R56 Mini Windscreen Washer Reservoir Problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 8th, 2011, 08:41 AM
stucam's Avatar
Local Time: 11:13 PM
Scotland Male
Scotland R56 Mini Windscreen Washer Reservoir Problem
Hi folks,
First posting, so hopefully in the right place and proper protocols being followed
I have a problem with my Mini Cooper (Built Dec 2006) which I think is classed as R56?
A couple of months ago when I was filling up the windscreen washer reservoir tank with some ready to use windscreen cleaning fluid, the cardboard piece that is on the inside of the cap of the fluid went straight down the reservoir. It was dark at the time! Unfortunately there was no way of being able to get it out even by filling up the reservoir and hoping it would float to the top. I thought that it would just eventually degrade and wouldn't be a problem. The reservoir has been refilled four or five times since then without any issues. However on the last fill when it was empty the washers are all still working but the front now seems to only be coming out at about half the force it originally did.
Can anyone offer any comments/advice on this and what would be the best way to proceed.
Thanks in advance folks.
Stucam
Old Nov 8th, 2011, 05:52 PM
mab01uk's Avatar
Online
Local Time: 12:13 AM
Some of the links below may be of help in your investigation of the problem.
The screenwash reservoir for the R56 MINI is in front of the nearside wheelarch.
Overview of R56 MINI windscreen washer system:
http://r56mini.com/tisdocs/RA%20Over...0%28SRA%29.pdf
Removing Wheelarch cover:
http://r56mini.com/tisdocs/RA%20Remo...ch%20cover.pdf
http://r56mini.com/tisdocs/RA%20Remo...her%20pump.pdf
RealOEM.com BMW R56 Cooper Reserv.,windshield/headlight washer syst
http://r56mini.com/tisdocs/RA%20Adju...%20nozzles.pdf
Tags: , , , , ,
Mini Window Washer reservoir Help! lovemymini09 First Generation Faults & Fixes 5 Dec 4th, 2009 07:32 AM
Leaking Washer Reservoir Buffster Bird First Generation Faults & Fixes 1 Sep 3rd, 2008 03:13 PM
Parklane Windscreen washer problem MiniMusey First Generation Faults & Fixes 3 Jul 1st, 2006 02:21 PM
Windshield Washer Fluid Reservoir LockjawDavis First Generation Faults & Fixes 8 Feb 20th, 2003 05:32 PM
Larger Windscreen Washer Fluid Reservoir??? GMINI First Generation Faults & Fixes 2 Jan 31st, 2003 08:37 PM
