| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| Help!! Noise from engine bay when car is off killing battery Hello all, We recently purchased a Countryman S, two weeks ago, and are having an issue that I have no idea on what it could be. Last week I came out to a dead battery, charged it up and checked and nothing was left on. Three days later same issue, charged it up and everything was fine. I then got into the habit of when I turn the car off in the garage waiting to make sure that all the lights are off so that nothing is killing the battery. This is when I heard a clicking noise from the engine bay; the best way I can describe the sound is a solenoid opening and closing. It makes this sound approximately every 90 seconds or so and I'm pretty sure this is what's killing the battery. I looked and listened and could not see anything moving. The location of the sound, standing in front of the car looking down at the motor, seems to start on the right side of the block as a light "engagement" sound and then to the left of the block near the firewall it sounds like a valve opening. We live 4 hours from the dealer and have an appointment next week but if anyone knows what could be causing this I would greatly appreciate it. Also, it doesn't matter if the car is locked or not - hood open or closed the sound is still present. Thanks in advance!! Steve |
Same Problem Here Steve, what ended up being the problem? What did the dealer say? I'm having the exact same issue with my 2012 Cooper S Hardtop. I only had the car one day and the battery was drained. Dealer is still running diagnostics. |
| That is a not a big issue, Don't worry. Sometime it happens in battery due to some chemical reaction in case of overheating of engine. You should concern with your car service dealer. So don't worry. |
| Tags: battery, countryman, noise |
| Problem with battery after replacing cooper-S engine | mrwarby87 | First Generation Faults & Fixes | 3 | Jan 30th, 2012 12:58 PM |
| Door Motor Failure Killing Battery? | Tallpaul | First Generation Faults & Fixes | 0 | Mar 2nd, 2009 03:08 PM |
| Battery, EML, Engine Warning Lights on | Lende | First Generation Faults & Fixes | 11 | Apr 28th, 2008 09:44 PM |
| Engine won't start - Battery Problem? | jleydon | First Generation Faults & Fixes | 3 | Jul 11th, 2006 04:12 PM |
| Battery Light ON then engine overheats!!! | Rolandh | First Generation Faults & Fixes | 8 | May 12th, 2004 06:06 PM |
