| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (91) | Thread Tools | Rate Thread |
| My MCS is 2 weeks old (450 miles)... at weekend on Saturday, cold started car to briefly move into garage as was going away in our other car for overnight stay. Then, on Sunday took car out garage for a spin... experienced the "diesel" noise on startup/low revs/first few miles. That's the only time I've experienced this, so yes there is maybe something in the "start/stop without letting warm"? |
| Hmm.. I thought that too until we left the car out of the garage one night after a long-ish drive. Next morning we had the dreaded noise, just as bad as ever... so unfortunately it doesn't seem to be to do with starting/stopping without letting the engine warm (in our case at least). |
| Oh and forgot to mention, the technicians at the dealership were apparently able to reproduce the noise last time the car went in for some work to be done. They agreed that it's loud and nasty, but are convinced its normal... make of that what you will. |
| I am convinced it's a temperature thing. This weekend (warmer weather), I have tried the car from cold and experienced much less noise from the engine. On Sunday, I didn't go out in the car till the afternoon and it was very warm outside. The car hardly made any noise and after a couple of minutes, it was gone completely. Coincidence??? I don't think so. Not that it makes me any happier, because it may mean there is no fix. |
| The guy tried to explain it - essentially he said it was just a feature of the new engines, all part of the way they work to keep emissions down, etc, etc. Trouble is we were in a hurry to collect the car on the way to work, having dropped it off to have 12 other issues resolved. As such we didn't have much time to go into it, and I was busy checking that the carpet gap was fixed, the boot alignment was fixed, the boot alarm was fixed, etc. We did manage to get another R56 Cooper S loaner for an afternoon, though, to see if this produced the noise. It didn't - but then ours sometimes will go for days without making it. Interestingly, it did make the 'growl' when slowing down for speedbumps in 2nd and then pulling away, though. I guess the bottom line is that we're still no further ahead diagnosing this problem - if indeed it is a problem. But the number of people experiencing it seems to be on the increase. I notice that Paul and Olly have mentioned similar noises elsewhere - see: http://www.mini2.com/forum/2nd-gen-f...ml#post2975699 ...and the post immediately beneath it. |
| My engine has gone a lot quieter now the weather has warmed up. I am taking it back to my dealer tomorrow.I have been very patient but I am starting to get a little bit peed off now The car is lumpy on tick over.I still have the faulty gear box that not only makes a strange noise when gearing down from 3rd to 2nd but also makes a loud rattling noise when ticking over then goes when you put you clutch pedal down! I also have a rushing water sound coming from behind the dash when first started up and over the weekend a strange noise has appeared on the steering.And the final straw was when a friend of mine asked me if it was a diesel Not a happy bunny.I Work in the motor trade and drive many a different car- a lot with high milage!!! but i haven't heard anything as hideous as this!!! I have owned 6 minis one being a 51reg that got bought back for having so many faults but i would say this one has to be the worst one COOPER S |
I just took My R56 into the dealer this morning to check the Diesel noise out and the first thing the technician said was its the "characteristic" sound of the engine!! I ve left the car to have a better look at it and should have an answer within the day. Honestly if they dont give me a good explanation of what the noise I am writing an official complaint to BMW. Maybe this forum should start this initiative, since so many people seem to be having the same problem, and demand an official reply from BMW. If I wanted a car that sounds like that I would be driving a truck. Ill keep you guys posted on the findings of the dealer. Do you think this sound has any effect on the performance of the engine? |
| I've got exact the same problem with my Mini (among other problems) and I am now discussing rejection. They seem to think it is a perfectly acceptable characteristic. I have argued with them, that most reasonable people would consider if a fault with the engine and unnacceptable. According to the dealer, there technical expert thinks it is due to insufficient oil on the tappets at start up. Which I have then argued is a fault. Mine happens on cold frosty mornings only. |
| Just got a call from the dealer and the dont see a problem with it.. They insist that the noise that the engine makes is the sound of the high pressure fuel pump on the injection system. Can this be possible? In other words they provided no remedy what so ever for the sound and practically they expect me to put up with it. I honesty think we should definately start an official complaint to BMW. |
| They have basically admitted something is wrong. Ask them to give you a complete report on there findings and the exact details as to why there is insufficient supply to the tappets. Also ask them to give it to you in writing that this 'perfectly acceptable characteristic' is no cause for concern and will have no affect on the longevity of your engine. Rant mode off CB |
| I am not sure what the complaint would be. So far this noise seems to be just that, a noise. It may not be expected and does not sound good, but is there any evidence that it is a symptom of a more serious problem? If not then I am not sure how far we would get in saying that we do not like the noise our cars sometimes make on cold mornings. Or am I missing something? |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html | ||||
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 30th, 2009 11:40 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Mar 29th, 2009 07:29 PM | |
| MINI2.com - MINI Forum | This thread | Refback | Mar 24th, 2009 03:46 PM | |
| My Community | This thread | Refback | Mar 21st, 2009 07:35 PM | |
| MINI Car Club of Indiana Forum - Search Results | This thread | Refback | Mar 19th, 2009 11:45 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Mar 18th, 2009 11:24 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 09:09 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 08:27 PM | |
| Mini (new bmw versions) Singletrackworld | This thread | Refback | Mar 17th, 2009 02:59 PM | |
| MINI COOPER :: North American Motoring - Clubman S cold engine valve noise | This thread | Refback | Mar 15th, 2009 03:07 AM | |
| MINI COOPER :: North American Motoring - Engine Knock During Cold Start | This thread | Refback | Mar 15th, 2009 02:38 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Mar 2nd, 2009 07:24 PM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Mar 2nd, 2009 07:28 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Feb 28th, 2009 09:26 PM | |
| R56 Mini Cooper S - | This thread | Refback | Feb 27th, 2009 04:20 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 22nd, 2009 08:17 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 04:15 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:29 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:21 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 01:23 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 12:59 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 21st, 2009 10:31 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 02:00 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 20th, 2009 10:45 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 19th, 2009 01:51 PM | |
| R56 Mini Cooper S | This thread | Refback | Feb 19th, 2009 11:26 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 08:27 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:41 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 07:09 AM | |
| Engine of the year award | This thread | Refback | Feb 18th, 2009 02:23 PM | |
| MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head | This thread | Refback | Feb 16th, 2009 06:38 PM | |
| One broken Mini! | This thread | Refback | Feb 16th, 2009 11:10 AM | |
| COLD START NOISE | This thread | Refback | Feb 15th, 2009 11:57 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 13th, 2009 10:23 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 11th, 2009 03:37 PM | |
| Winter Rattles.. | This thread | Refback | Feb 7th, 2009 09:40 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 6th, 2009 12:47 PM | |
| Engine of the year award | This thread | Refback | Jan 31st, 2009 10:32 PM | |
| Astle have a fix ???? | This thread | Refback | Jan 29th, 2009 07:19 PM | |
| Fault Register | This thread | Refback | Jan 29th, 2009 12:32 PM | |
| Engine of the year award | This thread | Refback | Jan 29th, 2009 09:03 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 28th, 2009 09:50 PM | |
| Example of noisy start | This thread | Refback | Jan 24th, 2009 03:55 PM | |
| MINI COOPER :: North American Motoring - Cold Start Issues Database | This thread | Refback | Jan 22nd, 2009 01:01 PM | |
| MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles | This thread | Refback | Jan 19th, 2009 12:57 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 16th, 2009 01:25 AM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 03:14 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:23 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 01:21 PM | |
| General Chit Chatter (Sorry!) | This thread | Refback | Jan 11th, 2009 10:52 AM | |
| Peugeot207Club | This thread | Refback | Jan 8th, 2009 01:10 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 8th, 2009 07:53 AM | |
| MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? | This thread | Refback | Jan 8th, 2009 03:12 AM | |
| R56 Mini Cooper S | This thread | Refback | Jan 7th, 2009 12:53 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Jan 6th, 2009 09:47 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 09:07 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 06:36 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 6th, 2009 02:07 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 07:22 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 06:16 PM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 5th, 2009 12:49 PM | |
| MotoringFile Archive R56 Cold Start Official Fix Coming | This thread | Refback | Jan 2nd, 2009 07:20 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 30th, 2008 09:35 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 29th, 2008 01:51 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 28th, 2008 03:35 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 25th, 2008 11:24 PM | |
| Fault Register | This thread | Refback | Dec 20th, 2008 07:19 PM | |
| Winter Rattles.. | This thread | Refback | Dec 20th, 2008 04:44 AM | |
| MINI COOPER :: North American Motoring - Engine Rattle After Sitting | This thread | Refback | Dec 18th, 2008 02:21 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Dec 13th, 2008 06:20 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Dec 12th, 2008 07:08 PM | |
| R56 Mini Cooper S | This thread | Refback | Dec 11th, 2008 10:18 PM | |
| Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) | This thread | Refback | Dec 4th, 2008 08:38 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 05:45 PM | |
| MINI COOPER :: North American Motoring - Cold Start Chatter | This thread | Refback | Dec 4th, 2008 12:10 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 11:00 AM | |
| engine noise when cold | This thread | Refback | Dec 2nd, 2008 08:32 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Dec 1st, 2008 10:11 AM | |
| Astle have a fix ???? | This thread | Refback | Nov 30th, 2008 08:02 PM | |
| engine noise when cold | This thread | Refback | Nov 29th, 2008 01:09 AM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 04:35 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:51 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:07 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:30 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:08 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:56 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 01:49 PM | |
| R56 Mini Cooper S | This thread | Refback | Nov 28th, 2008 03:12 AM | |
| Dealer Experience | This thread | Refback | Nov 23rd, 2008 04:34 PM | |
| Winter Rattles.. | This thread | Refback | Nov 19th, 2008 09:58 PM | |
| Winter Rattles.. | This thread | Refback | Nov 14th, 2008 06:37 AM | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Rattling noise when engine cold | berty | Second Generation Faults & Fixes | 14 | Feb 17th, 2008 06:05 PM |
| Engine noise when cold | Pglenning | First Generation Faults & Fixes | 7 | Feb 23rd, 2007 06:10 PM |
| Knocking noise from engine on MCS | DurhamFox | First Generation Faults & Fixes | 1 | Nov 16th, 2005 08:39 PM |
| Help Funny noise from ENGINE of MCS | BRGNICK | First Generation MINI Tuning | 4 | Jun 29th, 2005 01:23 PM |
| Please help me identify another MCS engine noise. | tenderidol | First Generation Faults & Fixes | 12 | Nov 10th, 2004 08:07 AM |
