| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (91) | Thread Tools | Rate Thread |
| I know exactly what you mean. I've had the cam chain tensioner replaced so far. The raucous rattle returned once... ever-so briefly (about 15-20 seconds). My heart pretty much sank. I LOVE-LOVE-LOVE the car on the whole. The JCW engine kit rocks! I think I've just come to the conclusion that I will fix what comes up through the warranty period... pray a long-term fix developes during that time... and failing that, keep the option open for a JCW Stage III (or whatever it's called at that time) in 2012. ![]() Founding member of R56 Anonymous: "Hello. My name is Mike. I'm a driving enthusiast... and I still like the R56" |
| Well finally someone with the same problem. My car also makes that strange noise. My dealer doesn't know what it is, or what to do. Also they have to hear the noise live, so a video didn't do it for them. I made 2 video's from my Cooper S after he already warms up for 5 minutes: 1. 2. My car is a January 30th and it makes this noise for a few months. Not every time when I start it, but mainly when it is raining or has rained. Very strange! It is scary to drive away. I hope they can solve it quickly! Let's burn some serious rubber! 2007 MINI Cooper S (Lightning Blue), what a great little car! |
| OMG! Turn it off! Ouch! ![]() Yes that's EXACTLY what mine sounded like and it turned out to be the tensioner (no oil in the piston). It was replaced under warranty. Noise popped up again, though (once, ever-so briefly). So I fear the tesniner failure might be a symptom of another problem in the oil circut itself. ![]() Founding member of R56 Anonymous: "Hello. My name is Mike. I'm a driving enthusiast... and I still like the R56" |
| Well the problem is cured!! 1st Visit te deale replaced the cm tensioner. THIS DIDNOT CURE THE PROBLEM, 2nd Visit my car had to the dealer, BMW advised to replace the hydraulic lifters. THIS HAS CURED THE PROBLEM!!!! Replacing the hydraulic lifters has certainly cured the rattle tapping noise on start up which indicates either a bad batch of hydraulic lifters or they are quite simply wearing out most likely due to material quality. I cover 600miles per week so as soon as the noise comes back it will be back at the dealer. I feel that this problem is getting closer to being resolved for other Mini owners. |
| [quote=Deanliv;3223889]Well the problem is cured!! 1st Visit te deale replaced the cm tensioner. THIS DIDNOT CURE THE PROBLEM, 2nd Visit my car had to the dealer, BMW advised to replace the hydraulic lifters. THIS HAS CURED THE PROBLEM!!!! Replacing the hydraulic lifters has certainly cured the rattle tapping noise on start up which indicates either a bad batch of hydraulic lifters or they are quite simply wearing out most likely due to material quality. I cover 600miles per week so as soon as the noise comes back it will be back at the dealer. I feel that this problem is getting closer to being resolved for other Mini owners.[/QUOTE) Glad you've got it sorted. Not the best situation to be in. Word of warning though...... new lifters did JACK on my car !!!!! Hope, like you say "Bad batch" is or was the problem. All WORKED up. |
| Keeping my fingers crossed. Doing the cam-chain tensioner has worked for me, at least tempararily. I'll suggest lifters to my dealer if the problem returns with any frequency. I just pray they get it sorted once-and-for-all within the warranty period. It's such an awsome car otherwise... ![]() Founding member of R56 Anonymous: "Hello. My name is Mike. I'm a driving enthusiast... and I still like the R56" |
| My car made a similar noise this morning, but not right away at start up. I hadn't driven since last Thursday, and the temperature in the garage was around 3 celsius this morning (barely above freezing). I started it up, and it sounded normal at idle. Backing down the driveway it sounded normal, but pulling away as the engine hit about 2000 rpm, it became very loud and noisy. Keeping it at very low revs it sounded fine, but again in second gear it became loud as it hit 2000rpm. I have had quite a few mornings so far with similar temperatures and not had any issues, but the weather has been getting colder, and will hit much colder temperatures regularly as we head into winter. I'm not sure if I should be overly concerned yet; my previous vehicle (a 2002 Toyota Corolla purchased new and owned for six years) used to get a little loud when it was cold (though not quite as loud, and at slightly higher engine speeds). It didn't even have to be this cold and it would become noisy around 2500rpm until the engine warmed up, and then it would go away. Apart from that issue, my Corolla was completely problem free for just over six years. Tomorrow I will let the Mini warm up for a bit before starting to drive and I'll see if I have any unusual noise, but the weather is actually due to warm up several degrees over the next few days, so I may not have an issue regardless. |
| Bishamon.......Had exactly the same problem with my July 07 MCS when I parked on the driveway overnight, instead of in the garage (see my earlier threads on this topic). The driveway slopes down towards the garage at an angle of approx 30 degrees. To stop it occuring I let the engine tick over for 2-3 minutes, then gently reverse up the slope. I suggest you try this, and also check the engine oil level as per the Owners Handbook. |
| hello all I have an April 2007 MCS and over the past two months numerous problems have occured, the two main ones being the gearbox/clutch grinding problem and the tractor type noise during cold starts form the engine. A month ago i took it to the dealer (Elms MINI Cambridge) and they changed the timing chain tensioner as per PUMA recommendation. This seemed to solve the problem for a couple of weeks (although there was still a faint knocking when cold) but unfourtunatley the sound has returned. In my experience it has occured when the car has been standing outside on the drive instead of the garage coupled with cold and damp/wet conditions. Now I'm wondering what to do. Could it be that the tensioner has started to fail again. I'm not so sure that this is problem and it is kind of weird that it occurs only when wet. The vibration as stated in earlier replies to this thread occurs at the 2k rpm level. Could it be heatshield related? Looks like I am going to have to book her in again for a another few days which is great. I really love all the time i have to spend trying to get these problems sorted NOT. I am definatley going to remember to mention the lifters as possible problem as stated earlier in this thread. So far after the first vist for three days to Elms MINI Cambridge three weeks ago:
I then had to book her in again because the wind screen was not fittled correctly. Got her back and noticed that the roof rainfall rubber above rthe drivers rear quarter were all pushed in from replacing the windscreen. Then over the past week the dash has developed a nasty rattle post windcreen replacement. The car is now due in on the 27th next week to get the rubbers and rattle sorted. So after this week I will have to book her in AGAIN for the forth time to try and get some of these major mechanical issue sorted. How many chances to these guys need as I am really getting hacked off. Its such a great car but I want a drivet rain that sounds like its going to last the disatnce and not just 20K ![]() Here is a video of the engine noise problem Pablo Last edited by brgc00perboy; Nov 25th, 2007 at 01:10 AM. Reason: Added video lik |
| brgc00perboy.........that video of the engine noise is very distressing, no wonder you are worried. It would be a good idea if you could send a copy to BMW Mini. As regards the noisy windscreen, had the same problem with my July 07 MCS when driving at 70 mph or higher during the summer. Since the cooler weather it has stopped, I have posted a few threads on this titled "Wind Noise" and other owners have the same problem. |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html | ||||
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 30th, 2009 11:40 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Mar 29th, 2009 07:29 PM | |
| MINI2.com - MINI Forum | This thread | Refback | Mar 24th, 2009 03:46 PM | |
| My Community | This thread | Refback | Mar 21st, 2009 07:35 PM | |
| MINI Car Club of Indiana Forum - Search Results | This thread | Refback | Mar 19th, 2009 11:45 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Mar 18th, 2009 11:24 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 09:09 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 08:27 PM | |
| Mini (new bmw versions) Singletrackworld | This thread | Refback | Mar 17th, 2009 02:59 PM | |
| MINI COOPER :: North American Motoring - Clubman S cold engine valve noise | This thread | Refback | Mar 15th, 2009 03:07 AM | |
| MINI COOPER :: North American Motoring - Engine Knock During Cold Start | This thread | Refback | Mar 15th, 2009 02:38 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Mar 2nd, 2009 07:24 PM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Mar 2nd, 2009 07:28 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Feb 28th, 2009 09:26 PM | |
| R56 Mini Cooper S - | This thread | Refback | Feb 27th, 2009 04:20 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 22nd, 2009 08:17 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 04:15 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:29 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:21 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 01:23 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 12:59 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 21st, 2009 10:31 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 02:00 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 20th, 2009 10:45 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 19th, 2009 01:51 PM | |
| R56 Mini Cooper S | This thread | Refback | Feb 19th, 2009 11:26 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 08:27 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:41 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:09 AM | |
| Engine of the year award | This thread | Refback | Feb 18th, 2009 02:23 PM | |
| MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head | This thread | Refback | Feb 16th, 2009 06:38 PM | |
| One broken Mini! | This thread | Refback | Feb 16th, 2009 11:10 AM | |
| COLD START NOISE | This thread | Refback | Feb 15th, 2009 11:57 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 13th, 2009 10:23 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 11th, 2009 03:37 PM | |
| Winter Rattles.. | This thread | Refback | Feb 7th, 2009 09:40 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 6th, 2009 12:47 PM | |
| Engine of the year award | This thread | Refback | Jan 31st, 2009 10:32 PM | |
| Astle have a fix ???? | This thread | Refback | Jan 29th, 2009 07:19 PM | |
| Fault Register | This thread | Refback | Jan 29th, 2009 12:32 PM | |
| Engine of the year award | This thread | Refback | Jan 29th, 2009 09:03 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 28th, 2009 09:50 PM | |
| Example of noisy start | This thread | Refback | Jan 24th, 2009 03:55 PM | |
| MINI COOPER :: North American Motoring - Cold Start Issues Database | This thread | Refback | Jan 22nd, 2009 01:01 PM | |
| MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles | This thread | Refback | Jan 19th, 2009 12:57 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 16th, 2009 01:25 AM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 03:14 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:23 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:21 PM | |
| General Chit Chatter (Sorry!) | This thread | Refback | Jan 11th, 2009 10:52 AM | |
| Peugeot207Club | This thread | Refback | Jan 8th, 2009 01:10 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 8th, 2009 07:53 AM | |
| MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? | This thread | Refback | Jan 8th, 2009 03:12 AM | |
| R56 Mini Cooper S | This thread | Refback | Jan 7th, 2009 12:53 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Jan 6th, 2009 09:47 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 09:07 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 06:36 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 6th, 2009 02:07 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 07:22 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 06:16 PM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 5th, 2009 12:49 PM | |
| MotoringFile Archive R56 Cold Start Official Fix Coming | This thread | Refback | Jan 2nd, 2009 07:20 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 30th, 2008 09:35 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 29th, 2008 01:51 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 28th, 2008 03:35 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 25th, 2008 11:24 PM | |
| Fault Register | This thread | Refback | Dec 20th, 2008 07:19 PM | |
| Winter Rattles.. | This thread | Refback | Dec 20th, 2008 04:44 AM | |
| MINI COOPER :: North American Motoring - Engine Rattle After Sitting | This thread | Refback | Dec 18th, 2008 02:21 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Dec 13th, 2008 06:20 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Dec 12th, 2008 07:08 PM | |
| R56 Mini Cooper S | This thread | Refback | Dec 11th, 2008 10:18 PM | |
| Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) | This thread | Refback | Dec 4th, 2008 08:38 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 05:45 PM | |
| MINI COOPER :: North American Motoring - Cold Start Chatter | This thread | Refback | Dec 4th, 2008 12:10 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 11:00 AM | |
| engine noise when cold | This thread | Refback | Dec 2nd, 2008 08:32 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Dec 1st, 2008 10:11 AM | |
| Astle have a fix ???? | This thread | Refback | Nov 30th, 2008 08:02 PM | |
| engine noise when cold | This thread | Refback | Nov 29th, 2008 01:09 AM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 04:35 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:51 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:07 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:30 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:08 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:56 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:49 PM | |
| R56 Mini Cooper S | This thread | Refback | Nov 28th, 2008 03:12 AM | |
| Dealer Experience | This thread | Refback | Nov 23rd, 2008 04:34 PM | |
| Winter Rattles.. | This thread | Refback | Nov 19th, 2008 09:58 PM | |
| Winter Rattles.. | This thread | Refback | Nov 14th, 2008 06:37 AM | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Rattling noise when engine cold | berty | Second Generation Faults & Fixes | 14 | Feb 17th, 2008 06:05 PM |
| Engine noise when cold | Pglenning | First Generation Faults & Fixes | 7 | Feb 23rd, 2007 06:10 PM |
| Knocking noise from engine on MCS | DurhamFox | First Generation Faults & Fixes | 1 | Nov 16th, 2005 08:39 PM |
| Help Funny noise from ENGINE of MCS | BRGNICK | First Generation MINI Tuning | 4 | Jun 29th, 2005 01:23 PM |
| Please help me identify another MCS engine noise. | tenderidol | First Generation Faults & Fixes | 12 | Nov 10th, 2004 08:07 AM |
