MCS Engine noise when cold - Page 84 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (91) Thread Tools Rate Thread
  6 links from elsewhere to this Post. Click to view. #1246 (permalink)
Old Oct 25th, 2008, 12:38 PM
Washy's Avatar
JCW time
Send a message via MSN to Washy
Local Time: 09:12 PM
England Male View Washy's Chili Red & Black 2nd Gen MINI John Cooper Works Profile
Quote: Originally Posted by S8RAH (original)
Sorry folks, I'm bailing out.
The car is going at the end of Nov-- I've had enough.
I'm keeping my eye on the forum cos I suspect the new one will be just as noisy but at least this Dec fix will be applicable to the next car.
I have finally convinced my dealer I have this problem....only taken a year...
But like you I have had enough of my car and will be replacing it as soon as I can
2011 CR/B JCW
  #1247 (permalink)
Old Oct 25th, 2008, 02:21 PM
United Kingdom View Union Jacks's Classified Ads
Unhappy Timing Chain Broke!
My R56 MCS also had the noisy start-up sound (like a diesel starting up!)
Dealer stated it was the hydraulic tappets going through an automatic self-bleed process on startt-up and i shouldn't worry.
6 weeks later the timing chain broke on start-up and stuffed the top of the engine - luckily warranty prevailed.
i am now having issues with jerky acceleration - almost like a misfire.
took to the dealer who stated there was an engine management fault alarm which was stopping over boost - dealer reset fault and i'm now getting full power but still jerky - so its in on monday for a day so they can diagnose the jerky acceleration.
tried all types of fuel - nothing helps
  #1248 (permalink)
Old Oct 25th, 2008, 06:17 PM
MJS's Avatar
MJS
United Kingdom View MJS's Chili Red & Black 2nd Gen MINI Cooper S Profile
I dread to think what's going to happen to these cars in 3/4/5 years time when they are out of warranty.
I hope this is a one-off and not a sign of things to come, or else we are all up the creek without a paddle.....
Very worrying indeed, especially as we are all being told there is no problem with the noisy engines!
  #1249 (permalink)
Old Oct 25th, 2008, 07:29 PM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
Timing Chain Broke !
A broken timing chain is a rare occurrence, but not unheard of. Some years ago Ford and other makers used Timing Belts but the Japanese always used chains as they are very reliable with an almost infinite life. Timing belts had to be replaced at recommended intervals but they frequently snapped early with sometimes serious engine damage.
The fact a MCS chain snapped is very unfortunate and rare, but any mechanical part according to "***'s Law" can break.
  #1250 (permalink)
Old Oct 25th, 2008, 07:47 PM
Local Time: 08:12 PM
United Kingdom View mike ken's Classified Ads
Our car is now doing this timing chain noise no matter how the car is parked, where as before it would only do it when car is parked facing down hill. Went on a long run today and we have found another noise which i think is the water pump, it sounds like there is a mouse squeaking under the bonnet.
mini nut
  #1251 (permalink)
Old Oct 26th, 2008, 09:33 AM
United-Kingdom
Has anyone else been told that the noise is just the tappets going through a self bleed on start-up?
or is it just what they fobbed me off with?
  #1252 (permalink)
Old Oct 26th, 2008, 09:51 AM
Tracie's Avatar
I'm Back!
Send a message via AIM to Tracie
United Kingdom Female View Tracie's Pepper White & Black 2nd Gen MINI Cooper S Profile View Tracie's Classified Ads
This is something that I have been concerned with, especially now as the MCS is the way to go for me.
I have taken a MCS and a JCW out in recent weeks, and the tappets on the JCW were a lot louder than the MCS.
The Tappet noise I have been told is normal on a performance engine, my brother's Subaru rattle like anything on a start up, evan when the oil has cooled down after standing for half and hour. He assures me this is normal and the noise stops when the oil has warmed up enough, which it is.
My Subaru does the same as well, although not as loud as my brother as his is pushing 500bhp.
OK, so they are different cars compared to the MINI, but the same sound occurring.
The tensioner rattle however is a different ball game I'm assuming?
  #1253 (permalink)
Old Oct 26th, 2008, 10:00 AM
caesar's Avatar
Over time the chain will stretch and relies on the tensioner to take up the slack, if the tensioner is getting insufficient oil pressure then the chain will rattle against the guide rails. Once the tensioner has sufficient oil pressure the rattle will stop. From earlier threads on this topic it would appear that the early build MCS R56's have a different mechanism than models built from 01.05.07. Models from this date will have a spring loaded tensioner available in December this year which will replace the existing oil pressure activated tensioner (PuMA Measure 10686850). Earlier build models will require more extensive modifications.
  #1254 (permalink)
Old Oct 26th, 2008, 10:05 AM
Well its a new one on me.
I've been told, after much investigation by dealers and manufacturers, that the top end of my engine lacks oil before/on start up. They will not say if this is the cause of the noise, I suspect that is a separate problem but who knows?
I didn't like the idea of all that metal churning round with a lack of oil which is why mine's going. There are various theories on the cause of the noise but none of them have been officially confirmed by BMW but at least they have recognised that this is an issue for owners.
Keep pressing, if only to ensure you are one of the first to get the fix.
  #1255 (permalink)
Old Oct 26th, 2008, 10:55 AM
caesar's Avatar
Engine noise on start-up
My MCS is a June 07 Build and occasionally makes the 'noise' if left parked facing down the driveway to the garage.,,,.....a restart cures the problem
I visited my dealer who stated they had not heard of this problem so I wrote to Mini Customer Services giving the Chassis and Engine numbers complaining about the service I had received from the dealer. About a week later the dealer wrote an apologetic letter and said they would contact me as soon as the replacement tensioner was available.
  #1256 (permalink)
Old Oct 27th, 2008, 10:41 PM
This "fix" due to be released to solve the problem - are adjustments currently being made to cars in the process of being built moment?
  #1257 (permalink)
Old Oct 28th, 2008, 05:29 AM
So my Aug build 08 MCS here in socal has given me two occasion of this nasty sound.
Both happen when I didn not drive the car for 24 hours (skipped a day of driving basically) and left it in the garage. Each episode would last about 2 minutes or so... VERY annoying and my wife thinks that the engine is gonna blow up or stall. Eventually the sound goes away. I dont even know what to tell the dealer (Southbay MINI) as they dont know how to reproduce the same sound.
As this does not happen everytime... i think a visit to the dealer is a waste of time at this time. They havent even heard this before (which is a lie i believe)
  #1258 (permalink)
Old Oct 28th, 2008, 06:15 AM
The only way is to record it.
I get in mine every morning with my cellphone on video mode and keep the clips only when the car makes the noise (daily at the moment, its got cold here)
Once you have proof that your car makes the noise then book it in and it will be their problem.
  #1259 (permalink)
Old Oct 28th, 2008, 08:44 AM
That is exactly what I did as posted on the 21st October, except I used a laptop and mike to get some good clear recordings put it on a USB and handed to the dealer with a copy of the technical bulletin. The job was fixed to my satisfaction with no further questions asked.
Our garage: Mini Cooper S with JCW kit - Z4 3.0i SE Roadster
X5 3.0i Sport, - CJ10a V8 Jeep - TJ 'Challenge' Jeep - Ford Ka
  #1260 (permalink)
Old Oct 28th, 2008, 01:50 PM
Bishamon's Avatar
Local Time: 04:12 PM
Canada Male View Bishamon's Pure Silver & Black 2nd Gen MINI Cooper S Profile
While MINI/BMW have stated that the sound does not cause damage, wouldn't slack in the cam chain have an effect on the timing?
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html
Posted By For Type Date
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 30th, 2009 11:40 PM
Rattling engine from cold- 08 MCS This thread Refback Mar 29th, 2009 07:29 PM
MINI2.com - MINI Forum This thread Refback Mar 24th, 2009 03:46 PM
My Community This thread Refback Mar 21st, 2009 07:35 PM
MINI Car Club of Indiana Forum - Search Results This thread Refback Mar 19th, 2009 11:45 AM
VANOS Oil Pressure Accumulator This thread Refback Mar 18th, 2009 11:24 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 09:09 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 08:27 PM
Mini (new bmw versions) Singletrackworld This thread Refback Mar 17th, 2009 02:59 PM
MINI COOPER :: North American Motoring - Clubman S cold engine valve noise This thread Refback Mar 15th, 2009 03:07 AM
MINI COOPER :: North American Motoring - Engine Knock During Cold Start This thread Refback Mar 15th, 2009 02:38 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Mar 2nd, 2009 07:24 PM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Mar 2nd, 2009 07:28 AM
VANOS Oil Pressure Accumulator This thread Refback Feb 28th, 2009 09:26 PM
R56 Mini Cooper S - This thread Refback Feb 27th, 2009 04:20 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 22nd, 2009 08:17 AM
COLD START NOISE This thread Refback Feb 21st, 2009 04:15 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:29 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:21 PM
COLD START NOISE This thread Refback Feb 21st, 2009 01:23 PM
COLD START NOISE This thread Refback Feb 21st, 2009 12:59 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 21st, 2009 10:31 AM
COLD START NOISE This thread Refback Feb 21st, 2009 02:00 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 20th, 2009 10:45 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 19th, 2009 01:51 PM
R56 Mini Cooper S This thread Refback Feb 19th, 2009 11:26 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 08:27 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 07:41 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 07:09 AM
Engine of the year award This thread Refback Feb 18th, 2009 02:23 PM
MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head This thread Refback Feb 16th, 2009 06:38 PM
One broken Mini! This thread Refback Feb 16th, 2009 11:10 AM
COLD START NOISE This thread Refback Feb 15th, 2009 11:57 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 13th, 2009 10:23 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 11th, 2009 03:37 PM
Winter Rattles.. This thread Refback Feb 7th, 2009 09:40 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 6th, 2009 12:47 PM
Engine of the year award This thread Refback Jan 31st, 2009 10:32 PM
Astle have a fix ???? This thread Refback Jan 29th, 2009 07:19 PM
Fault Register This thread Refback Jan 29th, 2009 12:32 PM
Engine of the year award This thread Refback Jan 29th, 2009 09:03 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 28th, 2009 09:50 PM
Example of noisy start This thread Refback Jan 24th, 2009 03:55 PM
MINI COOPER :: North American Motoring - Cold Start Issues Database This thread Refback Jan 22nd, 2009 01:01 PM
MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles This thread Refback Jan 19th, 2009 12:57 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 16th, 2009 01:25 AM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 03:14 PM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 01:23 PM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 01:21 PM
General Chit Chatter (Sorry!) This thread Refback Jan 11th, 2009 10:52 AM
Peugeot207Club This thread Refback Jan 8th, 2009 01:10 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 8th, 2009 07:53 AM
MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? This thread Refback Jan 8th, 2009 03:12 AM
R56 Mini Cooper S This thread Refback Jan 7th, 2009 12:53 PM
For all those with faulty engines & those interested - info inside! This thread Refback Jan 6th, 2009 09:47 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 09:07 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 06:36 AM
R56 Mini Cooper S - Index This thread Refback Jan 6th, 2009 02:07 AM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 07:22 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 06:16 PM
R56 Mini Cooper S - Index This thread Refback Jan 5th, 2009 12:49 PM
MotoringFile Archive R56 Cold Start Official Fix Coming This thread Refback Jan 2nd, 2009 07:20 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 30th, 2008 09:35 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 29th, 2008 01:51 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 28th, 2008 03:35 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 25th, 2008 11:24 PM
Fault Register This thread Refback Dec 20th, 2008 07:19 PM
Winter Rattles.. This thread Refback Dec 20th, 2008 04:44 AM
MINI COOPER :: North American Motoring - Engine Rattle After Sitting This thread Refback Dec 18th, 2008 02:21 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Dec 13th, 2008 06:20 AM
R56 Mini Cooper S - Index This thread Refback Dec 12th, 2008 07:08 PM
R56 Mini Cooper S This thread Refback Dec 11th, 2008 10:18 PM
Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) This thread Refback Dec 4th, 2008 08:38 PM
engine noise when cold This thread Refback Dec 4th, 2008 05:45 PM
MINI COOPER :: North American Motoring - Cold Start Chatter This thread Refback Dec 4th, 2008 12:10 PM
engine noise when cold This thread Refback Dec 4th, 2008 11:00 AM
engine noise when cold This thread Refback Dec 2nd, 2008 08:32 AM
VANOS Oil Pressure Accumulator This thread Refback Dec 1st, 2008 10:11 AM
Astle have a fix ???? This thread Refback Nov 30th, 2008 08:02 PM
engine noise when cold This thread Refback Nov 29th, 2008 01:09 AM
engine noise when cold This thread Refback Nov 28th, 2008 04:35 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:51 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:07 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:30 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:08 PM
engine noise when cold This thread Refback Nov 28th, 2008 01:56 PM
engine noise when cold This thread Refback Nov 28th, 2008 01:49 PM
R56 Mini Cooper S This thread Refback Nov 28th, 2008 03:12 AM
Dealer Experience This thread Refback Nov 23rd, 2008 04:34 PM
Winter Rattles.. This thread Refback Nov 19th, 2008 09:58 PM
Winter Rattles.. This thread Refback Nov 14th, 2008 06:37 AM
Rattling noise when engine cold berty Second Generation Faults & Fixes 14 Feb 17th, 2008 06:05 PM
Engine noise when cold Pglenning First Generation Faults & Fixes 7 Feb 23rd, 2007 06:10 PM
Knocking noise from engine on MCS DurhamFox First Generation Faults & Fixes 1 Nov 16th, 2005 08:39 PM
Help Funny noise from ENGINE of MCS BRGNICK First Generation MINI Tuning 4 Jun 29th, 2005 01:23 PM
Please help me identify another MCS engine noise. tenderidol First Generation Faults & Fixes 12 Nov 10th, 2004 08:07 AM
