Slight rattle/vibration driver side seatbelt unit - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 14th, 2007, 10:28 AM
Local Time: 12:04 AM
Hi,
I have a MCS. There is a near constant rattle (esepeciall over 2500 RPM) from where the driver side seatbelt comes from - if I jam my fingers in through the trim to the metal it sort-of stops. Anyone else had this?
Mini had the car yesterday and couldnt find the noise... maybe im being a little picky but its loud to me!
Neil
Old Jul 10th, 2007, 04:08 PM
<Bump>
Noone else got this one? Mini have replaced the trim and its still there - so I would think others might have it too?
Old Jul 15th, 2007, 12:46 PM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
Sorry to hear of your problem. I had a similar noise from the passenger seat belt, and found it was the buckle tapping against the door pillar.
You could try pushing soemthing soft like cotton wool into where the noise is coming from, this might stop it.
Old Aug 24th, 2007, 06:32 PM
Local Time: 07:04 PM
United States View garryjohnson's Chili Red & White 2nd Gen MINI Cooper Profile
DIY seat belt noise
Hi Realevil
Had same problem, dealer could not find noise.
I have found noise and fixed the problem.
Check the sheath around the seat belt buckle, under the sheath there is a heavy WIRE, that is what is making the noise, pull the wire in a different direction,
Windows to roof rattle / vibration sblyth First Generation MINI Convertible 31 Mar 2nd, 2008 11:03 PM
Slight vibration Esham First Generation Faults & Fixes 1 Apr 30th, 2007 12:08 PM
Slight vibration between 2000-2500rpm n00b First Generation Faults & Fixes 7 May 13th, 2006 09:13 AM
smashed side window from seatbelt?? welshminiman General Discussion 10 Mar 18th, 2003 09:24 PM
buzzing/rattle/vibration help Wentworth First Generation Faults & Fixes 27 Feb 22nd, 2003 12:45 PM
