A few little problems - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 9th, 2008, 07:13 PM
Local Time: 08:12 PM
Hi all,
If got a 57 plate Mini One and have noticed a few problems that dont seem quite right considering its a brand new, ill put up the list and can you let me knwo if you have the same issues and what youve done about them.
1) Drivers window seems to creak/squish against the door seal when going over rough surfaces.
2) Water comes in the top of passenger window when washing, only a little though.
3) After winding windows up the inside of front windows get a covering of moisture in the very front bottom corner as if door wet on inside.
Anyone else have these problems?
Matthew
Old Apr 10th, 2008, 03:23 PM
Local Time: 09:12 PM
England Male View Boro Boy's Eclipse Grey & Body Color 2nd Gen MINI Cooper S Profile
If your door seals are letting water through, I would get your dealer to have a look.
Regarding the creaking ... I had the same, and followed KenL's useful advice on getting some "Gummi Pflege" stuff. I apply it to the door seal rubbers (just the sections where the windows contact) every so often. Solves the creaking.
Old Apr 10th, 2008, 03:37 PM
I've got the driver's window issue too, one of the things on my 'list to get fixed', but it doesn't seem to leak.
Also sometimes hear a noise like something gently tapping the glass, at least that's what it sounds like. Comes from both sides too
Old Apr 10th, 2008, 05:53 PM
KenL's Avatar
Yes - Gummipflege (available from BMW dealers at about £3) will cure the noise from dried out rubber against glass.
On the window that leaks, is the window going up properly when you close the door. Try resetting the position of them by holding up the levers for 5 seconds or so when the doors are closed.
If not, get the dealer to have a look at it.
Old Apr 10th, 2008, 06:12 PM
Thanks, ill give that a go, i didnt realise you could reset them, maybe i should try reading the book!!!
Old Jan 16th, 2009, 12:31 PM
Local Time: 06:12 AM
Australia
I have recently had some significant warranty issues rectified on my 07 MSC... These included a new fuel pump and new gearbox. By the way thank you to all users of mini2 as it has helped me get an understanding of why my car had these probs and that i wasn't alone... The dealer had no explanations (AS USUAL) except to say "nothing is bulletproof". Doing my own reading I learned that the fuel pump was due to using ethanol blended fuel and the gearbox was related to the screeching sound it makes between the 2nd and 3rd gear which I honestly didn't think too much of...
Anyhoo, I am wondering whether these parts (fuel pump and gearbox) have been replaced with superseded parts or they have simply wacked the same thing back on...? It troubles me that a gearbox and fuel pump have a shelf life of a mere 18 months!!!
Secondly (and on another topic) has anyone else had a dealer service tech tell them that they should be flogging their car (which is aussie lingo for "driving hard"...). I found it kind of wierd but it made sense as he said that the MCS have performance engines and should be driven hard... Is this true? if so to what extent can you drive them hard?
Thanks again.
Tags: , ,
Has anyone else had problems with the dealer only half-fixing problems? Clurcle General Discussion 3 May 25th, 2006 05:40 AM
On going problems...What happens next? Lilly-May First Generation Faults & Fixes 15 Jan 30th, 2003 08:16 PM
problems yes/no RACER X First Generation Faults & Fixes 16 Jan 8th, 2003 08:08 PM
problems with my s Rynyin First Generation MINI Cooper S 12 Sep 18th, 2002 12:16 PM
problems? tomorthway MINI in the Media 0 May 20th, 2002 03:15 PM
