After fitting a roof rack, need a new gutter :( - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 28th, 2009, 10:19 AM
theminiv's Avatar
MINI2 Veteran
Local Time: 11:10 PM
United Kingdom Male View theminiv's Classified Ads
Well, I was hacking away at the perforated bits only to realise that I was hacking at the wrong end!!
Now I need a new gutter, can these be fitted easy? Or is it a big big job?
PS, roof rack is a bad piece of kit. Its pushing the shape of the gutter trim out something rotten.
Has had too many minis
Old Aug 28th, 2009, 10:43 AM
rec's Avatar
rec
England Male View rec's Classified Ads
you dont need to do any cutting on the 2nd gen - i think you might have placed this in the wrong forum area as i presume you have a 1st gen ?
Old Aug 28th, 2009, 10:46 AM
theminiv's Avatar
MINI2 Veteran
did you not see the perforated bits part of my post ?
The perforated bits are close to impossible to see on some of them, so they need pulling very hard with the tweezer kit. And I got the wrong bit.
Old Aug 31st, 2009, 08:56 PM
Registered User
Send a message via Skype™ to splitboy888
Local Time: 01:10 AM
Malta Male View splitboy888's Classified Ads
few steps that you may find useful
hello
i have no roof rack on however i was thinking of buying an original Mini rack,
after reading about fitting them in place best thing would be to thank the roof gatters off so you can locate the roof race holders better
to take of the gatters all you need is:
1) take off the door seals
2) unscrew the screws under the door seal
3) unclip by pulling towards you the rest of the roof gatter
4) locate the holders
5) slice the gatter with a small knife where the the holder is located.
6) put the gatter back on the car
Job Done
Old Aug 31st, 2009, 09:15 PM
theminiv's Avatar
MINI2 Veteran
Oh, are you sure this is for the R56? New new minis?
So you jsut remove the door seal, unscrew some screws and the gutter pops out?
Anyway, yes, if you are happy removing the gutter, I would defo recommend removing it first, this would have been a much better solution. I have to replace mine now sadly - But if what you say is right, I am happy to do it!!
Are you sure its not screwed in any other places?
Old Sep 2nd, 2009, 01:04 PM
Local Time: 12:10 AM
Belgium
any news?
Old Sep 2nd, 2009, 01:33 PM
theminiv's Avatar
MINI2 Veteran
on what ?!
Old Sep 2nd, 2009, 02:04 PM
PK5
any pics of the work you are trying to achieve?
Old Sep 3rd, 2009, 02:29 PM
theminiv's Avatar
MINI2 Veteran
I need info on how to change the gutter. Its not a project .
Old Sep 8th, 2009, 12:04 PM
Belgium
I have just bought a second hand original roof rack (still waiting to go and pick it up)
It would be nice to have some pictures of this gutter-removing job, and to see the details.
Roof Rack jshadz First Generation MINI Exterior 9 Aug 6th, 2008 09:43 PM
mini roof rack fitting!!!! grantw First Generation MINI Exterior 4 Feb 7th, 2007 02:17 AM
Replacing roof gutter Roofas Maintenance & MINI Care 0 Aug 6th, 2006 12:00 PM
Removing 05 Roof Aerial for roof decal fitting Benfrain First Generation MINI Exterior 5 Aug 27th, 2005 02:58 PM
Roof Rack fitting daverees First Generation MINI Exterior 10 May 1st, 2002 01:16 PM
