Ice Warning - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 6th, 2012, 08:17 AM
jonsteele's Avatar
Mini Newbie
Local Time: 12:14 AM
United-Kingdom Ice Warning
According to the manual, the car is supposed to warn you if the temperature falls below 3 degrees C - this is exactly the same as my E90 used to do. The temperature around here hasn't got above 3 degrees for a while, but I'm sure the E90 would still warn me even if it was below the threshold on start up - the MINI isn't doing, but is still displaying the temperature.
Can someone please confirm their MINI does this before I book it into the dealers again!
Old Feb 6th, 2012, 09:41 AM
United Kingdom Male View Spacer's Chili Red & Black 2nd Gen MINI Cooper Diesel Clubman Profile
Yep, my 2011 Clubman starts boinging when you start the car if the temp is below 3.
harvey94's Avatar
Male
Hi,
I do not have the same mini as you but i assume they all do the same which is when you get in the car and turn on ignition you get a warning tone and the temp display will flash.
Old Feb 6th, 2012, 12:33 PM
Local Time: 11:14 PM
Russia Male
So that's what the boinging means!! It's been consistently below 0*C since i got it last year so it always does that
Old Feb 6th, 2012, 02:16 PM
jonsteele's Avatar
Mini Newbie
Ta, another visit to the dealers then!
Old Feb 8th, 2012, 07:29 PM
Online
Must admit, mine doesn't always boing the change. Usually does, but not always. No warning triangle anywhere either.
Airbag warning light and tyre warning lights BOTH on? elainegel3 First Generation Faults & Fixes 1 Feb 1st, 2011 06:07 PM
Warning jordan First Generation MINI Convertible 1 Jun 10th, 2004 06:10 PM
