MCS Engine noise when cold - Page 91 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (91) Thread Tools Rate Thread
  #1351 (permalink)
Old Dec 31st, 2008, 05:15 PM
Send a message via MSN to xxx4xyz
Local Time: 12:48 AM
United Kingdom Male View xxx4xyz's Classified Ads
At last..... my MCS is going into the dealer for a few days in January to have the rattling engine noise 'fixed' they are keeping it for a few days as apparently its a complex job !! (and this will be the first one they have attempted to fix) !! ohhh joy
On top of that fix they are also re doing my sunroof (which refused to close the other day) which is a big job apparently ?? (new cables and motor)
On top of that they are also going to look at my cluch which makes a humming noise now and again when setting off in first -
And on top of that they are going to refit the door panels which have started to come lose (inside panel where we all rest our arm on - flush with window)
And finally, re fit the carpet where it does not fit properly on the pax side well !
Oh did i mention the loose gear stick ??? that too is on the list - so i hope to see my MCS around mid feb hahahaha !!
Wish me luck !!
  #1352 (permalink)
Old Dec 31st, 2008, 05:52 PM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
It would appear from the above post and other's, that the early R56 models have/or did have the most problems.
Not a very good advert for BMW
  #1353 (permalink)
Old Dec 31st, 2008, 06:10 PM
ShaunSheep's Avatar
Totally maniacal!
United Kingdom Female View ShaunSheep's Laser Blue & White 2nd Gen MINI Cooper S Profile
Just as the early 1st gen MINIs did. Or the early models of other cars for that matter?
I wouldn't necessarily agree with that comment anyway, there are new R56 owners posting with various issues.
Also just as an example, my early build MCS has had just two faults; a failed water pump and the cold start rattle.
  #1354 (permalink)
Old Dec 31st, 2008, 07:06 PM
caesar's Avatar
There is a greater possibility of problems with any early build vehicle. I have owned a number and have had problems.....and they have eventually been fixed.
Prior to buying a new MCS in June 07, I owned a Civic Type-R in February 04.........this was the facelift version of the 1st Type-R. I had no end of problems which were not fixed
I traded it in June 07 for a MCS.......apart from occasional cases of the 'noise' when it's left parked facing down the drive to the garage......easily cured by doing a restart.
Apart from the above the only other is a whistling noise from the windscreen at high speed or strong cross winds. The Dealer said they would fit a new windscreen which will done shortly.
Overall I am (touch wood) very pleased with the car
  #1355 (permalink)
Old Jan 2nd, 2009, 05:12 PM
MandyB1971's Avatar
Local Time: 11:48 PM
As per the oil usage issue, we had this very discussion with them a few weeks ago as we are putting more oil in it than we do in our Freelander Diesel!! Mini reckon that the MCS will use a litre of oil per 600 miles! Not only that but it can only have Mobil1 super-duper oil in it at Ģ15 per litre! Not good!
Our noise is worse than ever and following it returning from dealers last week where they proudly proclaimed it was the worst one they'd ever heard it also now has a rattle from the turbo, which we think might just be a cover they've not put on properly and is idling at nearly 1500 revs!
Whoever mentioned the new Fiat 500 Abarth - I'll fight you for it! Thinking of going same way myself!
Mandy
  #1356 (permalink)
Old Jan 2nd, 2009, 06:10 PM
Strippekniv's Avatar
Norway Male View Strippekniv's Classified Ads
Hellish engine racket
Has anyone (BMW/Peugeot) come up with a cure for this problem?
Can I take my 13 month old MCS Clubbie to the dealers for a fix on Monday morning?
Anyone in-the-know out there?
Greetings from one worried owner...
  #1357 (permalink)
Old Jan 2nd, 2009, 07:33 PM
caesar's Avatar
[quote=MandyB1971;3631332]As per the oil usage issue, we had this very discussion with them a few weeks ago as we are putting more oil in it than we do in our Freelander Diesel!! Mini reckon that the MCS will use a litre of oil per 600 miles! Not only that but it can only have Mobil1 super-duper oil in it at Ģ15 per litre! Not good!
That is a load of rubbish.........the recommended oil is Castrol Edge 5W-30 for the MCS not Mobil
The oil consumption for the Mini is minimal, my June 07 build MCS has done 9.5K miles from new.........I check the oil level on a regular basis and have added about 1.5 litres in total over this period.
Get your Dealer to check for oil leaks
  #1358 (permalink)
Old Jan 3rd, 2009, 04:25 PM
CBCooper started this thread on Feb 19th, 2007...
... is everything still speculation?
Have read about 25 of the over 60 pages(!) in this thread now, obviously the engine noise we are experiencing isnīt normal or supposed to be there as some (BMW?) contributors are allegeing.
Come on guys, is there anyone here who can give me a straight answer? Does changing the timing chain, the sprockets and the tensioner actually fix the problem? What can I tell my dealer needs to be done here?
Give me the low down please!
  #1359 (permalink)
Old Jan 3rd, 2009, 04:31 PM
Puma?
Also - what is PUMA?
English is not my first language.
Answers appreciated.
  #1360 (permalink)
Old Jan 3rd, 2009, 07:52 PM
MandyB1971's Avatar
PUMA is the BMW computer system that the dealers use.
As for the oil, I am SURE it has an oil leak as something's dripping on the road outside my house and I'm pretty sure its not our Freelander. I'm going to be ringing them for our weekly chat on Monday and will speak to them about this! Also, my fault, I lied above! (We put Mobil1 in it once so I got confused sorry!) My husband has just corrected me it is castrol edge but they charge us Ģ15+ per litre for that from Mini Dealers!
Mandy B
  #1361 (permalink)
Old Jan 3rd, 2009, 08:52 PM
caesar's Avatar
Castrol Edge is expensive because it's fully synthetic as opposed to mineral oil, but does not need changing as often.....hence the price.
Halfords were selling a 4 litre drum for about Ģ10 per litre.
  #1362 (permalink)
Old Jan 3rd, 2009, 09:11 PM
MINI-Morgan's Avatar
MINI Obsessed...
Mandy B
Is that a proper MINI/BMW dealer?? Is that a friendly name for the system?? The dealers systems are either the old GT-1 or newer SSS/OPS.
What colour is the oil? is there enough to form a puddle? hope its not powersteering fluid.....
  #1363 (permalink)
Old Jan 4th, 2009, 04:50 PM
MandyB1971's Avatar
Hi, this is Mandy's husband Steve.
Just wanted to clear this up (women always get things wrong! )
Mandy is right in that our local dealer (MINI/BMW main dealer) has told us that 600 miles per litre of oil is not excessive according to BMW themselves. I however think this is excessive even for a 'performance' engine. I've had experience with 600bhp V8's, turbo and supercharged engines and even full race engines which don't use this much.
Saying that, I've looked for any leaks and can't find any evidence of them!
As for your comments on the recommended oil caesar, BMW do recommend Castrol oils but Mobil 1 ESP is also manufactured to BMW LL-04 which is the specification stated in the handbook. I had to point this out to the service manager at our dealer when he tried to tell me that Mobil 1 wasn't a good enough oil for the MCS!
As far as I'm concerned, after seeing the sludge that came out of our MCS at it's oil change, I wouldn't recommend Castrol to anyone!
I've used Mobil 1 in many car and motorbike engines for years, even race spec, and have never had anything but superb results.
  #1364 (permalink)
Old Jan 4th, 2009, 05:40 PM
caesar's Avatar
Hi Steve.........many thanks for your informative post
I still think your wife's MCS has an oil leak, and your Dealer should investigate the source i.e. the cylinder head gasket. If it is blowing it would cause coolant to mix with the oil causing sludge to form
  #1365 (permalink)
Old Jan 5th, 2009, 01:42 PM
Isnīt this thread getting a bit off-topic? MCS Engine noise when cold
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html
Posted By For Type Date
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 31st, 2009 12:40 AM
Rattling engine from cold- 08 MCS This thread Refback Mar 29th, 2009 08:29 PM
MINI2.com - MINI Forum This thread Refback Mar 24th, 2009 04:46 PM
My Community This thread Refback Mar 21st, 2009 08:35 PM
MINI Car Club of Indiana Forum - Search Results This thread Refback Mar 19th, 2009 12:45 PM
VANOS Oil Pressure Accumulator This thread Refback Mar 19th, 2009 12:24 AM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 10:09 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 09:27 PM
Mini (new bmw versions) Singletrackworld This thread Refback Mar 17th, 2009 03:59 PM
MINI COOPER :: North American Motoring - Clubman S cold engine valve noise This thread Refback Mar 15th, 2009 04:07 AM
MINI COOPER :: North American Motoring - Engine Knock During Cold Start This thread Refback Mar 15th, 2009 03:38 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Mar 2nd, 2009 08:24 PM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Mar 2nd, 2009 08:28 AM
VANOS Oil Pressure Accumulator This thread Refback Feb 28th, 2009 10:26 PM
R56 Mini Cooper S - This thread Refback Feb 27th, 2009 05:20 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 22nd, 2009 09:17 AM
COLD START NOISE This thread Refback Feb 21st, 2009 05:15 PM
COLD START NOISE This thread Refback Feb 21st, 2009 04:29 PM
COLD START NOISE This thread Refback Feb 21st, 2009 04:21 PM
COLD START NOISE This thread Refback Feb 21st, 2009 02:23 PM
COLD START NOISE This thread Refback Feb 21st, 2009 01:59 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 21st, 2009 11:31 AM
COLD START NOISE This thread Refback Feb 21st, 2009 03:00 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 20th, 2009 11:45 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 19th, 2009 02:51 PM
R56 Mini Cooper S This thread Refback Feb 19th, 2009 12:26 PM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 09:27 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 08:41 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 08:09 AM
Engine of the year award This thread Refback Feb 18th, 2009 03:23 PM
MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head This thread Refback Feb 16th, 2009 07:38 PM
One broken Mini! This thread Refback Feb 16th, 2009 12:10 PM
COLD START NOISE This thread Refback Feb 15th, 2009 12:57 PM
Rattling engine from cold- 08 MCS This thread Refback Feb 13th, 2009 11:23 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 11th, 2009 04:37 PM
Winter Rattles.. This thread Refback Feb 7th, 2009 10:40 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 6th, 2009 01:47 PM
Engine of the year award This thread Refback Jan 31st, 2009 11:32 PM
Astle have a fix ???? This thread Refback Jan 29th, 2009 08:19 PM
Fault Register This thread Refback Jan 29th, 2009 01:32 PM
Engine of the year award This thread Refback Jan 29th, 2009 10:03 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 28th, 2009 10:50 PM
Example of noisy start This thread Refback Jan 24th, 2009 04:55 PM
MINI COOPER :: North American Motoring - Cold Start Issues Database This thread Refback Jan 22nd, 2009 02:01 PM
MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles This thread Refback Jan 19th, 2009 01:57 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 16th, 2009 02:25 AM
Lautes klackern nach dem starten - Seite 83 - MINIē - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 04:14 PM
Lautes klackern nach dem starten - Seite 83 - MINIē - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 02:23 PM
Lautes klackern nach dem starten - Seite 83 - MINIē - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 02:21 PM
General Chit Chatter (Sorry!) This thread Refback Jan 11th, 2009 11:52 AM
Peugeot207Club This thread Refback Jan 8th, 2009 02:10 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 8th, 2009 08:53 AM
MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? This thread Refback Jan 8th, 2009 04:12 AM
R56 Mini Cooper S This thread Refback Jan 7th, 2009 01:53 PM
For all those with faulty engines & those interested - info inside! This thread Refback Jan 6th, 2009 10:47 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 10:07 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 07:36 AM
R56 Mini Cooper S - Index This thread Refback Jan 6th, 2009 03:07 AM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 08:22 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 07:16 PM
R56 Mini Cooper S - Index This thread Refback Jan 5th, 2009 01:49 PM
MotoringFile Archive R56 Cold Start Official Fix Coming This thread Refback Jan 2nd, 2009 08:20 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 30th, 2008 10:35 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 29th, 2008 02:51 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 28th, 2008 04:35 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 26th, 2008 12:24 AM
Fault Register This thread Refback Dec 20th, 2008 08:19 PM
Winter Rattles.. This thread Refback Dec 20th, 2008 05:44 AM
MINI COOPER :: North American Motoring - Engine Rattle After Sitting This thread Refback Dec 18th, 2008 03:21 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Dec 13th, 2008 07:20 AM
R56 Mini Cooper S - Index This thread Refback Dec 12th, 2008 08:08 PM
R56 Mini Cooper S This thread Refback Dec 11th, 2008 11:18 PM
Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) This thread Refback Dec 4th, 2008 09:38 PM
engine noise when cold This thread Refback Dec 4th, 2008 06:45 PM
MINI COOPER :: North American Motoring - Cold Start Chatter This thread Refback Dec 4th, 2008 01:10 PM
engine noise when cold This thread Refback Dec 4th, 2008 12:00 PM
engine noise when cold This thread Refback Dec 2nd, 2008 09:32 AM
VANOS Oil Pressure Accumulator This thread Refback Dec 1st, 2008 11:11 AM
Astle have a fix ???? This thread Refback Nov 30th, 2008 09:02 PM
engine noise when cold This thread Refback Nov 29th, 2008 02:09 AM
engine noise when cold This thread Refback Nov 28th, 2008 05:35 PM
engine noise when cold This thread Refback Nov 28th, 2008 04:51 PM
engine noise when cold This thread Refback Nov 28th, 2008 04:07 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:30 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:08 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:56 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:49 PM
R56 Mini Cooper S This thread Refback Nov 28th, 2008 04:12 AM
Dealer Experience This thread Refback Nov 23rd, 2008 05:34 PM
Winter Rattles.. This thread Refback Nov 19th, 2008 10:58 PM
Winter Rattles.. This thread Refback Nov 14th, 2008 07:37 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Rattling noise when engine cold berty Second Generation Faults & Fixes 14 Feb 17th, 2008 07:05 PM
Engine noise when cold Pglenning First Generation Faults & Fixes 7 Feb 23rd, 2007 07:10 PM
Knocking noise from engine on MCS DurhamFox First Generation Faults & Fixes 1 Nov 16th, 2005 09:39 PM
Help Funny noise from ENGINE of MCS BRGNICK First Generation MINI Tuning 4 Jun 29th, 2005 02:23 PM
Please help me identify another MCS engine noise. tenderidol First Generation Faults & Fixes 12 Nov 10th, 2004 09:07 AM
