| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| Bizarre windscreen washer failure - please advise...!!! Hi guys Just driving home from work and tried to clear the bugs from the windscreen - no washer fluid. So popped the bonnet when I got home to top her up (was a bit confused that I hadn't had the warning from the car) to find the rubber tubes running into the washer jets are ripped into about five pieces, and there's washer fluid all over the engine bay. It's been a pretty hot day today and the car (JCW) does run hot, so winder whether this has dramatically softened the rubber, but this is the most bizarre thing I've ever seen. They look like they've been cut with a knife on the diagonal, but this is impossible as no-one but me ever goes near the car. I wondered whether an animal had crawled under the bonnet and had a go at them also, but this would be very unusual. So, I'm left thinking that maybe the rubber was a duff batch and the washer pressure has just burst them simultaneously in a few places (maybe the holes have become a bit caked as I haven't used the washers in a few weeks). This is an utter mystery to me - will take her to the dealer here tomorrow, but does anyone have a similar experience or any ideas what might have happened? Many thanks Phil |
Update OK - no replies from you guys so probably as confused as me, but I've done some asking around here and the general consensus is that they've been eaten by a pine marten (like a weasel or stoat and you do see them nocking around here at night) - they climb under the bonnet and feast on the rubber they find under there and apparently have a penchant for BMW rubber......off to the dealer for a double check and will post the outcome here. If true, this should be a warning to anyone in middle Europe - apparently, it's not an uncommon experience......in Switzerland, they offer special insurance for this to protect your no-claims!!! |
| Confirmed - eaten by critters. 11 Euros later and problem solved. Now need to get some anti-critter spray to daub my engine bay. Thankfully, it could have been much worse - I've got mates here who've had brake lines, fuel lines and HT leads eaten by the little buggars. Mini even sell a kit that they fit in the engine bay at high cost which emits a high pitched pulse to scare them away. You have been warned....... |
| Tags: washer, windscreen |
| Rear Windscreen Washer | captint | First Generation Faults & Fixes | 2 | Mar 22nd, 2008 12:29 AM |
| Bizarre Engine & EML Failure | Mongomaniac | First Generation Faults & Fixes | 2 | Nov 20th, 2006 11:45 AM |
| Parklane Windscreen washer problem | MiniMusey | First Generation Faults & Fixes | 3 | Jul 1st, 2006 03:21 PM |
| Windscreen Washer Failure | bards | First Generation Faults & Fixes | 3 | Apr 18th, 2006 05:30 PM |
| Washer Jets Failure!! | Mr P | First Generation Faults & Fixes | 18 | Nov 9th, 2005 08:38 AM |
