MCS Engine noise when cold - Page 70 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (91) Thread Tools Rate Thread
  1 links from elsewhere to this Post. Click to view. #1036 (permalink)
Old May 21st, 2008, 02:36 PM
caesar's Avatar
Local Time: 02:53 AM
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
Quote: Originally Posted by Den W (original)
Nor me I'm afraid.........
Possibly the reason why restarting only works for some owners depends on when the car was built. Mine was built June 07 !
  #1037 (permalink)
Old May 21st, 2008, 02:43 PM
Den W's Avatar
Now Aero Kitted!
Local Time: 01:53 AM
United Kingdom Male View Den W's Lightning Blue & Body Color 2nd Gen MINI Cooper S Profile
Mmm could be right..mines DEC 06
Den
  #1038 (permalink)
Old May 21st, 2008, 02:55 PM
Washy's Avatar
JCW time
Send a message via MSN to Washy
England Male View Washy's Chili Red & Black 2nd Gen MINI John Cooper Works Profile
Restarting doesnt work on mine either.....July 07 build.
2011 CR/B JCW
  #1039 (permalink)
Old May 21st, 2008, 03:48 PM
Bishamon's Avatar
Local Time: 09:53 PM
Canada Male View Bishamon's Pure Silver & Black 2nd Gen MINI Cooper S Profile
Restarting works nearly every time for me; February 07 build.
  #1040 (permalink)
Old May 23rd, 2008, 05:02 PM
I have mentioned in this thread before that one of the guys in service at my local dealers, was telling me 6 months ago that he was suffering from the same problem as you guys.
I was just talking to him a few minutes ago and asked if he had managed to get the problem fixed and basically he said no. They had tried a lot of the fixes that have been mentioned here but to no avail.
He gets the problem, like most when it is cold or if the car standing for a few days. The problem is related to the oil flow up to the valves and the rattling is the valves chattering until they are lubricated. He has been told that by his mechanics that he doesn't need to worry about it and he did say it only last 30 seconds, so he has just accepted it as a characteristic. Don't know if I would be quite as relaxed about having metal slapping on metal but I do suspect he is probably under more pressure than most not to make a fuss!!!
I must admit I was under the impression that most people in service departments or working in a dealership would get a staff discount but he told me he had to pay the same as everybody else because the demand for Mini's is so high.
  #1041 (permalink)
Old Jun 1st, 2008, 08:43 PM
I have noted the various comments about this noise and have read Tom at MMMC's post.
Unfortunately I have had the same problem with my R56 MCS. Although I had the problem wither the weather was hot or cold and even when I had been out in it ,stopped briefly and then restarted the engine. (Feb 07 build)
I had taken the car to the dealership where I had purchased it .Who informed me there was nothing wrong with the vehicle. Unsatisfied with this response I took it to an alternative dealership. They retained the vehicle for 3 weeks due to trying to get the parts and refit the full cylinder head. A list of items replaced are as follows.
Cylinder Head
Inlet Camshaft
Outlet Camshaft
Roller Drag Lever (16 of)
Hdr. Valve pushrod (16 of)
Repair kit valve seal ring
set bolt cylinder head
torx bolt (part number 11367545863)
torx bolt (Part number 11367536087)
Cylinder head gasket
set of profile gaskets (part number 11127572851)
vacuum pump
gasket, oil pan
gasket W/heat prot. shield
profile gasket (4 of) (part number 11617528340)
set of sealing and fastening parts (4 of)
profile-gasket (part number 11537548658)
gasket ring (4 of) (part number 07119963151)
gasket ring (4 of) (part number 07119963201)
valve collet (22 of)
set oil-filter element
(I have added part numbers for items of the same name in case anyone thought it was a duplication this is taken from a list supplied by the dealership who fitted them.)
Followed by a 100 mile roadtest.
I haven't had the noise since but I have no faith that it is now fixed for good as I have been waiting for 8 weeks now for an actual explanation of what the problem was and why so many components had to be replaced. All I have been told so far is that I had a leaking cylinder head although the oil had been checked and the level was fine and there was no traces of oil or smell of oil.
The car now has a relatively loud tick at idle wither it is hot or cold or even when it has been used. Although I have been told that this is normal and I have heard it on others but don't remember it being as loud on my car before the problem.
This is probably the most serious of the 10 problems I have had some cosmetic ie interior panels rattling, Sunroof blinds and panels squeaking, Rubber rear window seal below spoiler coming loose, Chrome stripping on bonnet coming off, scuttle panel riding up.
Window not returning properly when door shut leave a gap when closed.
2 electrical faults - flashed up warning lights, other flashed up warning lights and said to contact dealer at not move vehicle. Both rectified on individual visits to garage by replace parts.
Some more annoying like a sunroof which doesn't open when its warm. This has had bits replaced on countless occasions over the last 13 months and has had the full sunroof replaced too and it still is not operating properly.
I've had my car since 01/03/07 and it has been in the garage for repair over 25 times. Most of which for the sunroof and the rear window seal.
I just thought I would share this because of the relevance to this post and the number of people commenting on it.
This is my third Mini and at the moment I wouldn't recommend one to anybody due to my lack of faith in the car I have.
  #1042 (permalink)
Old Jun 2nd, 2008, 08:58 PM
Tracie's Avatar
I'm Back!
Send a message via AIM to Tracie
United Kingdom Female View Tracie's Pepper White & Black 2nd Gen MINI Cooper S Profile View Tracie's Classified Ads
I think you have a good case for rejection, evan after 14 months of ownership.
  #1043 (permalink)
Old Jun 2nd, 2008, 09:54 PM
campfreddie's Avatar
United Kingdom Male View campfreddie's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
New engine and 10,000 miles later and no rattle! Well when i say no rattle i mean no rattle from the engine. Obviously there are rattles from everything else!
I have sort of tuned out of this problem somewhat in the last few months or so but i am guessing not much headway has been made yet!
I think that weepuk's car like mine was built at 5.30pm on a Friday afternoon!
  #1044 (permalink)
Old Jun 3rd, 2008, 08:01 AM
caesar's Avatar
Years ago the Friday afternoon or Monday morning built car could have problems. Nowadays the are assembled by Robot's and in theory this should not apply..........unless one of the Robot's is faulty
  #1045 (permalink)
Old Jun 3rd, 2008, 08:27 AM
Washy's Avatar
JCW time
Actually most of the assembly is still done by hand....(lots of robots in the body in white shop though.) It is well worthwhile getting on a factory tour as it really is fascinating especially the way they turn the cars over to work on the underneath...
2011 CR/B JCW
  #1046 (permalink)
Old Jun 4th, 2008, 09:50 PM
Dont assembly line robots look forwards to a Friday night pint like everyone else then?
  #1047 (permalink)
Old Jun 4th, 2008, 10:29 PM
Two months and, apart from one heart stopping 5 seconds, the noise has not returned.
I'm dreading winter though, I'm convinced it will start again.
Smug (with some trepidation) of Blackburn
  #1048 (permalink)
Old Jun 5th, 2008, 02:48 AM
Local Time: 06:53 PM
United States Male
Thats what I always thought too
  #1049 (permalink)
Old Jun 7th, 2008, 04:01 PM
United Kingdom View Union Jacks's Classified Ads
United-Kingdom Self Bleeding Tappits!!!!!!
my MCS is also 06 and was making a tapping noise on start up
took it to the dealer and they say the hydraulic tappits go through a self bleed process on start up - this maybe the noise your hearing as my car makes the same noise as yours occasionally on start-up.
it sounds like the noise your hearing is the bleed sequence amplified by the gentle revving of the engine.
  #1050 (permalink)
Old Jun 14th, 2008, 11:36 AM
MJS's Avatar
MJS
United Kingdom View MJS's Chili Red & Black 2nd Gen MINI Cooper S Profile
Is everyone else all quiet with the warmer weather?
I've noticed its gone a lot quieter on this post recently....
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html
Posted By For Type Date
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 30th, 2009 11:40 PM
Rattling engine from cold- 08 MCS This thread Refback Mar 29th, 2009 07:29 PM
MINI2.com - MINI Forum This thread Refback Mar 24th, 2009 03:46 PM
My Community This thread Refback Mar 21st, 2009 07:35 PM
MINI Car Club of Indiana Forum - Search Results This thread Refback Mar 19th, 2009 11:45 AM
VANOS Oil Pressure Accumulator This thread Refback Mar 18th, 2009 11:24 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 09:09 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 08:27 PM
Mini (new bmw versions) Singletrackworld This thread Refback Mar 17th, 2009 02:59 PM
MINI COOPER :: North American Motoring - Clubman S cold engine valve noise This thread Refback Mar 15th, 2009 03:07 AM
MINI COOPER :: North American Motoring - Engine Knock During Cold Start This thread Refback Mar 15th, 2009 02:38 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Mar 2nd, 2009 07:24 PM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Mar 2nd, 2009 07:28 AM
VANOS Oil Pressure Accumulator This thread Refback Feb 28th, 2009 09:26 PM
R56 Mini Cooper S - This thread Refback Feb 27th, 2009 04:20 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 22nd, 2009 08:17 AM
COLD START NOISE This thread Refback Feb 21st, 2009 04:15 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:29 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:21 PM
COLD START NOISE This thread Refback Feb 21st, 2009 01:23 PM
COLD START NOISE This thread Refback Feb 21st, 2009 12:59 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 21st, 2009 10:31 AM
COLD START NOISE This thread Refback Feb 21st, 2009 02:00 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 20th, 2009 10:45 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 19th, 2009 01:51 PM
R56 Mini Cooper S This thread Refback Feb 19th, 2009 11:26 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 08:27 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 07:41 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 07:09 AM
Engine of the year award This thread Refback Feb 18th, 2009 02:23 PM
MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head This thread Refback Feb 16th, 2009 06:38 PM
One broken Mini! This thread Refback Feb 16th, 2009 11:10 AM
COLD START NOISE This thread Refback Feb 15th, 2009 11:57 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 13th, 2009 10:23 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 11th, 2009 03:37 PM
Winter Rattles.. This thread Refback Feb 7th, 2009 09:40 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 6th, 2009 12:47 PM
Engine of the year award This thread Refback Jan 31st, 2009 10:32 PM
Astle have a fix ???? This thread Refback Jan 29th, 2009 07:19 PM
Fault Register This thread Refback Jan 29th, 2009 12:32 PM
Engine of the year award This thread Refback Jan 29th, 2009 09:03 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 28th, 2009 09:50 PM
Example of noisy start This thread Refback Jan 24th, 2009 03:55 PM
MINI COOPER :: North American Motoring - Cold Start Issues Database This thread Refback Jan 22nd, 2009 01:01 PM
MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles This thread Refback Jan 19th, 2009 12:57 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 16th, 2009 01:25 AM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 03:14 PM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 01:23 PM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 01:21 PM
General Chit Chatter (Sorry!) This thread Refback Jan 11th, 2009 10:52 AM
Peugeot207Club This thread Refback Jan 8th, 2009 01:10 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 8th, 2009 07:53 AM
MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? This thread Refback Jan 8th, 2009 03:12 AM
R56 Mini Cooper S This thread Refback Jan 7th, 2009 12:53 PM
For all those with faulty engines & those interested - info inside! This thread Refback Jan 6th, 2009 09:47 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 09:07 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 06:36 AM
R56 Mini Cooper S - Index This thread Refback Jan 6th, 2009 02:07 AM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 07:22 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 06:16 PM
R56 Mini Cooper S - Index This thread Refback Jan 5th, 2009 12:49 PM
MotoringFile Archive R56 Cold Start Official Fix Coming This thread Refback Jan 2nd, 2009 07:20 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 30th, 2008 09:35 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 29th, 2008 01:51 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 28th, 2008 03:35 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 25th, 2008 11:24 PM
Fault Register This thread Refback Dec 20th, 2008 07:19 PM
Winter Rattles.. This thread Refback Dec 20th, 2008 04:44 AM
MINI COOPER :: North American Motoring - Engine Rattle After Sitting This thread Refback Dec 18th, 2008 02:21 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Dec 13th, 2008 06:20 AM
R56 Mini Cooper S - Index This thread Refback Dec 12th, 2008 07:08 PM
R56 Mini Cooper S This thread Refback Dec 11th, 2008 10:18 PM
Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) This thread Refback Dec 4th, 2008 08:38 PM
engine noise when cold This thread Refback Dec 4th, 2008 05:45 PM
MINI COOPER :: North American Motoring - Cold Start Chatter This thread Refback Dec 4th, 2008 12:10 PM
engine noise when cold This thread Refback Dec 4th, 2008 11:00 AM
engine noise when cold This thread Refback Dec 2nd, 2008 08:32 AM
VANOS Oil Pressure Accumulator This thread Refback Dec 1st, 2008 10:11 AM
Astle have a fix ???? This thread Refback Nov 30th, 2008 08:02 PM
engine noise when cold This thread Refback Nov 29th, 2008 01:09 AM
engine noise when cold This thread Refback Nov 28th, 2008 04:35 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:51 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:07 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:30 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:08 PM
engine noise when cold This thread Refback Nov 28th, 2008 01:56 PM
engine noise when cold This thread Refback Nov 28th, 2008 01:49 PM
R56 Mini Cooper S This thread Refback Nov 28th, 2008 03:12 AM
Dealer Experience This thread Refback Nov 23rd, 2008 04:34 PM
Winter Rattles.. This thread Refback Nov 19th, 2008 09:58 PM
Winter Rattles.. This thread Refback Nov 14th, 2008 06:37 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Rattling noise when engine cold berty Second Generation Faults & Fixes 14 Feb 17th, 2008 06:05 PM
Engine noise when cold Pglenning First Generation Faults & Fixes 7 Feb 23rd, 2007 06:10 PM
Knocking noise from engine on MCS DurhamFox First Generation Faults & Fixes 1 Nov 16th, 2005 08:39 PM
Help Funny noise from ENGINE of MCS BRGNICK First Generation MINI Tuning 4 Jun 29th, 2005 01:23 PM
Please help me identify another MCS engine noise. tenderidol First Generation Faults & Fixes 12 Nov 10th, 2004 08:07 AM
