black 2nd Gen MINI Cooper S Profile View Tracie's Classified Ads
I posted in the early pages of this thread, so a few years back now.
I had the full fix done in October 2010 ( S is a 1.12.08 build)
Not one rattle since and its been left out ( normally garaged) in minus 8 temps, moved a short distance and restarted..I've done all the things to re create the rattle since the fix and I have to say I've not heard it once.
R56 MCS & CMS..lovin both MINI's
Tracie is offline
post #2333 of 2350 (permalink) Old Aug 4th, 2013, 09:43 PM
zyo
owt else is just traffic
zyo's Avatar
I think its quite interesting that all the different dealers people are using seem to be giving out different prices for rectifying the same problem, my dealer quoted about £700/750 for the cam chain and tensioner kit fitted but when I asked about the decoke aswell that raised to £1750...eek
zyo is offline
post #2334 of 2350 (permalink) Old Aug 4th, 2013, 10:53 PM
Zanhar25
We had our timing chain, guides, tensioner, sprocket changed last week by Minitech in Raleigh, Essex, using the latest Genuine MINI parts. We now have no more rattling, or sounding like a diesel, Yippee!!
I was shown the old timing chain which was badly worn, two of the guides were actually broken and the tensioner was weak, it wouldn't of been long before we would of had a catastrophic failure!
Mileage of our MCS is 64K
Zanhar 25 is offline
post #2335 of 2350 (permalink) Old Aug 4th, 2013, 11:00 PM
Zanhar25
Forgot to mention that Minitech advised and carried out Seafoam treatment on our MCS as a first stage instead of having to carry out proper decoke, seems to of worked. they also carried out PCV delete so hopefully wont use as much oil and coke up the head. At the moment our MCS is running better than it ever has since we've owned it!
Check out Minitech , Raleigh, Essex website.
post #2336 of 2350 (permalink) Old Aug 11th, 2013, 06:02 PM
I have a similar problem myself on my 53 plate MCS, exhibiting the 3,000-3,500 rpm noise on a different thread, I've managed to find a YouTube vid that shows the same noise.
http://www.mini2.com/forum/first-gen...ml#post3861130
I'd like to know your view on it as earlier posts on this thread relate to it
petebarchetta is offline
post #2337 of 2350 (permalink) Old Sep 3rd, 2013, 03:36 PM
Quoted: 1 Post(s)
Hi,
I'm nearly buying a used 2008 MCS R55.
I'm afraid this issue could be on the car, and I can't detect it.
There's no strange noise, but it was no way near a cold day
Any advices how to detect if this Timing Chain issue is there?
I also doubt a cheap general checkup (50€) at a local mini dealer will find this issue.
PS:The owner said to keep an eye on the oil, because sometimes he had to add a bit more now and then, not sure if its a sign for future problems.
burtzz is offline
post #2338 of 2350 (permalink) Old Sep 3rd, 2013, 07:16 PM
Zanhar25
Hi I'm sorry I can't advise as my MCS is a 2007 turbo engine and yours is a first generation MCS with a different Supercharged engine so I wouldn't know what a faulty timing chain would sound like in your engine.
post #2339 of 2350 (permalink) Old Oct 8th, 2013, 11:58 AM
C1NTT's Avatar
United Kingdom Male View C1NTT's Dark Silver & Body Color 2nd Gen MINI John Cooper Works Profile
I had the timing chain tensioner, guides and an oil change done by Walkers Autotech a few months back for £650. Problem now seems to have completely gone away.
MINI Cooper S JCW
Dark Silver, Recaro Alcantara Seats, Nav, Xenons, Rooster Red Trim, Tints, Black Grille, MINI Bluetooth Retrofit, oh - and a 'small' HiFi upgrade in progress...
C1NTT is offline
post #2340 of 2350 (permalink) Old Jan 31st, 2014, 06:43 PM
I'm Back!
Tracie's Avatar
Just though I would add to this... I had the full fix done in October 2010, no issues since..however twice this week the rattle has come back, first time the oil was quite low. took a litre to top up...slight rattle a few days later....what will I do I hear you say....
It will be part ex for something other than MINI this year I'm afraid my MINI days are well and truly over...shame cause the car is FAB to drive.
Tracie is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mcs-engine-noise-when-cold.html
Posted By For Type Date
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 30th, 2009 11:40 PM
Rattling engine from cold- 08 MCS This thread Refback Mar 29th, 2009 07:29 PM
MINI2.com - MINI Forum This thread Refback Mar 24th, 2009 03:46 PM
My Community This thread Refback Mar 21st, 2009 07:35 PM
MINI Car Club of Indiana Forum - Search Results This thread Refback Mar 19th, 2009 11:45 AM
VANOS Oil Pressure Accumulator This thread Refback Mar 18th, 2009 11:24 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 09:09 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 08:27 PM
Mini (new bmw versions) Singletrackworld This thread Refback Mar 17th, 2009 02:59 PM
MINI COOPER :: North American Motoring - Clubman S cold engine valve noise This thread Refback Mar 15th, 2009 03:07 AM
MINI COOPER :: North American Motoring - Engine Knock During Cold Start This thread Refback Mar 15th, 2009 02:38 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Mar 2nd, 2009 07:24 PM
Untitled document This thread Refback Mar 2nd, 2009 07:28 AM
VANOS Oil Pressure Accumulator This thread Refback Feb 28th, 2009 09:26 PM
R56 Mini Cooper S - This thread Refback Feb 27th, 2009 04:20 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 22nd, 2009 08:17 AM
COLD START NOISE This thread Refback Feb 21st, 2009 04:15 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:29 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:21 PM
COLD START NOISE This thread Refback Feb 21st, 2009 01:23 PM
COLD START NOISE This thread Refback Feb 21st, 2009 12:59 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 21st, 2009 10:31 AM
COLD START NOISE This thread Refback Feb 21st, 2009 02:00 AM
Untitled document This thread Refback Feb 20th, 2009 10:45 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 19th, 2009 01:51 PM
R56 Mini Cooper S This thread Refback Feb 19th, 2009 11:26 AM
Untitled document This thread Refback Feb 19th, 2009 08:27 AM
Untitled document This thread Refback Feb 19th, 2009 07:41 AM
Untitled document This thread Refback Feb 19th, 2009 07:09 AM
Engine of the year award This thread Refback Feb 18th, 2009 02:23 PM
MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head This thread Refback Feb 16th, 2009 06:38 PM
One broken Mini! This thread Refback Feb 16th, 2009 11:10 AM
COLD START NOISE This thread Refback Feb 15th, 2009 11:57 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 13th, 2009 10:23 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 11th, 2009 03:37 PM
Winter Rattles.. This thread Refback Feb 7th, 2009 09:40 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 6th, 2009 12:47 PM
Engine of the year award This thread Refback Jan 31st, 2009 10:32 PM
Astle have a fix ???? This thread Refback Jan 29th, 2009 07:19 PM
Fault Register This thread Refback Jan 29th, 2009 12:32 PM
Engine of the year award This thread Refback Jan 29th, 2009 09:03 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 28th, 2009 09:50 PM
Example of noisy start This thread Refback Jan 24th, 2009 03:55 PM
MINI COOPER :: North American Motoring - Cold Start Issues Database This thread Refback Jan 22nd, 2009 01:01 PM
MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles This thread Refback Jan 19th, 2009 12:57 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 16th, 2009 01:25 AM
Untitled document This thread Refback Jan 13th, 2009 03:14 PM
Untitled document This thread Refback Jan 13th, 2009 01:23 PM
Untitled document This thread Refback Jan 13th, 2009 01:21 PM
General Chit Chatter (Sorry!) This thread Refback Jan 11th, 2009 10:52 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
2005 Cooper S Squealing Noise Independent of Engine Speed uilleann-piper First Generation MINI Cooper S 1 Sep 24th, 2013 09:18 PM
sound on cold 2010 MCS engine clusty Maintenance & MINI Care 0 Sep 4th, 2013 01:39 AM
strange noise when starting up mini cold asantaga MINI Cooper Diesel 3 Mar 18th, 2013 02:15 PM
NEED HELP 2008 Mini R56 BAD Engine noise 160k kentuckynet Second Generation MINI Cooper 4 Feb 4th, 2013 11:22 PM
Can cold air intakes damage the engine? tarayislandgirl General Discussion 3 Aug 18th, 2012 10:28 AM
