| Second Generation Faults & Fixes MINI faults and fixes Late 2006 - Present |
| Hi, It very well could be the cold but then the front washer would also be blocked as they feed from same tank if i am correct, i am not sure if the rear wiper is the same on your as older mini but don't see why not, so your rear wiper may just be blocked, you can open up the end of the rear wiper and check blockage in nozel, this can be cleaned with a paper clip, if you don't see any blockage then try rear washer again, if you see a jet of water then the blockage will be in the plastic cap attached to the rear wiper, you can use a paper clip to clear out any gunk. |
| Rear Washer Fix | nat21com | First Generation Faults & Fixes | 0 | Jan 6th, 2011 03:14 PM |
| Where's the rear washer! | marleymarl | First Generation Faults & Fixes | 4 | Feb 12th, 2010 10:59 PM |
| Rear washer doesn't work | IH1 | First Generation Faults & Fixes | 22 | Sep 13th, 2009 06:20 PM |
| Rear Wiper Washer Jet | JaysToy | First Generation Faults & Fixes | 6 | Mar 7th, 2005 09:37 PM |
| Rear Window washer jet? | hapaboy | First Generation MINI Exterior | 30 | Dec 23rd, 2002 03:46 PM |
