| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| The wheel speed sensor is what I thought, as all the systems looking at the turning speed of the wheels i.e. run flat monitors and traction control are flashing up. And as soon as you settle down to a steady speed it disappears suggesting that the system checks again and sees everything is fine. to KenL, when it first happened i did that but it made no difference. As this is happening more frequently I'm guessing the sensor in one of the wheels is detearating, so just as well its going in on Monday! Jamie1131, did your garage have the part in stock? how long did it take to fix and were you seeing the intermittent fault im seeing? Mary MkII | R56 Cooper S | Performance Torque'd 230bhp & 260lb/ft ![]() H&R Springs | Forge Resonator Delete Hose | Alta CAI | JCW Turbo Inlet Hose |
| Sytner Leicester had it in stock, it took about 2.5 hours from me arriving at the dealer to it being fixed and I wasnt even booked in. Then said MINI emergency services could even do it but the guy that turned up was a sub contractor and didnt have the correct diagnostic equipment. It wasn't intermittent for me, the lights started flashing and then stayed on. |
| I had this problem before and it's resolve. The faulty part is Steering Column Switch Cluster. Have it replace with the new one, which have to be re-programme 1st, problem solve but spend some bucks on it. |
| Tags: traction control |
| Traction Control on/off | Adamm1985 | General Discussion | 3 | Jul 11th, 2007 06:51 PM |
| Traction Control | Angel_1701 | First Generation Faults & Fixes | 0 | Dec 17th, 2005 01:25 PM |
| Traction Control | Wooly | First Generation MINI Cooper | 17 | Sep 9th, 2005 07:11 PM |
| Traction Control ON or OFF ? | dantes | General Discussion | 3 | Mar 19th, 2003 11:36 AM |
| Traction Control | NutTheBus | First Generation MINI Cooper | 10 | Apr 9th, 2002 07:09 PM |
