Screeching drivers window - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 12th, 2008, 10:25 PM
miniman23's Avatar
Local Time: 12:08 AM
United Kingdom Male View miniman23's Solid Black & Body Color 1st Gen MINI Cooper S Profile View miniman23's Classified Ads
Hi all,
This may be a silly question but I will ask it anyway, when drivers side window goes down it works fine but over the last few days when the window goes up it screeches. This happens whether the door is open or closed. I'm guessing some dirt rubbing on window on that long horizontal cushion thing seal but cant see any. Its well annoying any ideas anyone how I can solve this?
Paul
Old May 13th, 2008, 05:04 PM
Mini R56 S LiB/B
United Kingdom Male View Queb's Lightning Blue & Black 2nd Gen MINI Cooper S Profile
Yeah I had this also, but to solve it I cleaned the rubber seals down with some Zymol Seal out of my cleaning kit.
Zymol Seal for Rubber (200ml) 803
Might be slightly expensive though, otherwise get your Mini dealer to clean it with whatever they use under warranty, hope that helps,
Ste.
Mini Cooper S R56 Lighting Blue/Black now fully run in !
Old May 14th, 2008, 05:21 PM
miniman23's Avatar
Ste.
Many thanks for that, are you talking about doing this on the horizontal seal at the bottom of the window? As the screech noise happens when door is open as well and wont benefit from doing it to the two side seals. Also I found out today it only does this when its warm this morning 5 am it was fine but when a bit of sun was out for a while it started to do it.
Cheers.
Old May 14th, 2008, 06:25 PM
Mini R56 S LiB/B
Cheers.
Ooops sorry no, I should have read your post a little better
Sounds like a warranty job I'm afraid unless someone else knows better
Old May 14th, 2008, 08:07 PM
miniman23's Avatar
Oh no not another warranty job, already had 3 done. Thanks anyway.
Tags: ,
drivers window needs adjusting - help! jaynlisa08 First Generation Faults & Fixes 0 Apr 12th, 2008 09:42 PM
Drivers Window Not Working Aberdeen Al First Generation Faults & Fixes 0 Sep 19th, 2007 07:11 PM
drivers window wont go down :( Mini_Power16 First Generation Faults & Fixes 8 Jan 1st, 2007 03:52 PM
Screeching passenger window IH1 First Generation MINI Exterior 10 Oct 20th, 2006 07:46 PM
Screeching passenger window IH1 First Generation Faults & Fixes 1 Oct 19th, 2006 09:18 PM
