MCS Engine noise when cold - Page 99 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (91) Thread Tools Rate Thread
  #1471 (permalink)
Old Jan 27th, 2009, 03:08 PM
ShaunSheep's Avatar
Totally maniacal!
Local Time: 12:04 AM
United Kingdom Female View ShaunSheep's Laser Blue & White 2nd Gen MINI Cooper S Profile
Quote: Originally Posted by 118 (original)
mine seems fine now, so I think there is a fix
That's very good to hear Ian
I got my car back this afternoon having had the timing chain, tensioner and sprockets replaced.
Fingers crossed it does the trick...
  #1472 (permalink)
Old Jan 27th, 2009, 04:26 PM
118's Avatar
118
nyahahahaha
Send a message via MSN to 118
United Kingdom Male View 118's Laser Blue & White 2nd Gen MINI Cooper S Profile View 118's Classified Ads
Juuuuuuuuuuuules ooooh fingers crossed that yours is all sorted too then
  #1473 (permalink)
Old Jan 27th, 2009, 05:01 PM
Tracie's Avatar
I'm Back!
Send a message via AIM to Tracie
Local Time: 11:04 PM
United Kingdom Female View Tracie's Pepper White & Black 2nd Gen MINI Cooper S Profile View Tracie's Classified Ads
Perhaps a new thread.. "Mines Been Fixed and it Works! "..or is that a bit optimistic at this stage
  #1474 (permalink)
Old Jan 27th, 2009, 08:35 PM
TDLC's Avatar
United Kingdom Male View TDLC's Chili Red & White 2nd Gen MINI Cooper S Profile View TDLC's Classified Ads
Nah, can always start another thread on top of it, "Mines Been Fixed and Worked; Now Back To Square 1" should there be a need...
  #1475 (permalink)
Old Jan 27th, 2009, 09:13 PM
BRG_07_S's Avatar
Ireland Male View BRG_07_S's British Racing Green & White 2nd Gen MINI Cooper S Profile
I spoke to the dealer yesterday and my MINI is booked in for most of next week to try and sort this fault. Fingers crossed. I was told they will be giving me a 1 series, I hope it is better than the 316i I got last time.
Oliver.
  #1476 (permalink)
Old Jan 27th, 2009, 09:39 PM
T80WEB's Avatar
Webby
United Kingdom Male View T80WEB's Pepper White & Black 2nd Gen MINI John Cooper Works Profile
Angry
I'm really confused, How is it that from the "many" posts on this suggesting that their is a fix for this problem, with some sorted already, which means Mini must have acknowledged the issue, that when I have revisited my dealer this last week, the service manager goes into "auto speak mode", repeating almost word for word what he said 6 months ago, "depends on what the noise, is, whether it goes off after an "acceptable" length of time, etc etc etc" accceptable to who? Will not admit to Mini having a fix.
I really am getting a little tired of this, is there anything I can quote to the guy to get it sorted, it's my wife's car, which means I hear it more from outside the car, and I cannot believe this is not causing some wear!
  #1477 (permalink)
Old Jan 28th, 2009, 06:38 AM
Making it add up
United Kingdom Male View Martin F's Laser Blue & Black 2nd Gen MINI Cooper S Profile
Quote: Originally Posted by Bluebabe (original)
Hi all, just an update from a guy named Tom on the michigan mini motoring site. Tom has got some good technical info and pics, to explain what could be going on with this cold start noise
It is technical but understandable Also the thread is only 12 pages long
You could just read Toms posts and skip the others if you really wanted to cruise thru
Heres the link...COLD START NOISE
I had put this on herea while back, but for the benefit of those who don't want to read through thousands of posts here (which says something in itself, maybe it is time to get this petition up! here and abroad)
Hope it helps
The problem I have with this explanation is that what is described is what I would have called noisy tappets which was common on engines before the advent of hydraulic tappets.
In which case why does the fix seem to relate to the timing chain?
  #1478 (permalink)
Old Jan 28th, 2009, 11:57 AM
Mini-Trainer's Avatar
Morph-a-Doodle
United Kingdom Male View Mini-Trainer's Pepper White & Black 1st Gen MINI Cooper S Profile View Mini-Trainer's Classified Ads
I got mine back yesterday, it seems the problem has been fixed esp with the 'Cold start Rattle'.
Watch this space see if it lasts.
Rams
  #1479 (permalink)
Old Jan 28th, 2009, 12:29 PM
Banned
United Kingdom Male View Bluebabe's Pepper White & Black 2nd Gen MINI Cooper S Profile View Bluebabe's Classified Ads
There is a real possibility that there maybe more than one mechanical area, emitting a similiar noise relating to this "cold start noise"
Tom fromm MMMC has observed the points as per below......
I've read on Motoringfile.com a new update (through the comments) stating that a new spring chain tensioner will solve the problem instead of the oil pressure one.
Looking at Tom's gallery it's clear the the HLA items are very different from "standard industry". So, the above mentioned fix will not solve the problem from its root...
What do you think about this? Is it the cheapest solution BMW/PSA can provide?
I don't know enough about the PSA Prince engine's lube oil system to comment, but in general, cold start noise can only be corrected by 1) reducing dry lash and/or 2) adding a recirculation feature to the HLA, and/or 3) increasing HLA internal oil reservoir capacity, or 4) replacing HLA with self-contained HLA, or 5) replacing HLA with those incorporating the technology described by US Patent 5,622,147 or 6) replacing them with those incorporating proprietary technology such as I am currently developing.
I have personally benchmarked the INA-manufactured HLA which BMW has specified for the PSA Prince engine. It does not have a recirculation feature and the internal reservoir capacity is probably the world's smallest.
It's quite possible that some owners' cold start issues are caused by the chain tensioner, but correcting that issue won't correct issues caused by inadequate dry lash control in combination with a compromised HLA design.
Please note that "cold start" is a relative term. This term refers to an engine which has been run at operating temperature and then allowed to naturally cool to the ambient temperature, usually taking several hours. Parking the MINI on a moderately sloped driveway at an ambient temperature of 95° F can produce the same NVH as might occur at -40°C. The NVH won't last as long because the oil pump supplies oil to the overhead at a faster rate at warm ambient temperatures.
Couper entertains me with about 1 second of valve train NVH every time I start him in the morning after being parked overnight in my garage. The garage floor is level. I have no doubt that Couper's engine exhibits excessive dry lash at most of the 8 exhaust valve positions.
>>tom<<
I'll have to remember to grab it out of Lewis today, but when I was at GR MINI last time, Ashley informed me that MINI has a new service bulletin about the Cold Start Noise. Her tone suggested she believes it as much as I do but her hands are tied, so to speak.
Anyway.. their new line is that cold start noise originates from the vacuum pump. Customers who complain of the noise are to be told (after confirming that the noise comes from the vacuum pump by unplugging it during a cold start and observing that the noise goes away) that it is a "normal characteristic" of the pump.[/b]
Vacuum pump? I don't have a Diesel. Why does the MINI have a vacuum pump? Assuming that there is indeed a vacuum pump, it is possible that there are two noises that occur during cold start, one from HLA and one from the vacuum pump. The thing I find odd about my own cold start noise experience is that the noise is more pronounced around 1,500 rpm than at idle, which is more typical for HLA.
I'm more than a bit surprised that a noisy vacuum pump is a "normal characteristic". To me that indicates less than competent engineering. I'd never try to hide sloppy engineering behind a "normal characteristic" label. They must think we're all stupid. If it was a normal characteristic, 100% of vacuum pumps would be noisy, but obviously it's a lower percentage than that, so that indicates a latent defect. They need to do an 8D and then a recall to replace the faulty pumps.
If after I change to Castrol Syntec SAE 0W-30 my cold start noise disappears, I'll know for sure that this vacuum pump story is a load of beans. Stay tuned.
>>tom<<
These are some of the areas that have been attributed to the noise, unfortunately it might well be that one fix may not be enough!!
Lets hope this is not the case but from our own experiences with the R56 it could well be the case.!..
  #1480 (permalink)
Old Jan 28th, 2009, 04:49 PM
United Kingdom View mike ken's Classified Ads
bad news had the new spring tensioner fitted 3 weeks ago
started it up this morning to hear the noise is back
mini nut
  #1481 (permalink)
Old Jan 28th, 2009, 04:51 PM
started it up this morning to haer the is back
Oh no!!!!
Having said that, who here is surprised?
  #1482 (permalink)
Old Jan 28th, 2009, 07:24 PM
Banned
Nope not surprised either
MINI are trying to do a cheap fix here, so its back to the waiting room folks!!
  #1483 (permalink)
Old Jan 28th, 2009, 07:29 PM
how can a £22000 car sound so bad
spoke to dealer today told me it now needs new timing chain and other bits, will this work ?
mini nut
  #1484 (permalink)
Old Jan 28th, 2009, 07:50 PM
Tracie's Avatar
I'm Back!
I think we arel waiting for 118 to report back that his hasn't worked after all..here's hoping he doesn't..but with a cold snap heading our way next week time will tell.
  #1485 (permalink)
Old Jan 28th, 2009, 08:52 PM
118's Avatar
118
nyahahahaha
hehe well mine's been 10 1/2 weeks since it was fixed and there have been a few cold snaps, etc and I've been making sure it's parked exactly how I parked when the rattle was there........ all still seems to be ok!
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/136105-mini-cooper-s-engine-noise-when-cold.html
Posted By For Type Date
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 30th, 2009 11:40 PM
Rattling engine from cold- 08 MCS This thread Refback Mar 29th, 2009 07:29 PM
MINI2.com - MINI Forum This thread Refback Mar 24th, 2009 03:46 PM
My Community This thread Refback Mar 21st, 2009 07:35 PM
MINI Car Club of Indiana Forum - Search Results This thread Refback Mar 19th, 2009 11:45 AM
VANOS Oil Pressure Accumulator This thread Refback Mar 18th, 2009 11:24 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 09:09 PM
MINI Car Club of Indiana Forum - Buzz Sound when the engine is cold? This thread Refback Mar 18th, 2009 08:27 PM
Mini (new bmw versions) Singletrackworld This thread Refback Mar 17th, 2009 02:59 PM
MINI COOPER :: North American Motoring - Clubman S cold engine valve noise This thread Refback Mar 15th, 2009 03:07 AM
MINI COOPER :: North American Motoring - Engine Knock During Cold Start This thread Refback Mar 15th, 2009 02:38 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Mar 2nd, 2009 07:24 PM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Mar 2nd, 2009 07:28 AM
VANOS Oil Pressure Accumulator This thread Refback Feb 28th, 2009 09:26 PM
R56 Mini Cooper S - This thread Refback Feb 27th, 2009 04:20 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 22nd, 2009 08:17 AM
COLD START NOISE This thread Refback Feb 21st, 2009 04:15 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:29 PM
COLD START NOISE This thread Refback Feb 21st, 2009 03:21 PM
COLD START NOISE This thread Refback Feb 21st, 2009 01:23 PM
COLD START NOISE This thread Refback Feb 21st, 2009 12:59 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 21st, 2009 10:31 AM
COLD START NOISE This thread Refback Feb 21st, 2009 02:00 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 20th, 2009 10:45 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Feb 19th, 2009 01:51 PM
R56 Mini Cooper S This thread Refback Feb 19th, 2009 11:26 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 08:27 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 07:41 AM
Rassel från kamkedja - Sidan 2 - New MINI Club Sweden This thread Refback Feb 19th, 2009 07:09 AM
Engine of the year award This thread Refback Feb 18th, 2009 02:23 PM
MINI COOPER :: North American Motoring - The cold start clatter has caused a conundrum in my head This thread Refback Feb 16th, 2009 06:38 PM
One broken Mini! This thread Refback Feb 16th, 2009 11:10 AM
COLD START NOISE This thread Refback Feb 15th, 2009 11:57 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 13th, 2009 10:23 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 11th, 2009 03:37 PM
Winter Rattles.. This thread Refback Feb 7th, 2009 09:40 AM
Rattling engine from cold- 08 MCS This thread Refback Feb 6th, 2009 12:47 PM
Engine of the year award This thread Refback Jan 31st, 2009 10:32 PM
Astle have a fix ???? This thread Refback Jan 29th, 2009 07:19 PM
Fault Register This thread Refback Jan 29th, 2009 12:32 PM
Engine of the year award This thread Refback Jan 29th, 2009 09:03 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 28th, 2009 09:50 PM
Example of noisy start This thread Refback Jan 24th, 2009 03:55 PM
MINI COOPER :: North American Motoring - Cold Start Issues Database This thread Refback Jan 22nd, 2009 01:01 PM
MINI COOPER :: North American Motoring - 07 MC Engine Replacement @ 5k miles This thread Refback Jan 19th, 2009 12:57 AM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Jan 16th, 2009 01:25 AM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 03:14 PM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 01:23 PM
Lautes klackern nach dem starten - Seite 83 - MINI² - Die ComMINIty - Das große deutschsprachige Forum für alle New MINI One Diesel Cooper S Cabrio John Cooper Works Tuning BMW mini JCW R50 R52 R53 R55 R56 R57 This thread Refback Jan 13th, 2009 01:21 PM
General Chit Chatter (Sorry!) This thread Refback Jan 11th, 2009 10:52 AM
Peugeot207Club This thread Refback Jan 8th, 2009 01:10 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 8th, 2009 07:53 AM
MINI COOPER :: North American Motoring - New MCS Engine Cold Start Noise Problem? This thread Refback Jan 8th, 2009 03:12 AM
R56 Mini Cooper S This thread Refback Jan 7th, 2009 12:53 PM
For all those with faulty engines & those interested - info inside! This thread Refback Jan 6th, 2009 09:47 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 09:07 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 6th, 2009 06:36 AM
R56 Mini Cooper S - Index This thread Refback Jan 6th, 2009 02:07 AM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 07:22 PM
Rattling engine from cold- 08 MCS This thread Refback Jan 5th, 2009 06:16 PM
R56 Mini Cooper S - Index This thread Refback Jan 5th, 2009 12:49 PM
MotoringFile Archive R56 Cold Start Official Fix Coming This thread Refback Jan 2nd, 2009 07:20 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 30th, 2008 09:35 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 29th, 2008 01:51 AM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 28th, 2008 03:35 PM
For all those with faulty engines & those interested - info inside! This thread Refback Dec 25th, 2008 11:24 PM
Fault Register This thread Refback Dec 20th, 2008 07:19 PM
Winter Rattles.. This thread Refback Dec 20th, 2008 04:44 AM
MINI COOPER :: North American Motoring - Engine Rattle After Sitting This thread Refback Dec 18th, 2008 02:21 PM
MINI COOPER :: North American Motoring - Cold start chatter This thread Refback Dec 13th, 2008 06:20 AM
R56 Mini Cooper S - Index This thread Refback Dec 12th, 2008 07:08 PM
R56 Mini Cooper S This thread Refback Dec 11th, 2008 10:18 PM
Bekijk onderwerp - Vreemde geluiden (Diesel-, Tractor-, Ratel- geluiden) This thread Refback Dec 4th, 2008 08:38 PM
engine noise when cold This thread Refback Dec 4th, 2008 05:45 PM
MINI COOPER :: North American Motoring - Cold Start Chatter This thread Refback Dec 4th, 2008 12:10 PM
engine noise when cold This thread Refback Dec 4th, 2008 11:00 AM
engine noise when cold This thread Refback Dec 2nd, 2008 08:32 AM
VANOS Oil Pressure Accumulator This thread Refback Dec 1st, 2008 10:11 AM
Astle have a fix ???? This thread Refback Nov 30th, 2008 08:02 PM
engine noise when cold This thread Refback Nov 29th, 2008 01:09 AM
engine noise when cold This thread Refback Nov 28th, 2008 04:35 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:51 PM
engine noise when cold This thread Refback Nov 28th, 2008 03:07 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:30 PM
engine noise when cold This thread Refback Nov 28th, 2008 02:08 PM
engine noise when cold This thread Refback Nov 28th, 2008 01:56 PM
engine noise when cold This thread Refback Nov 28th, 2008 01:49 PM
R56 Mini Cooper S This thread Refback Nov 28th, 2008 03:12 AM
Dealer Experience This thread Refback Nov 23rd, 2008 04:34 PM
Winter Rattles.. This thread Refback Nov 19th, 2008 09:58 PM
Winter Rattles.. This thread Refback Nov 14th, 2008 06:37 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Rattling noise when engine cold berty Second Generation Faults & Fixes 14 Feb 17th, 2008 06:05 PM
Engine noise when cold Pglenning First Generation Faults & Fixes 7 Feb 23rd, 2007 06:10 PM
Knocking noise from engine on MCS DurhamFox First Generation Faults & Fixes 1 Nov 16th, 2005 08:39 PM
Help Funny noise from ENGINE of MCS BRGNICK First Generation MINI Tuning 4 Jun 29th, 2005 01:23 PM
Please help me identify another MCS engine noise. tenderidol First Generation Faults & Fixes 12 Nov 10th, 2004 08:07 AM
