How much should I expect to pay to have the water housing replaced? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 5th, 2012, 09:04 AM
Williffe11's Avatar
Local Time: 11:13 PM
United-Kingdom How much should I expect to pay to have the water housing replaced?
I recently discovered the coolant on my Mini Cooper (55Reg) was way too low. I've taken it to a local garage and they said they've found a leak - not major - but not good all the same. They've recommended I have the water housing replaced. I asked them how much and they gave me the standard whistle through the teeth and said they really couldn't tell me off the hoof as it was a BMW part that they don't often order. Can anyone give me any advice on how much is a reasonable amount to pay - I know labour will be on top. Forwarned is forearmed!
Thanks!
Old Jan 5th, 2012, 11:44 AM
mab01uk's Avatar
Online
Local Time: 12:13 AM
I presume you mean the thermostat housing which is a common Mini fault?
details of replacement here:
Thermostat Replacement (MCS) - Forums
Price of the part or parts required can be obtained by phoning or visiting your local Mini dealers spare parts department.
Part No.10 in diagram below:
http://www.realoem.com/bmw/showparts...99&hg=11&fg=35
Tags: , ,
thermostat & housing Senior Maintenance & MINI Care 1 Oct 23rd, 2011 07:37 PM
Oil filter housing Slashmb Maintenance & MINI Care 1 Jan 13th, 2008 07:20 PM
Water damage to engine - air intake susceptible to sucking in water stevesok First Generation Faults & Fixes 83 Jul 25th, 2007 03:58 PM
Water leak Coupe filter housing! Crashnet2000 First Generation Faults & Fixes 1 Jun 22nd, 2006 01:21 PM
Oil Filter Housing NJ Bob First Generation MINI Cooper S 2 Jun 10th, 2005 07:21 PM
