| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (91) | Thread Tools | Rate Thread |
| A "Characteristic"? That's "Bollox"! You just need the latest longer (10mm) hydraulic timing chain tensioner piston, the longer piston pushes the chain out further stopping it rattling and keeping the timing 100% spot on. If your dealer won't replace your dodgy timing chain tensioner under warranty, you can do it yourself in about an hour. You need a 17mm spanner and this part... Timing Chain Tensioner (December 2009 on) - R56 at minigenuineparts.co.uk Mini Genuine Parts Mini Servicing Parts & Spares, BM11.31.7.607.551, This is the latest replacement timing chain tensioner fitted from December 2009 to get rid of t The last three digits of the BMW part number is 551. We had a two year battle with our dealer over the dodgy tensioner piston, until they fitted the latest longer one in July this year and since then we've had no rattles etc and the engine has been great. That is until about a week ago when the engine started pinking under load, but I think I may have cured it with a can of BG44K in the fuel tank? Results to be posted soon. P. |
| Hi, I assume we are talking about the cold start rattle that disappears a minute or so after start up? What dealer are you using? This is total nonsense as there is plenty documentation regarding this FAULT. Did the dealer say that MINI said this or have you been in contact with MINI? If this is a characteristic, ask MINI why they have issued several "PUMA" instructions to dealers on how to fix it? Here is a perfect example: MotoringFile Archive MINI Solves R55/R56/R57 MCS Cold Start Problem (Again) Good Luck, KenL |
| well dont try Coopers in Ipswich, never understand how garages in the same group can behave so differently, but i explained the noise I was getting to them and was treated to a "whats that, never heard of that problem" till I started quoting the MINI advisory numbers and suddenly it was like "oh you mean THAT cold start rattle noise" so they have the car for a whole day to carry out a service and report back to me nothing found, couldnt hear it, all with a you must be making it up or cars are meant to be noisy kind of attitude, but I couldnt pick up the car that night so left it overnight with them next morning go down to collect the car, as Id been told the previous day it had been ready to collect, they just needed to clean it, only to be told overnight they had decided they needed to strip all the engine timing bits down to take a bundle of measurements to feed back to MINI UK and then push it through a 3hr test cycle just to make absolutely certain they couldnt find the problem that the previous whole day they had the car they'd said couldnt be found so Ive no idea what they are doing to the car now, as Ive not heard anyone else had theirs subjected to a 3hr test cycle for this, why they had this sudden change of heart overnight, or even if they intend fixing anything as they keep telling me its all just to make sure it doesnt have the problem, not that they are looking to fix anything you'd have thought this was a simple problem for dealers to handle, was the car built during the right timeframe, has it had the replacement parts fitted, is the customer complaining about it. whereas what seems to happen is deny the problem exists unless the customer pushes hard to get it noticed, and then they set about assessing the minimum amount of work required to simply patch it up and hope the customer then forgets about it. stonojnr |
| It's called "plausible denial". If you say "no" for long enough and loud enough, people will start to believe you! Put yourself in Mini's position, they're trying to sell a product with a first rate price tag, but a third rate build quality. It's like spraying over rust, eventually the rust will appear. Same with the N14 engine, now that some of the engines are over three years old and have done more than 30k miles, problems due to poor design are starting to appear, such as the premature coking up of the cylinder heads. I wonder how many sales Mini have lost after potential buyers have read on-line about the problems with the timing chain and overall crap build quality of the 2nd generation Mini's? P. |
| they should be in this thread somewhere, thats where I got mine from but use a combination of PuMA 10686850-13 or modified tensioner part# 11.31.7.598.956, they do know about it, they just need to feel that you know enough about it I think.fwiw mines been changed now to the modified tensioner, but I couldnt get out of them what else they did whether they included the guides and sprockets or anything else as well, and frankly it still sounds a touch rattly, and felt a bit flat too, but will have to see how it progresses stonojnr |
| i had mine changed at cooper ipswich it was fine all summer but now its starting to rattle again. So it should be interesting what they say this time. Since i got the car in feb its been a total disaster. They just changed all the valves and done all the de coking that they denied there had ever been a problem until i proved it to them. im wondering if the colchester branch is any better i may in there instead |
| Well today I dropped mines off again with Peter Vardy Seafield, and asked to see a technician so I could playback the recorded rattle. He says it's either the tensioner or vacuum pump which has been known to cause a similar sound. And low and behold when I get a call from the Senior Workshop manager, he asks ' can we keep you car so we can strip it down and check the parts we've replaced are the updated parts. We've also got newer versions released so just to be sure what is causing the fault' hmm |
| My car has also been into the garage you mention. All they did was replace the tensioner. The rattle has occurred again (but a lot quieter). I've got a video clip and am about to send that it in to them. Please could you get a detailed breakdown of what they have done to your's when you get it back? Thanks, KenL |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html | ||||
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 30th, 2009 11:40 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Mar 29th, 2009 07:29 PM | |
| MINI2.com - MINI Forum | This thread | Refback | Mar 24th, 2009 03:46 PM | |
| My Community | This thread | Refback | Mar 21st, 2009 07:35 PM | |
| MINI Car Club of Indiana Forum - Search Results | This thread | Refback | Mar 19th, 2009 11:45 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Mar 18th, 2009 11:24 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 09:09 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 08:27 PM | |
| Mini (new bmw versions) Singletrackworld | This thread | Refback | Mar 17th, 2009 02:59 PM | |
| MINI COOPER :: North American Motoring - Clubman S cold engine valve noise | This thread | Refback | Mar 15th, 2009 03:07 AM | |
| MINI COOPER :: North American Motoring - Engine Knock During Cold Start | This thread | Refback | Mar 15th, 2009 02:38 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Mar 2nd, 2009 07:24 PM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Mar 2nd, 2009 07:28 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Feb 28th, 2009 09:26 PM | |
| R56 Mini Cooper S - | This thread | Refback | Feb 27th, 2009 04:20 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 22nd, 2009 08:17 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 04:15 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:29 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:21 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 01:23 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 12:59 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 21st, 2009 10:31 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 02:00 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 20th, 2009 10:45 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 19th, 2009 01:51 PM | |
| R56 Mini Cooper S | This thread | Refback | Feb 19th, 2009 11:26 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 08:27 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:41 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:09 AM | |
| Engine of the year award | This thread | Refback | Feb 18th, 2009 02:23 PM | |
| MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head | This thread | Refback | Feb 16th, 2009 06:38 PM | |
| One broken Mini! | This thread | Refback | Feb 16th, 2009 11:10 AM | |
| COLD START NOISE | This thread | Refback | Feb 15th, 2009 11:57 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 13th, 2009 10:23 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 11th, 2009 03:37 PM | |
| Winter Rattles.. | This thread | Refback | Feb 7th, 2009 09:40 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 6th, 2009 12:47 PM | |
| Engine of the year award | This thread | Refback | Jan 31st, 2009 10:32 PM | |
| Astle have a fix ???? | This thread | Refback | Jan 29th, 2009 07:19 PM | |
| Fault Register | This thread | Refback | Jan 29th, 2009 12:32 PM | |
| Engine of the year award | This thread | Refback | Jan 29th, 2009 09:03 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 28th, 2009 09:50 PM | |
| Example of noisy start | This thread | Refback | Jan 24th, 2009 03:55 PM | |
| MINI COOPER :: North American Motoring - Cold Start Issues Database | This thread | Refback | Jan 22nd, 2009 01:01 PM | |
| MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles | This thread | Refback | Jan 19th, 2009 12:57 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 16th, 2009 01:25 AM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 03:14 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:23 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:21 PM | |
| General Chit Chatter (Sorry!) | This thread | Refback | Jan 11th, 2009 10:52 AM | |
| Peugeot207Club | This thread | Refback | Jan 8th, 2009 01:10 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 8th, 2009 07:53 AM | |
| MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? | This thread | Refback | Jan 8th, 2009 03:12 AM | |
| R56 Mini Cooper S | This thread | Refback | Jan 7th, 2009 12:53 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Jan 6th, 2009 09:47 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 09:07 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 06:36 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 6th, 2009 02:07 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 07:22 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 06:16 PM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 5th, 2009 12:49 PM | |
| MotoringFile Archive R56 Cold Start Official Fix Coming | This thread | Refback | Jan 2nd, 2009 07:20 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 30th, 2008 09:35 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 29th, 2008 01:51 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 28th, 2008 03:35 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 25th, 2008 11:24 PM | |
| Fault Register | This thread | Refback | Dec 20th, 2008 07:19 PM | |
| Winter Rattles.. | This thread | Refback | Dec 20th, 2008 04:44 AM | |
| MINI COOPER :: North American Motoring - Engine Rattle After Sitting | This thread | Refback | Dec 18th, 2008 02:21 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Dec 13th, 2008 06:20 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Dec 12th, 2008 07:08 PM | |
| R56 Mini Cooper S | This thread | Refback | Dec 11th, 2008 10:18 PM | |
| Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) | This thread | Refback | Dec 4th, 2008 08:38 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 05:45 PM | |
| MINI COOPER :: North American Motoring - Cold Start Chatter | This thread | Refback | Dec 4th, 2008 12:10 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 11:00 AM | |
| engine noise when cold | This thread | Refback | Dec 2nd, 2008 08:32 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Dec 1st, 2008 10:11 AM | |
| Astle have a fix ???? | This thread | Refback | Nov 30th, 2008 08:02 PM | |
| engine noise when cold | This thread | Refback | Nov 29th, 2008 01:09 AM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 04:35 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:51 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:07 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:30 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:08 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:56 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:49 PM | |
| R56 Mini Cooper S | This thread | Refback | Nov 28th, 2008 03:12 AM | |
| Dealer Experience | This thread | Refback | Nov 23rd, 2008 04:34 PM | |
| Winter Rattles.. | This thread | Refback | Nov 19th, 2008 09:58 PM | |
| Winter Rattles.. | This thread | Refback | Nov 14th, 2008 06:37 AM | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Rattling noise when engine cold | berty | Second Generation Faults & Fixes | 14 | Feb 17th, 2008 06:05 PM |
| Engine noise when cold | Pglenning | First Generation Faults & Fixes | 7 | Feb 23rd, 2007 06:10 PM |
| Knocking noise from engine on MCS | DurhamFox | First Generation Faults & Fixes | 1 | Nov 16th, 2005 08:39 PM |
| Help Funny noise from ENGINE of MCS | BRGNICK | First Generation MINI Tuning | 4 | Jun 29th, 2005 01:23 PM |
| Please help me identify another MCS engine noise. | tenderidol | First Generation Faults & Fixes | 12 | Nov 10th, 2004 08:07 AM |
