Rough Idle Speed - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 30th, 2007, 02:55 PM
Local Time: 12:05 AM
Rough Idle Speed
Can anyone help? my engine when at idle speed is really rough, it revs away to itself, and you can actually feel it shaking!!!! almost as though its goin to stall!!
This only happens when the engine is warm, and I have had it back to dealer and they said there was nothing wrong with it!!
Old Jul 30th, 2007, 04:15 PM
still learning
Scotland Male
Fooj, the obvious questions are, when did it start doing this ? is it the fuel your using ?
does it need a service ? is your air conditioning on ?
it sounds as if the engine is "hunting" ie it's not happy to tick over smoothly when warm due to most likely a fuel problem or some electrical load causing it to hunt.
could even just be a dodgy spark plug, but I thought the dealer would pick this up with test equipment, then again maybe not.
Old Jul 30th, 2007, 04:35 PM
aid's Avatar
aid
**** You Mr Darling
Local Time: 11:05 PM
Scotland Male View aid's Classified Ads
also take a good look at your engine oil level and if the oil in the car is the correct grade as this can cause your described symptions and if un-treated is normally fatal to the engine!!!!!!!!!!!!!!!!!!!!
06 mcs alta cai gtt re route pipe ngk iridum sparks and big tunes
Old Jul 30th, 2007, 04:55 PM
United Kingdom Male View Simz's Dark Silver & Body Color 2nd Gen MINI Cooper S Profile View Simz's Classified Ads
get dealer to check air-mass sensor - could be faulty and cause your symptons - cannot get the air/fuel mix correct ...worth checking
Old Jul 30th, 2007, 05:42 PM
Dawn's Avatar
Work'd Up !
Send a message via MSN to Dawn
United Kingdom View Dawn's Classified Ads
here try this, a whole thread about it, including my problems which are now sorted ..not just on convertibles either.
http://www.mini2.com/forum/faults-fi...may-build.html
Old Jul 30th, 2007, 05:53 PM
Hello thanks for all your quick replys.
The car only has 4000 miles on it, and im just using normal BP petrol, 95 octane (i think).
The dealer said there was nothing wrong with it, and its never had any oil put it since it got it, and its sittin about midway! so i cant see that being a problem.
The problem disappears with the aircon, with pulls the idle speed up, so its like the idle speed is just too low.
Think am gonna have another go at the dealership, but as per usual they want the car the whole day, and wont give me a courtesy car coz am not 21!!!!!!!!!!
Old Aug 1st, 2007, 10:35 AM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
Put some 98 Ron or higher petrol in, and see if that solves the problem!
Old Aug 1st, 2007, 12:12 PM
Arnbut's Avatar
Manic Hill-Dweller
Local Time: 06:05 PM
United States Male
That's an injector program issue then. Remember that these things run extremely lean at low rev.
There's one report of a couple that was motoring and their car stalled while on the highway. They were lucky to realize it and restart the car before things became critical.
Safety fast,
Bill
Old Aug 23rd, 2007, 12:28 PM
MINI-Morgan's Avatar
MINI Obsessed...
Is it a facelift MCS between july 04 and March 05? I have similar problems but seems to quite common on the facelifts with the old ECUs. I've always had it....but after resetting the ECU it got so much better and only happens very rarely.
Old Aug 28th, 2007, 08:24 PM
Smile
Ive got a similar problem in that i can feel it shaking slightly when warm although mine doesn't rev away to it's self. it gets alot worse when the coolling fan kicks in & you can really feel it then
Tags: , ,
Rough Idle (MOD) bryce03 First Generation Faults & Fixes 6 Oct 26th, 2006 09:22 PM
Rough Idle rerenatorizlnatoizla First Generation Faults & Fixes 10 Oct 10th, 2005 01:35 PM
Rough Idle While Stopped Beaver04 First Generation Faults & Fixes 28 Dec 6th, 2004 10:05 AM
Fuel Mileage and rough idle... IndygoLunaria General Discussion 0 Apr 3rd, 2003 01:57 AM
Rough Idle with CVT btsave First Generation Faults & Fixes 7 Jul 12th, 2002 07:46 PM
