Ripped Off.. Or At least Mislead!!! - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Nov 13th, 2007, 01:44 PM
ALD0's Avatar
Local Time: 12:05 AM
Quote: Originally Posted by Rakey (original)
you know what assume does?
it makes an ass out of u and me
never assume, always read anything you pay for or sign up to
David Brent classic!
Yeah, £220 seems reasonable enough, although I would of personally like a courtesy call to me first to tell me the work needs doing.
  #17 (permalink)
Old Nov 13th, 2007, 01:45 PM
ALD0's Avatar
Quote: Originally Posted by ScoobyDoo (original)
As per my slight hijack earlier in the thread, my Mums Cooper has had pads and discs changed at 15k miles - yet her previous Cooper didn't have them changed til about 25k miles.
I think it depends on a lot of things.
My Red Coop were that @ 25k?
  #18 (permalink)
Old Nov 13th, 2007, 03:54 PM
ScoobyDoo's Avatar
Back in a first gen.
United Kingdom Female View ScoobyDoo's Solid Black & Black 1st Gen MINI Cooper S Convertible Profile View ScoobyDoo's Classified Ads
No, sorry Si, I meant the silver one that she had before.
Yours she never had changed, I don't think.
  #19 (permalink)
Old Nov 13th, 2007, 05:08 PM
Local Time: 11:05 PM
View bond101's Classified Ads
Apparantly the pads have 6000 miles left on them, I appreciate that for £150 perhaps free brakes was little much to expect however, I thought they should last a little more than 17000 miles, alot of other manufacturers just replace the discs when they wear at this mileage under warranty, oh well, its just more money to spend, should of bought a veyron, in for a penny in for a pound!
  #20 (permalink)
Old Nov 13th, 2007, 08:06 PM
Loui's Avatar
230whp an counting
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Loui's Classified Ads
They have changed discs an not pads?????
Isnt that a classic way of knackering discs?
  #21 (permalink)
Old Nov 13th, 2007, 10:06 PM
View oldnell's Solid Black & Body Color 1st Gen MINI One Profile View oldnell's Classified Ads
This is crazy.
So, TLC doesn't cover brakes and pads as the documentation will have stated when you bought it (but not discounting bad sales advice from your dealer).
However, I can't believe what your dealer has done here. Firstly, they've done work without your authorisation. Given that, they have no right to expect payment and you should not pay them. If you do end up having to pay in this circumstance (i.e. because you want your car back and the dealer knows this), pay by credit card, write "paid under protest" on the invoice and make sure you get a copy. Then follow up with your credit card company.
Secondly, why did they say the discs needed replacing? If they measured the thickness and it was just below the thickness stamped on the disc, but otherwise fine (i.e. not warped) then they're bull******** you. I would have asked to keep the parts (which are yours to keep), although there's not a lot stopping them finding any old set of worn out discs from their workshop and telling you they came from your car.
After 17k, this is surely indicative of a fault and they should be going through the warranty claims process for this, not charging the customer.
What the hell are they doing changing discs and putting the old pads back on? The cost of new pads compared to the labour (and they have to remove the pads to replace the disc, of course) is miniscule. As Loui says, that's very bad.
Finally, they're charging more for replacing discs only than my dealership charges for discs and pads.
I think the rule with the disc thickness is that at the time of replacing pads, if the disc measures less than the thickness stamped on the shell then the discs should be replaced. That doesn't mean that if the disc thickness falls below that they should be replaced. At 17k miles, this is irrelevant anyway -- there must be a fault for discs to need replacing if the pads haven't worn.
Care to name and shame the dealer?
Oli
  #22 (permalink)
Old Nov 13th, 2007, 10:22 PM
They're probably hoping that Andrew doesn't notice when the pads need replacing, hears the sound of crunching brakes and returns to the dealer. "Your discs were scored sir, so we've replaced them for you" ££££
Cowboy dealers are what give Mini and BMW a bad name. Unfortunately there are far too many of them about.
Andrew, I'd think a good well-written letter to your dealer and Mini Customer Service might do wonders here. What your dealer has done is absolutely shocking.
Once you've got your money back, never return to that dealer. They don't deserve your custom.
I'd still like to know which dealer it is, out of curiosity.
Oli
  #23 (permalink)
Old Nov 15th, 2007, 09:22 AM
still learning
Scotland Male
agree with everything Oli has said, you have been ripped off by cowboys, and the job has not even been done properly.
  #24 (permalink)
Old Nov 15th, 2007, 01:43 PM
ScoobyDoo's Avatar
Quote: Originally Posted by oldnell (original)
So, TLC doesn't cover brakes and pads as the documentation will have stated when you bought it.
Whilst I agree with majority of what you said - shouldn't have needed changing yet / MINI should have asked/informed you first. I do disagree with the above.
In the R56 TLC book - Terms & conditions, point number 2...........it does state that TLC does not cover repair and maintainence items such as tyres, brake pads, top ups etc.
Its the etc bit thats MINI's get out.
  #25 (permalink)
Old Nov 15th, 2007, 02:30 PM
the undertaker's Avatar
dooper loopy club man
The only thing they should have done is come and spoken to you, explained these parts were required and seeked your approval.
Life begins at MINI....
Tags: , , , , ,
Am I being ripped off? zip nolan General Discussion 4 May 27th, 2005 07:42 PM
Am i being ripped off? minifanatic General Discussion 36 Jul 18th, 2004 10:19 PM
Got Totally Ripped Off ashley adam Wheels, Tyres & Brakes 10 Nov 4th, 2003 02:58 PM
Help - Being Ripped off By Dealer S200 First Generation MINI Cooper S 14 Jun 11th, 2002 06:24 PM
MFSW - have you been ripped off? groovy_jr First Generation Interior & Ice 7 Mar 12th, 2002 05:27 PM
