Metalic squeak from rear end - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 18th, 2008, 07:05 PM
Matt FT's Avatar
Local Time: 12:07 AM
Question Metalic squeak from rear end
Hi guys,
500 miles on my Clubman S and loving it.
Only issue so far is a very annoying metalic metal on metal sort of squeek from the rear end, audible in the car at all speeds. Seems to be caused by flexing (so changed in camber of road or bumps on one side not the other).
I've tried making sure the rear seats are locked in properly and nothing is lose in the boot, but to no avail.
Before a trip to the dealers, anyone got any ideas?
Old Mar 24th, 2008, 07:24 AM
ThatsMe's Avatar
Local Time: 09:07 AM
Australia Male View ThatsMe's Astro Black & Body Color 2nd Gen MINI Cooper S Profile
I think i have the same little noise, but mine seems to come and go, so im not sure what it is.
When everything's coming your way, you're in the wrong lane.
Old Mar 25th, 2008, 10:14 AM
steve11's Avatar
Mad Modder
Australia Male View steve11's Electric Blue & Body Color 1st Gen MINI Cooper S Profile View steve11's Classified Ads
Rear sway bar mounts may need greasing ?
Old May 26th, 2008, 12:52 AM
awil88
Local Time: 10:07 AM
Australia Male
Quote: Originally Posted by Matt FT (original)
Hi guys,
I seem to have the same prob. Did the dealer fix the fault? What is it?
Old May 26th, 2008, 07:31 PM
Matt FT's Avatar
No solution yet. Going back to dealer for the third time soon for get this fixed, along with my broked roof rack
Old May 28th, 2008, 10:15 AM
mu5c13b0y's Avatar
I have just borrowed a clubman while my cooper d is being sorted, I have the same squeek in the back!!
Old May 28th, 2008, 10:30 AM
Matt FT's Avatar
aw crap, looks like a common clubman problem.
Old May 29th, 2008, 08:31 AM
ThatsMe's Avatar
I have a MCS and have the smae squeak.
Old May 29th, 2008, 10:26 AM
simeds's Avatar
Grumpometer: OFF SCALE
Send a message via MSN to simeds
United Kingdom Male View simeds's Classified Ads
i'm getting a squeak from the rear left handside (petrol filler cap side), it started the otherday just after i'd filled in the post marketing survey and answered '' No'' to the question about squeaks and rattles.
It came after i'd had the back seat down for moving some garden waste to the dump. As far as I can tell it only happens when the seat is up, so I assume its coming from the latch mechanism, - but need to do a bit more driving to be sure.
UPUBMNJOJ.DPN
Old May 29th, 2008, 10:39 AM
Pep71's Avatar
United Kingdom Male View Pep71's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
I had the same type of squeak on my MCS at the rear. Not sure if yours is the same but I put some electrical tape around the metal loop that the rear seats clip into when they are up and it has stopped the noise.
Mine sounded like metal rubbing on metal.
Old May 29th, 2008, 10:51 AM
simeds's Avatar
mines a metal on metal sound, i might give your solution a try
UPUBMNJOJ.DPN
Old May 30th, 2008, 08:45 AM
ThatsMe's Avatar
Mines a metal on metal sound, but only around speeds of between 65-80km, and only every now and then.
Old Jun 1st, 2008, 03:16 AM
awil88
Australia Male
Thanks Pep! The electrical tape solved my problem... i've been going insane the past week since picking up my car. I called the dealer but they had no idea what was what. So thanks again
Old Jun 5th, 2008, 07:35 AM
Matt FT's Avatar
dealer has confirmed it's the metal clip holding the rear seats up. They're installing a new clip. If that doesn't work I'll go for electrical tape.
Glad it wasn't anything in the mechanicals...
  #15 (permalink)
Old Oct 10th, 2008, 12:35 PM
Yellow/Black OneD's Avatar
Clubman D
United Kingdom Male View Yellow/Black OneD's Mellow Yellow & Black 2nd Gen MINI Cooper Diesel Clubman Profile
Have MINI now got a fix for this or shall I get my electrical tape out?
Tags: , ,
rear squeak or creak aid Second Generation Faults & Fixes 3 Oct 18th, 2010 06:24 AM
Wierd Squeak/Click noise from rear of car when STATIONARY "tink" Cooooooperslad First Generation Faults & Fixes 0 Aug 25th, 2007 10:14 PM
unstable rear end george p First Generation Faults & Fixes 8 Jul 19th, 2006 06:13 AM
Banging Rear End AberdeenMini First Generation Faults & Fixes 6 Feb 17th, 2004 11:58 AM
Squeak...squeak...squeak from the engine bay? v8voodoo First Generation MINI Cooper S 15 Dec 31st, 2003 05:19 PM
