| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (91) | Thread Tools | Rate Thread |
| I don't understand your point. If you are instancing the Pinto engine problem and the Firestone tyre problem as examples of design faults that proved expensive for the manufacturer then I would not disagree that major design faults that lead to serious failures can be costly. I am sure there are other examples. But if you are suggesting they are relevant to the R56 MCS, where no serious consequences of the noise have been reported in the 26 months since it was launched with many thousands of miles covered, then what would be interesting is if you could confirm that these examples did not manifest themselves on vehicles until more than two years and many thousands of miles. I suspect the cases you cite started to become evident quite quickly. I certainly think this was the case with the Firestone tyres. So the longer we go with no serious consequences reported, the more I am convinced that this is a tiresome and unpleasant noise but nothing more serious. |
| Hi Caeser Yes, I am sure. I had my first MCS in July 08 and the fualt displayed with 18 miles on the clock. I went through the process of booking the car in for investigations and they identified the fault and told me of the perm fix promised for December. After much negotiations I agreed a buy back with Mini to receive a replacment vehichle. My new MCS has a build date of Nov 08 and the fault was even worse in the new one. First displayed at 200 miles. The dealership have been very helpful and they were under the impression that the replacement car would be manufactured with the modified part (sadly it was not). They took the car back on the 5th Jan and had it for a week. They told me that they were 100% sure the fault had been fixed. I asked if the modified spring loaded tensioner was used and they said yes. I was guaranteed that the fault was fixed for good. Sadly the fault is not fixed and is as described in my prebious quote. In fact I think I can hear a slight knocking constantly when at about 1000 rpm. My car has only done 600 miles. I have contacted the dealership and I am told the service manager is discussing with the technical people. I think this is a fault that affects all MSC cars but due to peoples driving styles, I think it is only displaying in a smaller number of cars. |
| My 2008 Mini/S is at the dealer now. It has the cold start issue as well. I also have some other issues, the heat does not work very well, I'm down to about 22 mpg in the city, I notice moisture around the oil cap and now they say it has a rear main seal leaking. They have not pulled the transmission out yet so I'm not sure what they will find out obout the rear main seal. I am not happy with the sevice manager at the dealer and Mini USA called me at 5:00 on Friday, one of the questions they asked is "what did you tell the dealer you want to do with the car" I told that at the time I would give them their 3 chances to fix but I told Mini USA I want the car bought back after the added problems they found with the car. The car now has 5500 miles on it and I have had it 8 months. Am I doing the right thing by asking them to buy it back? And what do you guys think they will want to do? Any thoughts will be helpful to me as I have never been in a situation like this. Thanks |
| Mine has done the rattle 3 times. Its an Nov 08 build and I have done just over 1000 miles, always kept garaged. The first 2 times it did it was during that cold spell and the temp was minus 2.5 and minus 5.5...it stopped after around 40 secs, buts as soon as it did it I though "Aha..thats the rattle" It only did it in the morning of those 2 occasions and not at any other time on those days. It did it yesterday though at 8 degrees..I took it out of the garage and onto the driveway which has a gently slope, so car was facing up. It stayed there for a couple of hours as I didn't go out in it yesterday as planned. I started it up to reverse back into the garage ( which is flat btw) and got the rattle for around 30 secs, then it stopped. I've not gone out today and it will be interesting to see if it does it in the morning after being stood up for best part of 2 days. I have to say I not overly bothered at this stage, I ordered the car knowing about the rattle issue and went to my local dealers on Friday and reported it in.They have said it won't damaged the engine and They have a car there in their workshop being fixed that does it every single time its started whether hot, cold, mild etc. I said I'd ring in a few weeks to see if its *fixed*..in the mean time "Lots" will let me know how her *fix* goes as well. I have to say its a great car, I love it, and the rattle doesn't put me off..but it does sound awful. ![]() |
| Hi Lots, My June 07 MCS only makes the noise sometimes if it's parked on the downward slope leading to the garage never anywhere else. On these occasions it can be fixed by turning off the engine and re-starting. I have noticed it does not happen when the barometric air pressure is high. I think it's caused by the oil pump sending aerated oil to the tensioner because the angle it's parked is causing the pump to draw air and oil. The action of doing a restart releases the air allowing the pump to draw pure oil. Possibly there is some connection as well regarding ambient temperature of the oil and the barometric air pressure |
| I'm really sticking my neck out here, so I expect to get my head bitten off. But based on my 25yrs of mechanical engineering experience, the engine in my R56 S is a disaster waiting to happen. I think that the top end rattle on my engine is caused by insufficient oil feed to the appropriate parts..... similar problem as the Ford Pinto engine. I just hope that I am proved wrong? P. |
| I agree with you completely. I was a mechanic for 20yrs and the rattle in my mini engine sound like valve train rattle to me and yes it would be damaging the engine. |
| Mine was doing it at virtually every start but since it has had a new cam chain and tensioner it hasn't done it yet. It was only Friday I got the car back but I'm hopeful. The car does sound slightly different though. ![]() |
| Hi all, just an update from a guy named Tom on the michigan mini motoring site. Tom has got some good technical info and pics, to explain what could be going on with this cold start noise ![]() It is technical but understandable Also the thread is only 12 pages long![]() ![]() You could just read Toms posts and skip the others if you really wanted to cruise thru ![]() Heres the link...COLD START NOISE I had put this on herea while back, but for the benefit of those who don't want to read through thousands of posts here (which says something in itself, maybe it is time to get this petition up! here and abroad)![]() Hope it helps |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html | ||||
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 31st, 2009 12:40 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Mar 29th, 2009 08:29 PM | |
| MINI2.com - MINI Forum | This thread | Refback | Mar 24th, 2009 04:46 PM | |
| My Community | This thread | Refback | Mar 21st, 2009 08:35 PM | |
| MINI Car Club of Indiana Forum - Search Results | This thread | Refback | Mar 19th, 2009 12:45 PM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Mar 19th, 2009 12:24 AM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 10:09 PM | |
| MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? | This thread | Refback | Mar 18th, 2009 09:27 PM | |
| Mini (new bmw versions) Singletrackworld | This thread | Refback | Mar 17th, 2009 03:59 PM | |
| MINI COOPER :: North American Motoring - Clubman S cold engine valve noise | This thread | Refback | Mar 15th, 2009 04:07 AM | |
| MINI COOPER :: North American Motoring - Engine Knock During Cold Start | This thread | Refback | Mar 15th, 2009 03:38 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Mar 2nd, 2009 08:24 PM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Mar 2nd, 2009 08:28 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Feb 28th, 2009 10:26 PM | |
| R56 Mini Cooper S - | This thread | Refback | Feb 27th, 2009 05:20 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 22nd, 2009 09:17 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 05:15 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 04:29 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 04:21 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 02:23 PM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 01:59 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 21st, 2009 11:31 AM | |
| COLD START NOISE | This thread | Refback | Feb 21st, 2009 03:00 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 20th, 2009 11:45 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Feb 19th, 2009 02:51 PM | |
| R56 Mini Cooper S | This thread | Refback | Feb 19th, 2009 12:26 PM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 09:27 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 08:41 AM | |
| Rassel från kamkedja - Sidan 2 - New MINI Club Sweden | This thread | Refback | Feb 19th, 2009 08:09 AM | |
| Engine of the year award | This thread | Refback | Feb 18th, 2009 03:23 PM | |
| MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head | This thread | Refback | Feb 16th, 2009 07:38 PM | |
| One broken Mini! | This thread | Refback | Feb 16th, 2009 12:10 PM | |
| COLD START NOISE | This thread | Refback | Feb 15th, 2009 12:57 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 13th, 2009 11:23 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 11th, 2009 04:37 PM | |
| Winter Rattles.. | This thread | Refback | Feb 7th, 2009 10:40 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Feb 6th, 2009 01:47 PM | |
| Engine of the year award | This thread | Refback | Jan 31st, 2009 11:32 PM | |
| Astle have a fix ???? | This thread | Refback | Jan 29th, 2009 08:19 PM | |
| Fault Register | This thread | Refback | Jan 29th, 2009 01:32 PM | |
| Engine of the year award | This thread | Refback | Jan 29th, 2009 10:03 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 28th, 2009 10:50 PM | |
| Example of noisy start | This thread | Refback | Jan 24th, 2009 04:55 PM | |
| MINI COOPER :: North American Motoring - Cold Start Issues Database | This thread | Refback | Jan 22nd, 2009 02:01 PM | |
| MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles | This thread | Refback | Jan 19th, 2009 01:57 AM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Jan 16th, 2009 02:25 AM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 04:14 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 02:23 PM | |
| Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 | This thread | Refback | Jan 13th, 2009 02:21 PM | |
| General Chit Chatter (Sorry!) | This thread | Refback | Jan 11th, 2009 11:52 AM | |
| Peugeot207Club | This thread | Refback | Jan 8th, 2009 02:10 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 8th, 2009 08:53 AM | |
| MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? | This thread | Refback | Jan 8th, 2009 04:12 AM | |
| R56 Mini Cooper S | This thread | Refback | Jan 7th, 2009 01:53 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Jan 6th, 2009 10:47 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 10:07 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 6th, 2009 07:36 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 6th, 2009 03:07 AM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 08:22 PM | |
| Rattling engine from cold- 08 MCS | This thread | Refback | Jan 5th, 2009 07:16 PM | |
| R56 Mini Cooper S - Index | This thread | Refback | Jan 5th, 2009 01:49 PM | |
| MotoringFile Archive R56 Cold Start Official Fix Coming | This thread | Refback | Jan 2nd, 2009 08:20 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 30th, 2008 10:35 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 29th, 2008 02:51 AM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 28th, 2008 04:35 PM | |
| For all those with faulty engines & those interested - info inside! | This thread | Refback | Dec 26th, 2008 12:24 AM | |
| Fault Register | This thread | Refback | Dec 20th, 2008 08:19 PM | |
| Winter Rattles.. | This thread | Refback | Dec 20th, 2008 05:44 AM | |
| MINI COOPER :: North American Motoring - Engine Rattle After Sitting | This thread | Refback | Dec 18th, 2008 03:21 PM | |
| MINI COOPER :: North American Motoring - Cold start chatter | This thread | Refback | Dec 13th, 2008 07:20 AM | |
| R56 Mini Cooper S - Index | This thread | Refback | Dec 12th, 2008 08:08 PM | |
| R56 Mini Cooper S | This thread | Refback | Dec 11th, 2008 11:18 PM | |
| Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) | This thread | Refback | Dec 4th, 2008 09:38 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 06:45 PM | |
| MINI COOPER :: North American Motoring - Cold Start Chatter | This thread | Refback | Dec 4th, 2008 01:10 PM | |
| engine noise when cold | This thread | Refback | Dec 4th, 2008 12:00 PM | |
| engine noise when cold | This thread | Refback | Dec 2nd, 2008 09:32 AM | |
| VANOS Oil Pressure Accumulator | This thread | Refback | Dec 1st, 2008 11:11 AM | |
| Astle have a fix ???? | This thread | Refback | Nov 30th, 2008 09:02 PM | |
| engine noise when cold | This thread | Refback | Nov 29th, 2008 02:09 AM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 05:35 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 04:51 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 04:07 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:30 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 03:08 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:56 PM | |
| engine noise when cold | This thread | Refback | Nov 28th, 2008 02:49 PM | |
| R56 Mini Cooper S | This thread | Refback | Nov 28th, 2008 04:12 AM | |
| Dealer Experience | This thread | Refback | Nov 23rd, 2008 05:34 PM | |
| Winter Rattles.. | This thread | Refback | Nov 19th, 2008 10:58 PM | |
| Winter Rattles.. | This thread | Refback | Nov 14th, 2008 07:37 AM | |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| Rattling noise when engine cold | berty | Second Generation Faults & Fixes | 14 | Feb 17th, 2008 07:05 PM |
| Engine noise when cold | Pglenning | First Generation Faults & Fixes | 7 | Feb 23rd, 2007 07:10 PM |
| Knocking noise from engine on MCS | DurhamFox | First Generation Faults & Fixes | 1 | Nov 16th, 2005 09:39 PM |
| Help Funny noise from ENGINE of MCS | BRGNICK | First Generation MINI Tuning | 4 | Jun 29th, 2005 02:23 PM |
| Please help me identify another MCS engine noise. | tenderidol | First Generation Faults & Fixes | 12 | Nov 10th, 2004 09:07 AM |
