Ipod with Feb 09 built cooper - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 1st, 2009, 06:08 PM
Mini William's Avatar
Local Time: 11:10 PM
Scotland View Mini William's Chili Red & Black 2nd Gen MINI Cooper Profile
I have a 3rd Gen Ipod Nano and it does not work with my USB in my new Cooper (just under the A/C controls) but my mums ipod shuffle works in the USB .Can anyone help??
Old Mar 1st, 2009, 10:52 PM
Local Time: 04:10 PM
United States Male
Are you using the MINI supplied Y-Cable? The USB port can only control the iPod using the older serial communication and the MINI Y-Cable has a built-in USB to serial converter. The DRM on the audio files makes it necessary for the iPod to decode the files and play them through the AUX port.
IIRC, the iPod shuffles are basically Apple thumb drives without the encryption of the other iPods, which lets the car read the MP3s directly.
Curious if your cell works with the Second Gen MINI?
See the R56 MINI Bluetooth Cell Compatibility Matrix
Old Mar 2nd, 2009, 10:20 AM
Thanks.But my old Gen 1 Nano works fine in the car with just the Ipod lead
William
Old Mar 2nd, 2009, 11:32 AM
Local Time: 12:10 AM
There is a problem with the new generation ipods not working with old cables ( i think its something to do with firewire). A colleauge at works new ipod won't charge using an ipod charger. but it works ok on an older generation ipod. I think you need to get a new compatible cable. Check out the ipod forums for details.
Old Mar 2nd, 2009, 11:38 AM
Thanks ill get one from the garage
Old Mar 3rd, 2009, 08:07 PM
Troy's Avatar
Wanted a JCW!!
United Kingdom Male View Troy's Chili Red & Body Color 2nd Gen MINI One Profile View Troy's Classified Ads
Yeah you need the Y cable, the iPod isn't new enough for it to be the Firewire removal issue. Go and pay the stealers a visit!!
It's a Mini Adventure.
Old Mar 3rd, 2009, 10:00 PM
United States Male
The changes to the newer gen Apple stuff (iPhone 3G, 4th Gen nano, and the 2nd Gen iPod Touch) removes the firewire connection (see: iPod, Connectivity), but for the MINIs this only effects charging capability, everything else should work.
NewMiniStuff sells a connector to adapt plugs that charge using the firewire connection to the newer USB.
Any non-DRM MP3's saved to an iPod in generic storage mode will play fine using the iPod lead, maybe that's how your're playing audio with the nano?
Old Feb 14th, 2012, 06:12 PM
Hi all, in what seems like ages away, prob second week of April I will get my MCS R57
Included within my is Chilli, Visual Boost, HK and Full Blue Tooth. I know that USB sticks will work fine My question is, will I be able to play videos from either a Nano 3rd Gen or Nano 4th Gen on the Visual Boost Screen. Will the cable that is supposed to come with the car with this spec allow me to do this.
Many thanks Pips - A
LL4 - let's get dirrrty! Sun Feb 22nd **registration closing 5.00pm Sat Feb 21st** Shamster UK & Ireland Discussion & Event Planning 195 Mar 2nd, 2009 08:13 PM
Middx Mini Maniacs Feb Run - 1st Feb 2004 Shamster UK & Ireland Discussion & Event Planning 115 Feb 6th, 2004 12:00 PM
Is the bypass valve built into the Cooper S Eaton? LMB First Generation MINI Tuning 3 Dec 22nd, 2003 07:44 PM
Anyone built a heatshield for a K&N filter in a Cooper? slegorreta First Generation MINI Tuning 1 Aug 4th, 2002 04:47 PM
pre 03/02 built Cooper info!!! chris@helix First Generation MINI Tuning 6 Jun 25th, 2002 04:27 PM
