| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| what I have noticed popey especially on the motorway is the amount of wind noise caused by the windscreen wipers. on each stroke there is a loud swishing noise which becomes very annoying on a long wet journey. |
| WIND NOISE. This may not be relevant, but if you set the Heating & Ventilation direction control to the foot-well area with the fan on and drive at 70 mph or more, then you will hear a very high pitched wind noise. Change the direction control to another area, and the noise stops! |
| Don't worry about having the windscreen rebonded Dave, this is a common problem with MINIs and one that is almost always solved in this way. I'm sure Woodmans, or whichever windscreen fitter they use, has had plenty of experience doing it! |
| In fact in my MCS at speeds over 160 km/h there is a constant whistling noise which has nothing to do with the wipers (even if I move them the sound is there). I have found out from some other guys here in Greece who have had the same issue that the problem was solved after removing and glueing back the rubber thing that sits between the windscreen and the roof. I am planning to take a ride to my dealer from September on and I will let you know about the results. |
| At speeds above 85mph I get a 'windy sort of noise' which is difficult to describe! It's a MCS purchased new 05/07/07 with A/C. The sound comes from the area of the heater controls when I have the A/C off, and the air flow directed to the windscreen and the fan on 1st click. It only starts at 85-90 MPH and gets worse as the speed increases. As I reduce speed so the noise reduces, and stops once i get to 80mph. The noise is high pitched......almost like a whistle! Very annoying, maybe the car has a built in sensor to stop it going above the speed limit! |
| Hi All, The car has manual A/C, and the noise occurs at 85mph or more. This is with A/C OFF and air distribution switch set to distribute air to the Windscreen, and fan running at low speed. I've had the car since July 5th this year, and the problem has just started. It would appear to be caused by a surge of air entering the heating/ventilation system causing something to spin and make a high pitched whistling noise. As it only occurs at high speed it is difficult to replicate unless I'm driving on a long open stretch of road. |
| Thank goodness I am not the only one getting wind noise at autobahn speeds - it also happens with a headwind. It seems to be coming from either the front of the sunroof or the top of the windscreen. There are two flappy rubber bits above the a pillars and I wonder whether they are resonating at higher speeds? Really annoying so you have to turn up the stereo and cover it with the distortion from the stereo. |
| wind noise 1400 kms incredible fun and almost faultess, will give a full review of my impressions after 1800 kms and opening her up a bit. When I say almost faultless I am also experiencing this high pitched whistling at motorway speeds its the only issue I have had so far, so very interested to hear what people put this down to. |
| Wind Noise Found out at last how to stop the wind noise I was getting at speeds above 85 mph ![]() Went for a trip just now....the Air Distribution rotary wheel was set 90 degrees i.e air flow to windscreen and blower was on 1st click...no A/C on. As soon as I reached 85 mph the noise started. I turned off the blower...noise continued and got louder at 90 mph. Turned the Air Distribution anti-clockwise one click and it stopped ![]() Have not found the cause, but at least I can stop it happening |
| Tags: problems, r56, wind noise, windscreen |
| Wind Noise?? | KostaLot | First Generation Faults & Fixes | 3 | Nov 23rd, 2006 02:06 AM |
| A/C + Wind Noise | burns863 | First Generation Faults & Fixes | 3 | Jun 26th, 2006 03:56 PM |
| Wind Noise | Aitchy | First Generation MINI Cooper | 7 | Sep 10th, 2004 10:56 AM |
| Road and wind noise | Lylej | First Generation MINI Cooper | 11 | Aug 29th, 2004 02:07 AM |
| Wind Noise | swil00 | First Generation Faults & Fixes | 5 | Aug 10th, 2002 01:17 PM |
