| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| | LinkBack (2) | Thread Tools | Rate Thread |
| Since originally starting this thread, I've made a few observations. Driving my car hard, on hill roads, on hot days, revving the engine hard, doesn't cause the fan to come on. Recently I've started to do long distance commutes (40 miles or so each way) and I never hear the cooling fan come on. I previously did shorter journeys and drove gently, so perhaps it is just related to short journeys? |
Active Regeneration Cycle Problem Solved!! I called Mini Assist out for a heater problem (I have aac and it got stuck on very hot - oven like!). The same morning on arriving at work (M1, 70mph, 0°C....etc.) the fan was wailing away. When the bloke plugged the car into the computer, I asked him about this and he was clueless: His answer was that he didn't know because he doesn't see many Cooper D's due to their reliability. After a little push, he went through the computer and brought up the regeneration data for the cat-filter system. The time since an active regeneration cycle was 0 miles, i.e. it was doing it that morning. It is a normal part of how the Cooper D works unfortunately, but the guy did say that the car SHOULD do this at motorway speeds, which begs the question: When I travel such a massive distance on the motorway (140 miles/day), why do this when I get to a town/city!! Super_Dooper_Cooper £35 Tax, 60mpg, Sticking it up to the Government! |
| Yes, it is the old Particulate gubbins (Technical for don't really know what it does) doing its job, and by the way, the auto stop-start doesn't work when it is going through that cycle! You will get it kicking in more often if you drive steady or short miles as the engine/exhaust temp doesn't get hot enough to burn the excess particles in the filter! My dad has got a diesel Jag and it does just the same thing, and as he does short journeys it does it quite a lot! |
| Tags: cooper d, fan |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/second-generation-faults-fixes/150243-cooper-d-cooling-fan-freezing-temperatures.html | ||||
| Bekijk onderwerp - Cooper D overdreven draaien van radiator | This thread | Refback | Jan 31st, 2009 03:22 PM | |
| Bekijk onderwerp - Cooper D overdreven draaien van radiator | This thread | Refback | Jan 3rd, 2009 02:30 PM | |
| Cooling Fan | Howie | Maintenance & MINI Care | 0 | Oct 14th, 2007 07:47 AM |
| Cooling Fan | minidonut | First Generation Faults & Fixes | 3 | Apr 3rd, 2007 05:03 PM |
| HK or Boost noise & static with cold temperatures | jwardell | First Generation Faults & Fixes | 15 | Mar 13th, 2005 02:34 PM |
| Freezing Windows | kezman50 | First Generation Faults & Fixes | 4 | Jan 25th, 2005 01:23 PM |
