Front plastic wheel arch removal - MINI Cooper Forum
post #1 of 3 (permalink) Old Nov 25th, 2009, 01:12 PM Thread Starter
Local Time: 12:25 AM
United-Kingdom Front plastic wheel arch removal
Hey there all, just managed to scuff the front plastic wheel arch on the 2009 coopers s, looks simple to remove, well, looks like u just pull it, but would like to be more sure first before i try. Been quoted about 34 from local dealer to supply the arch. Can anyone help. Thanks in advance guys!!
iain10 is offline
post #2 of 3 (permalink) Old Nov 29th, 2009, 11:04 AM
adam_Randell's Avatar
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile View adam_Randell's Classified Ads
Send a message via MSN to adam_Randell
34!!? mine were 30 for 2!
right, first you need to get the felt lining out slightly where the arch trim meets the bumper. (only enough to get your hand in) there is a little clip there which connects the arch to the bumper (its the same sort of clip tha holds your front grill on).
once youve got this out there is another clip to get off but i dont know how to get it off and cant really see any need for it (obviously there will be but ive driven my R56 cooper round for over 2 years without it with no problems). so i just plled mine off. you will also need about 8 replacement clips for each side. these are about 2p each from a dealer.
to get the old clips from the body work, get a med-sized flat head screwdriver and a hammer, place the screwdriver between the clip and bodywork and give it a bash (thats how i did mine anyways, done it quite alot due to getting my bumper off....quite a lot )
hope this helps, someone may come with a better way that just the way i do mine
adam_Randell is offline
post #3 of 3 (permalink) Old Dec 3rd, 2009, 09:09 AM Thread Starter
Thanks for that, gonna have to bite the bullet and give it a go!!!
iain10 is offline
Replacing the front bumper outer plastic trim bkeane2414 First Generation Faults & Fixes 2 Mar 22nd, 2013 05:35 AM
replacement wheel arch clips romiloned First Generation MINI Exterior 2 Nov 26th, 2012 09:31 PM
Rear wheel arch trim clips adz1989 Second Generation MINI Exterior 1 Nov 21st, 2012 01:36 PM
removing front wheel bearing/hub..... midian-man Wheels, Tyres & Brakes 3 Sep 9th, 2012 06:06 PM
About Front wheel suspension NiuNiu First Generation MINI Suspension 3 Aug 21st, 2012 09:45 PM
