Look for the white nylon screw behind and inboard (towards the center of the car). It's in there down low... but once youve found it, it's easy to adjust.
Some have phillips heads and others allen... be careful so you don't strip the head (it should take too much effort to turn).
Also be aware... with xenons: a little bit of ajustment goes a LONG way.
Founding member of R56 Anonymous: "Hello. My name is Mike. I'm a driving enthusiast... and I still like the R56"
I took mine to the dealer... they adjusted them too high. They were blinding other drivers and I was getting flashed constantly. I needed to figure it out in order NOT to be blinding other drivers and I didn't want to driver the three hour round trip for this simple proceedure. How do you know the OP isn't experiencing the same? It's a 50-50 possibility, right? Better to learn how to PROPERLY adjust them yourself IMO.
The car has now been to the Dealer four times, it is my wifes car and she is a midwife and travels home on unlit roads late at night, after the Dealer adjusted the lights one time she was subjected to a frightening attack of road rage. It quite upset her. We go from being able to pick out the moon to having to drive at 30 (or less) in the dark on dipped due to the lights shinning about 3 metres in front. The Dealer seems incapable of adjusting them a small amount. Sadly this seems typical of Mini Dealers (certainly in our area). I'm glad I sold my S after a few weeks ownership.......
There are two white nylon screws, one toward the centre of the car and another near the wing, I presume one adjusts left and right and another up and down, any one know which is which?
I had a fiddle about with mine ready for a euro trip next week. i fear i have just buggered it up.
in another thread i was told that the levers are inside the headlight unit (two white levers), my dealer also pointed this out to me. what are you guys talking about with the screws???
My question however is regarding the 'clicks' for uk roads is it
right headlight = click up
left headlight= click down
Xenons shouldn't really need adjusting if they were set properly and working properly as the self levelling sensors on the suspension should adjust the lamps automatically according to the load (to avoid dazzle), Halogens you move the switch in the passenger compartment (manually), however as most of you will know the screws on the lamps alter the beam, this is to fine tune them.
This seems to come up often on MINI2 and there is always a little confusion, here is a post that I did a while back in-fact the whole thread maybe worth a read , just click on the (original) of my quote , although the advice was for the 1st Gen BMW MINI it also applies to the 2nd Gen.
Destined to live life £5 behind. Disclaimer
Any advice given is my opinion only, if you decide to act on any advice / info I've given, it's at your own risk!
