R56 Dipstick will not go in - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 17th, 2011, 01:37 AM
ThatsMe's Avatar
Local Time: 09:12 AM
Australia Male View ThatsMe's Astro Black & Body Color 2nd Gen MINI Cooper S Profile
I puled my dipstick out to check the oil, and now i cannot get it back in, i have tried pushing and twisting it and it still will not go all the way in, it stops about 150mm from the top going on.
Any ideas, i need to fix it so i can go to work tomorrow.
When everything's coming your way, you're in the wrong lane.
Old Oct 17th, 2011, 12:30 PM
Local Time: 06:12 PM
I have the same problem with the dip stick not going back in all the way. Has anyone found a solution?
Old Oct 18th, 2011, 09:56 AM
ThatsMe's Avatar
Mine was the PLASTIC timing chain guides caused by the timing chain tensioner (that had already been replaced about 5000k earlier), I had to fight my dealer to have it fixed under warranty, as my car was 8 days out of warranty, long story short after contacting MINI Australia they replaced the timing chain tensioner, timing chain guides, timing chain and dip stick all under warranty.
Tags: ,
Dipstick Trevor First Generation Faults & Fixes 2 Mar 2nd, 2011 02:46 PM
Oil Dipstick and Oil to use kingoftherodeo Maintenance & MINI Care 4 May 17th, 2010 06:48 PM
snapped dipstick!!! HELP removing dipstick Pipe!!! venox22 First Generation Faults & Fixes 10 Jun 7th, 2006 08:25 AM
Oil dipstick 118 Maintenance & MINI Care 5 Aug 24th, 2004 12:27 PM
MCS Dipstick mcsyorkie First Generation Faults & Fixes 5 May 6th, 2004 04:45 PM
