| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (91) | Thread Tools | Rate Thread |
| Having read this forum I was dreading getting the cold start noise problem sorted out. I booked the car in to our local dealer for two days, they provided a loan car and they carried out the work with no problems even though the car only made the noise occasionally. I think this problem is been blown out of all proportion now that BMW will carry out checks and if required the modification to customers cars that report the noise |
| The engine rattle on my June 07 build MCS appeared during October 07. We had building work being done and the garage was full so I had to park on the slope. The noise happened then and only then, never anywhere else. I discussed it with the Dealer and they were not at all helpful. I found the rattle could be stopped by turning off the engine and restarting, so I was not unduly concerned. I did write to Mini Customer services and they were helpful. In May 09 I decided to contact the Dealer and they had the car back and kept it overnight. Next day they rang and said a new tensioner had been fitted and it was OK. Touch wood it's been fine since and and pulls much better at low speeds. I think BMW have worked hard to solve the problem, but some of the Dealers are not very helpful. My advice would be to anyone who has the rattle, to contact another Dealer in the area. BMW pay them for fixing the rattle so they make money by doing the job. |
| I completely agree as I've said before. My R56 MCS suffered from the noise quite badly before its final fix around May 2009 (three times a day or so). It's now covered 45,000 miles and there's no sign of premature engine wear. I'm not aware of a single case of engine failure confirmed to be connected with this problem. As annoying as it is, it only appears to be a noise. |
| I have to disagree because as in our case there was significant engine wear which caused engine failure. Although we have had all the available fixes none has helped and we had an engine failure resulting in receiving a new engine. So I do believe that damage can be caused or is caused prior to the cars first fixes or even beyond if the fixes don't help. We are thankful to our dealer who decided to sort it out themselves although they would not confirm or tell what they had encountered. |
| I'm sorry to hear of your problems. A large majority of R56 MCS engines have the problem, and with any mass produced engine there will be a number of isolated engine failures. It doesn't surprise me that there are engine failures, where owners had experienced the noise. This doesn't automatically imply, however, that the source behind the noise is the cause, and engine failure was the effect. Was the engine independently inspected, e.g., the engine failure was completely attributed to the cold start problem, and not another manufacturing defect? It might be I have to eat my hat....... |
| Tend to agree with Lawrothegreat on this, "***'s law" means there will always be a chance of something going wrong. With era of mass production this will occur. I don't think the rattle alone causes engine damage, the cause could be attributed to the driving habits of the owner. |
| Dear Lawrothegreat and Caesar, I do understand you guys that these things could happen with mass production. It's also clear that the last fix has helped many owners. In our case the car went in and received repeatedly official fixes + relevant services without any permanent result this year. When the rattle suddenly became permanent I brought the car to the dealer who then dismantled the engine as far as the warranty aloud them to. I understood that their findings where briefed to MINI but they could not tell my any details other then that the engine had sufficient wear out in order to be replaced but the most important part that it was not driver related, according to the dealer. Keeping this in mind I believe that something was/went wrong as we were helped a year after the first complaints. I also do hope that I and all other MINI colleagues stay trouble free as these are costly repairs. Last edited by movit; Oct 23rd, 2009 at 09:35 PM. Reason: spelling factors |
| Hi moveit, I wasn't suggesting in your case it would be driver related. I see from your previous posts, your engine has been fixed on three occasions. Is it not possible that the dealer could have previously dismantled your engine, reassembling it in an incompetent fashion, enough for it to lead to premature engine failure? Maybe they told you it was related to the cold noise. Sorry, but I'm just not convinced on this one. When I had the noise really bad (three times a day) it sounded as though the engine was literally going to blow. After the last fix, and 10,000 miles later you would expect my engine to be on its last legs. In fact it's quieter and smoother than ever. Again, as I've previously said I have yet to see any real evidence (an independent inspection of some form) that the cause behind the noise can lead to engine failure. As I've previously said I might need to eat my hat on this one, but, I'm just not willing to assume the worst because it's leaving too many owners with concern and worry when it could be unnecessary. |
| Ladies and gentlemen, I give you the Honda V-tec engine, I'm advised there has never been a failure yet. We obviously have the wrong engines fitted in our MCSs. ![]() On a more serious note, and again this is second hand knowledge so don't shoot me, I was told that there have been no timing chain failures in R56 MINIs other than in MCS models. Given that the noise has been isolated to this area, I think it may not be sheer coincidence. A couple of cars that have had the latest and greatest fix still have a cold start rattle of sorts though it has been reduced to a run time of under 5 secs and I for one am not concerned anymore. However , there are still 'cherished' MCSs being re-sold with the rattle- not really acceptable, all MCSs should be checked to allay any fears and restore some confidence in the model. If it gets a bad rep it may affect our residuals down the line then, no doubt, we will be a bit less complacent about the issue. |
| That's not strictly true, I had a Civic Type-R prior to buying an MCS. I was a member of the Type-R Forum and there were cases where an engine developed faults. There were also cases of excessive oil consumption. Another problem was if you started it up from cold, and moved it a few yards say for cleaning....and started it up after you had finished, the engine ran rough for a while. To stop this happening I used to drive it around the block till it was warm, and then clean it. This was my only complaint apart from the fact it drank petrol like an alcoholic! |
| I had a EP3 CTR from new 2002 to 2004 and didnt have any of those problems, dont recall ever reading about the running rough issue either, it could use some oil (the VTEC system needed enough oil in the system for it to work). MPG wasnt to bad, around 30mpg usually on a mixed drive. When talking of failures they are talking about the VTEC system IIRC, not the engine as a whole. ..:: Cheers Stu ::.. ![]() |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html | ||||
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 30th, 2009 11:40 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Mar 29th, 2009 07:29 PM | |
| MINI2.com - MINI Forum | This thread | Refback | Mar 24th, 2009 03:46 PM | |
| My Community | This thread | Refback | Mar 21st, 2009 07:35 PM | |
| MINI Car Club of Indiana Forum - Search Results | This thread | Refback | Mar 19th, 2009 11:45 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Mar 18th, 2009 11:24 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 09:09 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 08:27 PM | |
| Mini (new bmw versions) Singletrackworld | This thread | Refback | Mar 17th, 2009 02:59 PM | |
| MINI COOPER :: North American Motoring - Clubman S cold engine valve noise | This thread | Refback | Mar 15th, 2009 03:07 AM | |
| MINI COOPER :: North American Motoring - Engine Knock During Cold Start | This thread | Refback | Mar 15th, 2009 02:38 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Mar 2nd, 2009 07:24 PM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Mar 2nd, 2009 07:28 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Feb 28th, 2009 09:26 PM | |
| R56 Mini Cooper S - | This thread | Refback | Feb 27th, 2009 04:20 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 22nd, 2009 08:17 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 04:15 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:29 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:21 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 01:23 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 12:59 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 21st, 2009 10:31 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 02:00 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 20th, 2009 10:45 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 19th, 2009 01:51 PM | |
| R56 Mini Cooper S | This thread | Refback | Feb 19th, 2009 11:26 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 08:27 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:41 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:09 AM | |
| Engine of the year award | This thread | Refback | Feb 18th, 2009 02:23 PM | |
| MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head | This thread | Refback | Feb 16th, 2009 06:38 PM | |
| One broken Mini! | This thread | Refback | Feb 16th, 2009 11:10 AM | |
| COLD START NOISE | This thread | Refback | Feb 15th, 2009 11:57 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 13th, 2009 10:23 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 11th, 2009 03:37 PM | |
| Winter Rattles.. | This thread | Refback | Feb 7th, 2009 09:40 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 6th, 2009 12:47 PM | |
| Engine of the year award | This thread | Refback | Jan 31st, 2009 10:32 PM | |
| Astle have a fix ???? | This thread | Refback | Jan 29th, 2009 07:19 PM | |
| Fault Register | This thread | Refback | Jan 29th, 2009 12:32 PM | |
| Engine of the year award | This thread | Refback | Jan 29th, 2009 09:03 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 28th, 2009 09:50 PM | |
| Example of noisy start | This thread | Refback | Jan 24th, 2009 03:55 PM | |
| MINI COOPER :: North American Motoring - Cold Start Issues Database | This thread | Refback | Jan 22nd, 2009 01:01 PM | |
| MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles | This thread | Refback | Jan 19th, 2009 12:57 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 16th, 2009 01:25 AM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 03:14 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:23 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:21 PM | |
| General Chit Chatter (Sorry!) | This thread | Refback | Jan 11th, 2009 10:52 AM | |
| Peugeot207Club | This thread | Refback | Jan 8th, 2009 01:10 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 8th, 2009 07:53 AM | |
| MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? | This thread | Refback | Jan 8th, 2009 03:12 AM | |
| R56 Mini Cooper S | This thread | Refback | Jan 7th, 2009 12:53 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Jan 6th, 2009 09:47 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 09:07 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 06:36 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 6th, 2009 02:07 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 07:22 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 06:16 PM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 5th, 2009 12:49 PM | |
| MotoringFile Archive R56 Cold Start Official Fix Coming | This thread | Refback | Jan 2nd, 2009 07:20 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 30th, 2008 09:35 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 29th, 2008 01:51 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 28th, 2008 03:35 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 25th, 2008 11:24 PM | |
| Fault Register | This thread | Refback | Dec 20th, 2008 07:19 PM | |
| Winter Rattles.. | This thread | Refback | Dec 20th, 2008 04:44 AM | |
| MINI COOPER :: North American Motoring - Engine Rattle After Sitting | This thread | Refback | Dec 18th, 2008 02:21 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Dec 13th, 2008 06:20 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Dec 12th, 2008 07:08 PM | |
| R56 Mini Cooper S | This thread | Refback | Dec 11th, 2008 10:18 PM | |
| Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) | This thread | Refback | Dec 4th, 2008 08:38 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 05:45 PM | |
| MINI COOPER :: North American Motoring - Cold Start Chatter | This thread | Refback | Dec 4th, 2008 12:10 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 11:00 AM | |
| engine noise when cold | This thread | Refback | Dec 2nd, 2008 08:32 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Dec 1st, 2008 10:11 AM | |
| Astle have a fix ???? | This thread | Refback | Nov 30th, 2008 08:02 PM | |
| engine noise when cold | This thread | Refback | Nov 29th, 2008 01:09 AM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 04:35 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:51 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:07 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:30 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:08 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:56 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:49 PM | |
| R56 Mini Cooper S | This thread | Refback | Nov 28th, 2008 03:12 AM | |
| Dealer Experience | This thread | Refback | Nov 23rd, 2008 04:34 PM | |
| Winter Rattles.. | This thread | Refback | Nov 19th, 2008 09:58 PM | |
| Winter Rattles.. | This thread | Refback | Nov 14th, 2008 06:37 AM | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Rattling noise when engine cold | berty | Second Generation Faults & Fixes | 14 | Feb 17th, 2008 06:05 PM |
| Engine noise when cold | Pglenning | First Generation Faults & Fixes | 7 | Feb 23rd, 2007 06:10 PM |
| Knocking noise from engine on MCS | DurhamFox | First Generation Faults & Fixes | 1 | Nov 16th, 2005 08:39 PM |
| Help Funny noise from ENGINE of MCS | BRGNICK | First Generation MINI Tuning | 4 | Jun 29th, 2005 01:23 PM |
| Please help me identify another MCS engine noise. | tenderidol | First Generation Faults & Fixes | 12 | Nov 10th, 2004 08:07 AM |
