High Pitch whining noise - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 9th, 2008, 06:33 PM
Local Time: 12:07 AM
United Kingdom View rust bucket's Classified Ads
Does anyones Mini make a strange high pitch whining noise after switching off the engine?.
If I lift the bonnet the noise is coming from the area of the turbo/ EGR valve and continues for about a minute.
Old Mar 9th, 2008, 06:45 PM
merv's Avatar
nice
Local Time: 11:07 PM
United Kingdom Male View merv's Astro Black & Body Color 1st Gen MINI Cooper S Profile
Sounds an awful lot like the it is the cooling fan to me - in which case nothing to worry about
Old Mar 9th, 2008, 06:48 PM
caesar's Avatar
United Kingdom Male View caesar's Chili Red & Body Color 2nd Gen MINI Cooper S Profile
The whining noise after switch off could be from the electric water pump that cools the Turbo, this is quite normal. If it's very noisy then let the Dealer have a look. Mine runs for about 5-10 minutes after turning off the engine dependent on how hot the turbo is.
Old Mar 9th, 2008, 06:53 PM
astilla's Avatar
Hmmmmm
Send a message via MSN to astilla Send a message via Yahoo to astilla
It mentions this in my user manual (and will probably be in yours) - says it's perfectly normal
1988 Mini 'Designer' & 2008 MINI Cooper 'S' Works (photos on Flickr)
Old Mar 9th, 2008, 07:28 PM
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI John Cooper Works Profile View supa-dupa-cooper's Classified Ads
My Cooper D has a high pitched noise when switched off as well. Was going to ask this question but you beat me to it
It does turn off after a while, but I noticed mine came back on again when I was cleaning it the other day? Is that normal?
Old Mar 9th, 2008, 07:40 PM
jamesbeaumont's Avatar
Addicted to MINI...
Send a message via MSN to jamesbeaumont
Scotland Male View jamesbeaumont's Chili Red & White 2nd Gen MINI Cooper Profile View jamesbeaumont's Classified Ads
Puzzle is alive! I'm pretty sure its normal...
Chili Red R56 Cooper aero kit side repeaters, ITG panel filter, Eagle F1 GSD3's, Silver vision bulbs and soon to have a cat back exhaust and chip
Old Mar 9th, 2008, 08:16 PM
caesar's Avatar
If you read my earlier post on this topic, I said it was the Turbo cooler pump running as it was a Cooper S. I don't think the Cooper D has a Turbo
The only cause I can think of is it's the Electric Radiator Cooling Fan, but cannot understand why it would run if you only moved the car to clean it unless the car had been driven for a while before you cleaned it
Old Mar 9th, 2008, 08:40 PM
The Cooper D does have a Turbo
The car had been for a run before coming home to clean it. At first the noise was there, then as I was cleaning the front alloy I heard it go off. I came back round to polish the front alloy about 10 minutes later and the noise was going again?
Old Mar 9th, 2008, 09:07 PM
Factory JCW
United Kingdom Male View neilobe's Classified Ads
Mine does this noise too especially after a good run
Factory JCW
Old Mar 9th, 2008, 09:29 PM
caesar's Avatar
My apologies to owners of Cooper D's did not know they had Turbo's
In that case it's the Turbo cooler running, the fact that it came on again later is due to the thermostat sensing an increase in temperature due to the principal that 'hot water rises'. So you have nothing to worry about because all is functioning OK
Old Mar 9th, 2008, 09:30 PM
Phew!
Old Mar 10th, 2008, 07:02 AM
Stiggy's Avatar
MINI memories...
United Kingdom Male View Stiggy's Sparkling Silver & Black 2nd Gen MINI Cooper Diesel Profile
I don't think it's the turbo, it sounds more electrical to me.
Any ONE/Cooper (non-turbo) owners heard it?
Old Mar 13th, 2008, 06:02 PM
Addicted to MINI...
I have had something similar in my cooper but didnt pay much attention to it, it didnt go on for as long as a minute though. I thought it was either the ignition of fuel pump...
Old Mar 13th, 2008, 09:15 PM
It's definately an electrical noise of some discription, it doesn't sound like a pump running, more like a gaint mosquito.
I'm not worried about it, just curious to know what it is and I can't be bothered to go to the Dealers
  #15 (permalink)
Old Mar 14th, 2008, 08:08 PM
Sid-Clubman's Avatar
Male
Doesn't sound like a pump, my Clubman D makes a sound like high pitched electrical whistle.
Sounds like it is at the rear of engine area.
jcw whining noise at 2000 rpm JCW225 Maintenance & MINI Care 0 Nov 26th, 2007 10:24 PM
High Pitch Whine A/C nevillejnr First Generation Faults & Fixes 5 Apr 1st, 2006 07:24 AM
Whining Heater Fan Noise?? MINNOW First Generation Faults & Fixes 0 Nov 18th, 2005 06:48 PM
whining noise muisje S First Generation MINI Cooper S 9 Oct 23rd, 2005 09:32 PM
