| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| Coolent and Oil Empty each Month My mini one keeps running out of oil and coolent every month totaly empty. I took it to a mini garage and they said I should be topped up every two weeks with coolent and oil. Does this sound correct as it seems a lot? Looking at the car on a ramp I can't see any leaks. Has anyone else had any similar problems? Thanks Jemes |
| Jemes, your oil and coolant must be going somewhere !! for some reason the mini garage is pulling your plonker ?? if there is no obvious leaks then I would agree that the head gasket could be knackered. you need to get it checked out asap or you will ruin your engine. Iain |
| Jemes Hi! The garage is completely lying to you! Since when would a car use 24 Litres of Oil a year? !If a Head Gasket is blown, the car looses water, which spreads around the block, Oil is not at a loss here. The engine management light (yellow) will be seen on the dash, once the system is sensing a distruction! Have the system pressure tested by another garage! Do NOT go back to that bull**** garage. There are plenty of decent MINI Specialists around, find that trust worthy guy who will tell you instantly what problem you have! “Give a man fish and he will eat for a day... ...teach a man to fish and he will eat for a lifetime” |
| Tags: coolent mini one, oil |
| help!!! bleeding coolent | mini_one_1.6 | Maintenance & MINI Care | 10 | Mar 13th, 2011 09:45 AM |
| Coolent Fluid On Top Of Gearbox | Pfendley | First Generation Faults & Fixes | 12 | Dec 6th, 2009 04:54 PM |
| Coolent Level | spongebob | Maintenance & MINI Care | 3 | Nov 24th, 2008 03:04 PM |
| coolent mix | mini_one_1.6 | Maintenance & MINI Care | 7 | Aug 21st, 2008 12:52 AM |
