| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (2) | Thread Tools | Rate Thread |
| Lawro, thanks for the update. Hope this dealer is able to fix the problem... The R56 Turbo does have a 'bypass' valve that bypasses excess boost around the turbo. This bypass valve is actuated via a vacuum diaphragm which is controlled via vacuum fed from solenoids. These solenoids are controlled by the engine management system. I suspect the software is leaving the bypass valve open when it shouldn't... but proving it is not that easy... ken |
| Just to add to this.. We took our Mini out on Saturday and had the same issue. Driving the car it was just like a 1.4, just had no get up and go. Car had no warning lights on or anything, but just no power. Stopped the car and left it, after re-starting it was all back to normal again. Have dropped the car into Cotswold BMW to see if they can find anything, but I am not expecting much. |
| Well not sure if it helps, my mrs had the call this morning to say the fault is caused by the high pressure pump ? and will be fixed tomorrow, Will find out more tomorrow when I'm home |
| Well the car came back today as did I, the car feels great. ![]() The bad news is I have no more info, all the job sheet says it's the High Pressure pump has been removed and replaced. So sorry I can;t say anymore. The work was completed by Cotswold BMW in Cheltenham |
| Well here's my update. The car has been with the dealer since yesterday to have the ECU reflashed in the hope it solves the problem (it was pretty bad last week - I accelerated away in 1st/2nd/3rd gear and it was like the handbrake was still on - it wasn't!). Unfortunately it keeps crashing on updates so hopefully I'll get it tomorrow. |
| Hi Joe I work at Stansted Airport so have used Elms as a matter of convenience, I live in Witham so also use Cooper's in Chelmsford who recently have been very good, I've had a complete timing gear change recently and they kept me informed throughout. Saying that I must also praise Elms who were also very good. If you're interested mate our club ESSEX MINI2 has a couple of members over your way so if you fancy coming to any of our meets feel free! all the best Den |
| Tags: turbo |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/149793-no-turbo.html | ||||
| MINI COOPER :: North American Motoring - Feels Like Turbo Dies Out | This thread | Refback | Jan 1st, 2009 11:17 PM | |
| MINI COOPER :: North American Motoring - Odd loss of thrust | This thread | Refback | Dec 11th, 2008 05:47 AM | |
| Is the New Turbo? | accce | Second Generation MINI Cooper S | 5 | Jan 12th, 2007 01:25 AM |
| Turbo | baraboab | First Generation MINI One | 17 | Oct 16th, 2006 06:21 PM |
| Turbo ? Can It Be Done | Jacked up | First Generation MINI Tuning | 4 | Sep 1st, 2006 05:42 PM |
| Turbo!! | Louisxiii | Second Generation MINI Tuning | 21 | Sep 8th, 2005 04:02 PM |
| Turbo.... | Vesterdux | First Generation MINI Tuning | 13 | Jul 5th, 2002 05:34 AM |
