Cooper S 2007 lambda/fuel running problem - MINI Cooper Forum
post #1 of 6 (permalink) Old Aug 22nd, 2011, 08:02 PM Thread Starter
Local Time: 02:18 PM
United-Kingdom Cooper S 2007 lambda/fuel running problem
Hi All
Im new to the forum wondered if any of you may be able to help with a problematic cooper s i have,
its a 2007 (45k miles) recently developed the 'death rattle' swapped the cam chain, tensioner, guide rails & oil - job done rattle gone.
Now next problem, engine management light on, mechanic had a look at the fault, code reading 'bank 1' (suspected pre cat lambda sensor). The car was due MOT so decided to put it through test to see how emissions read - car failed on everything possible on emissions. Decided to swap the pre cat lambda, which thankfully flew through the re-test.
However now the car seems to run terrible, lack of turbo and excessive fuel consumption???? not sure what to do now as the emissions test passed with flying colours!
forgot to add all recent parts ive bought are genuine,
Any help would be appreciated
Many thanks
Ben
b3nhk is offline
post #2 of 6 (permalink) Old Aug 23rd, 2011, 09:21 PM Thread Starter
come on people someone must be able to help
bloody management light come back on again today
b3nhk is offline
post #3 of 6 (permalink) Old Aug 23rd, 2011, 09:35 PM
Canned
MINIAC's Avatar
Local Time: 06:18 AM
Quoted: 2 Post(s)
I doubt many MINI technicians frequent this site.
MINIAC is offline
post #4 of 6 (permalink) Old Aug 23rd, 2011, 11:17 PM
If the problem is since the timingchain replacement, maybe the valve timing is out, as a ill running vehicle can pop up a lambda fault as there is to much unburnt fuel entering the exhaust.
stead34 is offline
post #5 of 6 (permalink) Old Aug 24th, 2011, 06:54 AM Thread Starter
Thanks stead think ill take it to bmw let them check the timing
b3nhk is offline
post #6 of 6 (permalink) Old Nov 28th, 2012, 08:22 PM
bpirie1000's Avatar
Local Time: 01:18 PM
Scotland View bpirie1000's Cosmos Black & White 1st Gen MINI Cooper Profile View bpirie1000's Classified Ads
Did you get this sorted? Which sensor was it? Top or bottom as there are 2 sensors on the 2007 cooper S.
bpirie1000 is offline
pre cat lambda sensor problem golfpro1 First Generation Faults & Fixes 0 Aug 5th, 2010 11:41 AM
Running Problem-Mini cooper S-Help 546roberts First Generation Faults & Fixes 4 May 26th, 2009 04:53 PM
Cooper S Fuel Cap Problem webbocs First Generation Faults & Fixes 3 Feb 12th, 2009 06:52 PM
Argh! Convertible Roof and Lambda sensor problem spinout First Generation Faults & Fixes 4 Jul 24th, 2008 02:24 PM
Fuel Pump problem on 2004 Cooper S silvertoro First Generation Faults & Fixes 4 May 28th, 2008 12:31 PM
